Results 1 to 20 of 20
    Apr 19 2008
    Spokane, WA
    Verizon/Bluetooth Question
    I'm in the market for a B7, and I'm trying to decide whether to get the bluetooh option as a Verizon user. I've done a lot of search, and I'm getting conflicting info. If I buy an a4 with bluetooth, will my verizon razr work with the bluetooth? The phone is listed on Audi's site, but I've seen people say that Verizon disables bluetooth compatibility and that you have to download special software.
    I anyone running this phone with bluetooth in their b7?
    Thanks.
    Apr 18 2008
    Jacksonville, FL
    Re: Verizon/Bluetooth Question
    no experience personally on that phone, but i'd say go to your local audi dealer and ask if you can try that on a new audi. check the vehicle manual for how to do the pairing (and your phone manual for how to delete the pairing after you test it), but basically the car is discoverable for 5 minutes after you start it. during that time, have your phone look for new bluetooth devices, and when it finds the car, use "1234" as the pin (i think, check the manual to make sure). if your contacts show up, cool, you're good to go. if not, dinger.
    2011 Toyota Tacoma Double Cab SR5
    SOLD 10/2011
    2008 A4 Avant 2.0TQ Tip in Quartz Grey
    APR Stg 1; RS4 Rear Sway; 034 Turbo Inlet Pipe; 35% tint; 640 SWITCH mod; GROM-I2-VAGD + Proclip
    Apostrophes: how to use them Baby Jesus cries when you misuse apostrophes.
    Jun 21 2008
    07 A4 2.0T S-Line Quattro Tip
    Northeast Alabama, US
    If it's a bluetooth enabled Moto Razr, than it WILL work on your B7.
    Apr 19 2008
    Spokane, WA
    Thanks for the feedback. It is bluetooth enabled, so I'm gonna assume it will work. I may take mud's advice and try it at the dealership before I close the deal. I've just heard so much about Verizon disabling connectivity that I wasn't sure.
    Veteran Member Four Rings praudi's Avatar
    Jul 31 2007
    R8 power wheels , Tiguan and Ferrari F1 power wheels
    Tampa,Fl
    i have a motorola q and it works perfectly no problem my gf has an lg venus both from verizon so go ahead
    Veteran Member Four Rings a4dc89's Avatar
    Nov 07 2007
    Land Rover Disco I
    Washington DC
    yeah, mine works fine with verizon
    2006 A4 B7 2.0TQ Dolphin Gray Metallic 6MT
    REVO Stage II, 034 HFC, AEM turbo inlet/intake, OEM Piston DV, BSH PCV Fix, HID Fogs/Fog Mod, AWE Boost Gauge, Debadge
    All go no show
    Nov 12 2007
    Grand Junction, CO
    I've had 3 phones on the verizon network with bluetooth and they all work just fine with the bluetooth. Two KRZR's and one Blackberry Pearl. All work great!
    Apr 18 2008
    Jacksonville, FL
    yeah, it'll probably work just fine, but if it's important to you, it's probably worth the 10 minutes at the stealership to test it for yourself.
    SOLD 10/2011
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    i love bluetooth with my verizon q9m in my sline. i dont think ill ever be able to buy another car without it...
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Apr 19 2008
    Spokane, WA
    Thanks again, gang. One less thing for me to worry about.
    Jun 18 2008
    Even though it has been answered, Ill add that the new Dare from verizon works, and that just came out. So, you should be good!
    Mar 24 2008
    I happen to work for Verizon, and I know we've paired several of our phones with Audi's. I don't have the bluetooth option in my car, but I know it works. You shouldn't have a problem at all. Oh and on the phone, unless you change it, the bluetooth password is always "0000."
    Veteran Member Four Rings ibiski's Avatar
    May 21 2008
    Most likely it will pair without a problem, but Verizon is the worst company when it comes to firmware. They cripple their phones by disabling many features and putting in their own junk. Go here and you'll know everything: http://www.howardforums.com/forumdisplay.php?f=51
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Quote Originally Posted by QuadRings View Post
    When pairing a phone (any phone) to the Audi BT system, the BT password on the phone doesn't actually matter. The default Audi BT password is 1234 and is what you'd use to pair your phone with your car.
    Mar 24 2008
    Quote Originally Posted by mksap11 View Post
    Ah got ya. Yeah I've never paired them myself, our technicians usually do it. And yes, Verizon does f' all their phones up with their software, it's dumb, but oh well.
    Veteran Member Four Rings rudtf's Avatar
    Dec 27 2005
    07 A4 2.0TQM S-line Ti Ibis
    Ft lauderdale
    damm i've been trying this all day. i have the lg voyager and i've searched and read posts where people have paired the voyager just fine. any tips? i also see posts where you leave the car running, and turn turning the key to the on position, which is it? i've tried both. also how long do you let it search for?
    Dec 27 2005
    Ft lauderdale
    no tips????
    Aug 08 2008
    2017 Q5
    Houston, TX
    i got a tip....i say make sure you put your phone in discoverable mode. that should be it. thats what i did for a few customers and it connected fine. should be a ok.
    Dec 27 2005
    Ft lauderdale
    yes my phone is in discovery mode... any other tips? is my car supposed to be running or just battery on? i've tried both ways many times
    Registered Member Two Rings 80020vr6's Avatar
    Dec 19 2006
    2007 A4 2.0TQM (Ibis)
    Colorado
    I've got a LG ENV2 and it will sink up, but about 30seconds later it disconnects. Don't know what's up. My RAZR with T-mobile worked without fail.
