Results 1 to 10 of 10
    Senior Member Two Rings dichiee's Avatar
    Dec 15 2005
    What do you think about this suspension setup?
    I'm on a tight budget right now and I'm thinking of getting Vogtland Club Spec springs with Bilstein sports then add the ECS Coilver kit later on. Is this a good setup?
    Thanks in advance.
    ## dichiee ##
    2012 A4 Prestige S-line | 2016 Fiat 500e e-Sport | 01.5 India Red A4 Avant | 04 A4 3.0QAS | 07 Passat Variant 2.0T | 02 S4 Stage II | 01 Cabrio GLX | 96.5 Jetta GLX | 99.5 2.0 Jetta (RIP 1999-2004) | 95 2.0 Golf Sport
    4th Watch!
    Forum Moderator Four Rings docurley's Avatar
    UK London
    Re: What do you think about this suspension setup?
    Just put H&R Race springs on the stock sport shocks it will be fine I ran that set-up for near on 2 years.
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Dec 15 2005
    is the ride the same as the stock sport? I have 65K on the car already.
    Where can I get RS4 shocks here in the states? How much do they run over there?
    ## dichiee ##
    4th Watch!
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Vogtland Sports over Bilsteins or Konis is a very nice setup. The Club Spec springs are too low. I'm pulling a set off of a local's S4 Avant with Club Specs over Konis. The thing is tucking some tread.
    Jim
    I Do Werk.
    UK London
    The ride is stiffer with the sport shocks and the H&R springs and I would not waste any money one the shocks because you are planning to go Coilovers later.
    RS4 shocks would have to be a main dealer option or try vagparts.com butit may be cheaper to just et upgraded shocks but my point is save the money and just do the springs and go do the coilovers later.
    My car had more miles then yours when I put the H&R springs on and only swap out the shocks as I had them sitting around and I was puting on the RS4 brakes.
    Dec 15 2005
    oh ok but its not bouncy right?
    ## dichiee ##
    4th Watch!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Oh, im running the same setup and it is bouncy. lol
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Feb 22 2007
    Australia
    club spec springs over koni are VERY nice. They are A4 front (350lb/in) and S4 rear (360lb/in) so if anything on the A4 they'll be higher at the back compared tothe Vogtland sport. Very nice and neutral handling with neuspeed rear sway bar
    Veteran Member Three Rings firstars's Avatar
    Jan 22 2007
    NNJ
    used to have vogtland/koni now have H&R coilovers. The spring/shock combo was very bouncy compared to the coils
    2007 Cayman S Racecar For Sale!
    2017 Raptor Avalance Gray Daily
    2012 Cayman S Track
    2013 S4 Sepang Blue Traded
    UK London
    Quote Originally Posted by dichiee View Post
    Nope it was fine, when I had H&R race springs on my none Sport shocks it was bounce on slow dips in the road but my 1.8TQ with sport shock was fine.
