Results 1 to 3 of 3
    Mar 18 2007
    Singapore
    Smile Parking light bulb holder melted!
    My left parking light blew, and apparently as I was told by my service guy, the bulb holder had melted and he was unable to replace the bulb. Mine were retrofitted xenon lights with the projector housing and I was advised to have the complete left housing replaced!
    Any idea what could have caused this ? I'm determined to find out why, so that the same thing doesn't happen again when I have the replacement done.
    Thanks,
    Edgar
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: Parking light bulb holder melted!
    what kind of xenon lights did you have? haven't heard of the actual xenons/HID's to cause melting but i know the Hoen city lights tend to melt alot of housings. Was it just the xenons that you had or did you change some of the other lights as well? Lucky for you the Halogen housings are cheaper then the xenon ones!!
    The usual things!!
    Resistor Install
    Veteran Member Four Rings Sanjman's Avatar
    Nov 16 2006
    nothing else special
    Skokie, IL
    were you using hoen parking light bulbs?? it has melted a lot of housings... and most people who still have them have no idea it's melting... everyone should check... there is a thread about this too if you want to read it... search.
