Results 1 to 19 of 19
    Dec 03 2005
    2 pedals 1FG
    connecticut
    clutch pressure plate torques
    I'm in the middle of putting my engine/trans back together and getting it in my car today.
    Flywheel is bolted on. For my 22.5mm OEM Bolts my torque was 60Nm + 90deg
    What are the pressure plate bolt torque values?
    Shall I put some blue loctite on the threads? Looks like the ones that came out did not have any loctite.
    FYI: Southbend OFE SS clutch with OEM DM Flywheel. Clutch has been installed before so I'm just reinstalling everything. New flywheel bolts and re-using PP bolts.
    -Doug
    Buncha motorcycles
    Memphis, TN
    Re: clutch pressure plate torques
    60nm + 90 degree turn
    i thought the flywheel was 60nm + 180 turn?
    yeah i just checked the bentley.. flywheel is 60nm + 180 and the pressure plate is 60nm + 90
    i have the pic but i cant figure out how to load it... i can email you the microsoft word file if u want
    APR Stage 2/AWE Intake
    Established Member Two Rings smarrick's Avatar
    Apr 07 2008
    04 A4 18T 6MT QT SPORT, 07 X3, 74 Lincoln Continental
    Fort Collins, CO
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Jake told me the spec for the PP bolts is 22Nm. He suggested (and I did) 30Nm with loctite on the PP bolts. That is what I did and it felt pretty friggn' tight. I don't see 60Nm on the PP bolts.
    Trans is now on and everything looks good.
    Engine/Trans is going into the Avant shortly....
    -Doug
    Buncha motorcycles
    Memphis, TN
    i would agree with that, i did the 60nm plus a 1/4 turn is all i could get , i started to strip one and said the hell with it, thats tight enough... i have the snappy torque wrench so it clicks when its at 60nm
    Dec 03 2005
    2 pedals 1FG
    connecticut
    The Craftsman one I'm using clicks too. I used a 1/2" breaker bar to get the 90deg turn on the flywheel bolts.
    -Doug
    Buncha motorcycles
    Memphis, TN
    be a man! do 60nm + 180!!!!!!
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    I also did EXACTLY what papachristou did:
    60Nm + 180* for the Flywheel (New OEM bolts - supposedly have loctite already on them)
    60Nm + 90* for the Pressure plate bolts (I used ACE hardware bolts grade 10.9 versus the OEM bolts that are grade 8.8...plus they had a 13mm head versus the CRAPPY OEM hex head bolts....I did NOT use loctite)
    -Sami-
    Buncha motorcycles
    Memphis, TN
    oh i hated those OEM pressure plate bolts, so soft... i dread if i ever have to take them out... ill probably be dremeling a cut in them to use a large flathead or something... i should have done what you did... oh well, hindsight is 20/20
    Dec 03 2005
    2 pedals 1FG
    connecticut
    60Nm for the pressure plate is too much! They are a 6mm bolt which can't take too much load. All the torque on the pressure plate is taken out on the dowels.
    I had no problems with the OEM flywheel bolts (12point). No stripping when removing and no issues when installing. It helps to have the right tools.
    -Doug
    Buncha motorcycles
    Memphis, TN
    oh yeah definitely, the OEM flywheel bolts (spline drive/triple squares) are a great design and allow you to put plenty of torque down.. i was talking about the pressure plate bolts.. shitty design... i was just following the bentley torque specs for them......
    (i can assure you, i have all the right tools!)
    60nm+90 is too much for those soft allen head pressure plate bolts
    Oct 29 2005
    10speed
    San Francisco, CA
    My impact gun does great things
    - Clint
    Buncha motorcycles
    Memphis, TN
    Makes it easy when u dont have big guns
    Feb 19 2007
    Charleston, SC
    +1 ... I too was referring to the PP bolts. I had ZERO problem installing the flywheel bolts.
    I have all the right tools and the some! When I first installed the PP bolts I used brand new OEM bolts and all they did was strip the damn head and then I had to dremel a big notch in it and it took like 30 minutes to get it out with a big flathead! But with those ACE hardware bolts everything went super smooth
    -Sami-
    Buncha motorcycles
    Memphis, TN
    im sure thats what ill be doing if i ever do another clutch job... if i do, im going to go to a lightweight flywheel.. .my car isnt a DD anymore so i can mod all i wont now
    i really think if i had the new flywheel there (and all the stupid new bolts), i could do the whole job in 8-12 hours now..
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    i meant 30 ft. lbs. doug lol... whatever, i explained to you what those bolts do so its all good , the loctite is what matters
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by 317ssayzarc View Post
    That is what I did, look at post 4.
    -Doug
    Oct 27 2007
    In the lab
    post 4 says newton meters....
    look what i got today...
    means its go time...
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Awesome!
    I just finished wiring my EBC and boost gauge. FMIC should be here tomorrow.
    -Doug
