Results 1 to 18 of 18
    Mar 12 2007
    Boston
    ECS Snub Mount and new Bosch plugs going in today, Vogtland COs ordered!
    Should have the coils on by next week. Can't wait.
    SOLD 4/16/15- '08 Daytona Gray RS4/Black leather/CF trim/35% tint/MTM 10mm spacers/Euro steering wheel/GMG catback w/ Magnaflow DPs
    SOLD 9/4/11- '04 Nogaro Blue S4 w/ LaBree Resonated Fullback/ Vogtland Coils/ ECS Snub Mount/18x8.5" et32 Diamond Black RS-GTs
    Oct 11 2007
    Suburbia
    Re: ECS Snub Mount and new Bosch plugs going in today, Vogtland COs ordered!
    hows the snub mount? I am considering buying one, but im not sure if ill notice any performance increases, esp. since i drive a tip..... Let me know , thanks.
    Mar 12 2007
    Boston
    I'll let you know after the first drive. By all accounts, it is a HUGE improvement to the driving experience in 6mt cars. I've read the difference is less dramatic for Tip cars, though.
    Veteran Member Three Rings covertS4driver's Avatar
    Jun 11 2008
    2007 Audi RS4 (Gone), 2005 Audi S4 (Gone), 2002 Audi S4 (Gone)
    Dutchess County, NY
    Did you install the snub yourself? I want to get one, but it seems like a tough install.
    I will prob try it anyways! :)
    2000 Audi A4 Race Car, 2014 Audi SQ5 (Daily)
    Run Silent, Run Swift...
    Mar 12 2007
    Boston
    a few on AZ have done it themselves and the consensus seems to be it's worth paying to have someone else do it. my local quoted me around $200 for the install.
    Deactivated Two Rings
    Nov 12 2006
    Pensacola, FL
    i installed mine myself and it's a real PITA, but a very worthwhile mod, especially when coupled with a short shift kit. I would definitely pay someone to do it.
    Oct 11 2007
    Suburbia
    Anyoe with a Tip have a consensus on the mod? i'd be interested in what they have to say............
    Veteran Member Three Rings VR2V8's Avatar
    Dec 20 2007
    Philly Area, PA
    The snub install is actually very EASY.........provided you have someone helping you. At first I tried making the room to work by wedging a hammer in there. It didn't work out too well and I could only get about 1/8-1/4 turns at a time on each bolt. Loosen the bumper rebar bolts and have a friend pull on the rad support to give you room to work. Doing it this way I was able to turn all the bolts entire revolutions at a time.
    By myself, it took over 2 hours just to get the old snub out. With a friend helping, it took less than 5 minutes to get the new snub installed and torqued. And another 20min or so to put the rest of the car back together.
    So take it as you will:
    By yourself--> PITA, frustrating, time consuming
    With help--> Easy, could probably do the entire disassembly, swap, and re-assembly in about an hour.
    2022 SQ7: P+, Daytona Gray Pearl/Black, Alu Optics, Ambient Lighting Package, Extended Leather Package
    Audi All-Season Floormats/Trunkliner, Llumar CTX 35%
    Jun 11 2008
    Dutchess County, NY
    Did it in about an hour? That is awesome!!
    I have also heard that it is a great mod for the MT. Don't know about the tip
    Oct 11 2007
    Suburbia
    Any Tip guys have this?
    Registered Member Two Rings
    Jun 23 2008
    Iowa
    Sorry, newb here - what is a snub mount? Is it a good upgrade for a RS4?
    Oct 11 2007
    Suburbia
    Quote Originally Posted by blacksheep View Post
    Its an engine mount, it helps with shifts and such, and yes it would benefit a RS4, considering its a stick.
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    Didn't APR have a bad batch of these? What's the deal?
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Oct 11 2007
    Suburbia
    Quote Originally Posted by swoyekr. View Post
    I remember reading something about APRs snub mounts but im not sure what it was.....
    Dec 20 2007
    Philly Area, PA
    Yes, a bunch of people had them split in half. That was a while ago and I haven't read about it happening to anyone in a while.
    Mar 12 2007
    Boston
    Got a call from the shop and they adjusted their initial estimate on the install from 2 hours to 4 hours. Told them to hold off for now. I am going to look around for a more reasonable deal. So....no snub mount today for me.
    Dec 20 2007
    Philly Area, PA
    Quote Originally Posted by tadhgbrosnan View Post
    I can almost guarantee you that's because they think they need to remove the entire rad support do the job. If you really don't want to try it yourself, I'd find a shop that's more familiar with Audi's. I don't even think an Audi dealer would need 4 hours to do the swap.
    Mar 12 2007
    Boston
    Sadly enough, this was the local stealership. I asked around and was told these are some of the most experienced Audi guys in the area. Appears not. Thankfully, I have more options available but will have to travel farther to use'em.
