Results 1 to 13 of 13
    Senior Member Two Rings BoRoKo's Avatar
    Mar 08 2008
    Illinois
    AudiWorld.com couldn't help, maybe you guys are better-please read and help
    2.8 V6
    Car can not start, it's cranking and almost start but failed.
    I checked almost everything switching parts from my wife's A4 with the same engine.There is more the half fuel in the tank.New spark plugs, new wires.Even switched wife's igniton coil and nothing The only one think which I observed is that spark on the plugs while engine crankink is so WEAK, almost not visible (one time blink, no more). Switched even ECU's and nothing.
    Thought that ignition coil is not getting enough power to fire up the spark plugs. What can cause that ? What module gives power on ignition coil ?
    Looks like engine has fuel, but no power on spark plugs to burn it.
    If you can help, PLEASE becouse it's been fourth day without any idea.
    Here are the codes what I had:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    16795 - Secondary Air Injection System: Incorrect Flow Detected
    P0411 - 35-00 - -
    18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
    P1606 - 35-00 - -
    16684 - Random/Multiple Cylinder Misfire Detected
    P0300 - 35-10 - - - Intermittent
    16685 - Cylinder 1 Misfire Detected
    P0301 - 35-10 - - - Intermittent
    16687 - Cylinder 3 Misfire Detected
    P0303 - 35-10 - - - Intermittent
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: AudiWorld.com couldn't help, maybe you guys are better-please read and help
    You might have a loose power of ground connection loose on that terminal causing weak power to the coil. Check that first.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Well that code can be thrown if the ecu or battery are unplugged and it will be stored till it is cleared.
    Could be a bad crank trigger sensor, but I dont see a code for it.
    Maf could be bad to the point that the ecu doesn't see any air going thru it so it doesn't give any fuel. Can try unplugging the maf to see if the car will start.
    Mar 08 2008
    Illinois
    MAF has been switched from my wife's car - still doesn't work.
    This crank position sensor is on the back of camshaft ?
    I already switched it as well.
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    I say is the Cam position sensor sensor.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Mar 08 2008
    Illinois
    cam pos. sensor on the back of camshaft ? driver side
    Jul 07 2004
    socal
    Quote Originally Posted by BoRoKo View Post
    Pretty sure the crank sensor on the 2.8 is located on the tranny bell housing, it just senses the flywheel instead.
    Mar 08 2008
    Illinois
    I know what you are saying. That's the only one sensor I didn't check.
    Just to wanna make sure - sensor is right above the driver's axle on two bolts in tranny ?
    Mar 08 2008
    Illinois
    Update
    I replaced from other audi 2.8 engine, crank position sensor,
    http://picasaweb.google.com/betho500...75236733831698
    And it's still doens't work Fuel filter replaced as well.
    What is going on with my car ???
    Jun 25 2007
    Phoenix
    Do you hear the fuel pump running? And are you sure that fuel is making its way into the cylinders? Smell the spark plugs after you try to fire it up and see if you can smell the fuel.
    Mar 08 2008
    Illinois
    Yes, I can hear the fuel pump is running. I even disconnected fuel rail to the injectors and it's full of gasoline when cranking. There was a lot of fuel from filter while I was removing it. So at this point fuel is not an issue.
    What about sparks ? What take control over the igniton coil ?
    Looks for me, there is not enough spark on the plugs to burn in cylinders.
    here is a sensor which I replaced today. still dead while cranking
    Senior Member Two Rings audi_a4_kid's Avatar
    Jan 14 2005
    1996 2.8 12v
    Wa
    does your battery hold a charge? or is it possible that its dead?
    Mar 08 2008
    Illinois
    Battery is about to die while the engine is cranking that's why I'm running on jump from another car. Gauge shows 12 Volts and below later on.
