Results 1 to 21 of 21
    Jun 29 2007
    Raleigh, NC
    question about internal waste gates
    ok... we all know they suck for larger turbo applications, go external, blahblahblah
    that's not of any importance here, so keep the opinions to yourself. kthx
    anyways, lets assume that hypothetically - someone with say... a GTRS eliminator was considering upgrading to a 3071R-WG (the bastard child of a love-hate relationship between a 2871R and a 3071R)
    would swapping the waste gate actuator from the GTRS be feasible? Does anyone know what the set spring tension is in it? (7psi?) and would it be more worthwhile to upgrade to a 14psi actuator if it is indeed a 7psi on the GTRS.
    while we're on the subject, if you're running a MBC or EBC (which effectively reduces the amount of boost the waste gate actuator sees) would it even matter which one you had?
    this is all hypothetical of course...
    (SOMEONE BUY MY GTRS!!!!!!!!)
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: question about internal waste gates
    Your 2871 WG act. will fit on Shawns 3071wg. A 7psi spring is 7psi and can only increase boost but not lower it. I am running off the WG spring in my car for the time and get 5-7 psi, I have an ext. WG but that doesn't matter. All a MBC or EBC does is limit/control the amount of boost the act. sees.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 29 2007
    Raleigh, NC
    that's what i though. so i guess i'll be swapping that over
    The Awesome™
    Veteran Member Four Rings F16HTON's Avatar
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    Quote Originally Posted by B6Lovin View Post
    Hypothetically speaking why are you interested in changing turbos already? What exhaust manifold are you planning on running?
    FWIW the Eliminator series turbos come with a 1.0 bar wastegate actuator that can be tuned a little higher or a little lower depending on the tension you put on it (pre-load).
    You cannot just change your actuator to the 30-71WG because the arm on the eliminator series turbos is modified (shortened by ATP) and does not work correctly on the full sized T-2 or T-3 flanged turbo.
    If you are planning on running between 14 and 30 pounds of boost, the internally gated turbo will do you just fine, you will not see boost creep with it because NOBODY runs 9-12 pounds of boost on the 1.8T, it just does not make power at those levels.
    There are a few choices out there for T3 flanged manifolds for the 1.8T Longitudinal motor but they all have the highlights and drawbacks.
    1.) ATP style cast iron manifold: Works well, the turbo will fit on the side of the motor however you will be replacing studs all of the time because they break. The reason they break is because the turbo is heavy and the studs support the full weight of the turbo, no all 4 studs support it but rather 2 studs because of the size of the holes in relationship to the size of the studs. Log style cast manifolds are not good for high RPM applications because the exhaust pulses begin to cancel each other out and send the EGTs through the roof too.
    2.) Tubular style manifolds: All tubular manifolds wil eventually crack, it is a fact of life, get over it. The main advantage is when there is a low merge angle on the collector that allows the exhaust to flow more freely at higher RPMs which gives you higher output. Everyone that I know who runs a tubular low merge angle manifold feels it performs better at higher RPMs. I might be a bit biased but I feel the Full-Race manifolds are the best on the market right now.
    Feel free to call me any time if you have questions.
    Jun 29 2007
    Raleigh, NC
    ok. so i CANT just switch my actuator over? i was looking on ATP's website, and they charge the same for a 7psi actuator as a 14psi actuator.. so i guess i'll go with the 14?
    boost creep wasn't something i was terribly worried about anyways, but that's good to have the reassurance.
    I'm switching up turbos already because i'm already building my motor... and i'll only be out about 200 bucks to swap turbos/manifolds once my other one is sold. figured i might as well, since that turbo/manifold are the biggest chokes in my system as far as power/air flow are concerned right now.
    i was planning on running the T25 flanged manifold from ATP with a blockoff plate on the waste gate flange. I don't need the external gate now, nor can i afford it/the extra exhaust work. (my new 3" is gonna cost me enough as is..) not to mention the ladies might shit a brick if they have to listen to open waste gate dump all the time lol.. personally i think they sound sweet... but im a car nut.
    i also cant afford a full-race manifold right now. i'll worry about that after i build a different motor and go even bigger further down the road. (im sure i won't stay happy with these power levels forever)
    The Awesome™
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Or you can reach him at www.dthaus.com
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    A new wastegate cost me $40 bucks when I bought it for my full size turbo. I may have the old one sitting around at home you can have for free.
    Jun 29 2007
    Raleigh, NC
    Quote Originally Posted by 400HPA4 View Post
    that would be awesome! let me know, i guess i'll go ahead and order the bracket and then wait for word from you. call email or PM me.
    p.s. - any word from southbend on my order status? still no sign of the clutch in the mail. just get ahold of me. (i'm almost always up all night, so even though i'm eastern time, just call whenever you have a free minute.)
    The Awesome™
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    What bracket? The wastegate actuator comes with the bracket. Is this going to be for Shawns turbo? If it is, make sure you get a T3 flanged manifold because this is what he has.
    The block off plate works great but DO NOT use the gasket as it will definietly fail. You need to tighten it down with grade 8 or better cap screws (allen or triplesquare) and torque it down as much as mechanically possible, make sure you use anti sieze or assembly lube on the threads so they do not bind when you are torquing it.
    All of this stuff I am posting comes from my experience with turbo hardware over the past 4 years, evedrything I say to do is because it is a remedy for when shit fucks up.
    Apr 24 2005
    E55 AMG, CTS-V
    he is talking about buying a a 3071 internal wastegate turbo (2871r T25 housing)shawn ordered for a customer which didnt get used and is in the classifieds not the 3071r off shawns car
    ~David~
    CTS-V 9.6@148
    Jun 29 2007
    Raleigh, NC
    the bracket that bolts to the turbo which you mount the actuator to.. on the site it's a separate piece. this isn't for the turbo on shawns car, but rather for the one which he's selling in the classifieds which he said is a T25.
    edit -- read what david said above, that's the one im talking about
    I've heard not to use a gasket on those, so its good to hear the same from you. conflicting information always worries me lol. thanks for all the pointers, its stuff like this that's helping me get through everything with as few headaches as possible.
    The Awesome™
    Jul 04 2004
    992 Carrera
    Makai - Kaka'ako
    I have the bracket at home for a T2 turbo...free to you.
    Jun 29 2007
    Raleigh, NC
    sweet, i sent you a PM. thanks man!
    The Awesome™
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    like to keep your passenger side headlight lol?
    Mar 21 2006
    Lakeland, FL.
    I don't see an issue with the headlight
    I'm back bitches!
    Oct 27 2007
    In the lab
    well since itll put the turbo inlet right over the frame area, you will have to be very crafty with the TIP... to the drivers side is the mani, to the pass side is the fender, to the top is the hood and the bottom the framerail...
    Nov 12 2007
    '03 A4 1.8TQM
    Washington
    or go mafless
    Oct 27 2007
    In the lab
    Quote Originally Posted by EmoScumBag View Post
    or go mafless
    i hate you guys and your motronic 7
    Jun 29 2007
    Raleigh, NC
    yeah, i dont have a TIP or MAF at all. just a filter.
    and i looked at that... but decided i didnt like it as much as the ATP... mainly because it's 100 bucks more, and im no more sure about whether or not it'll crack (i plan to fab up a support bracket for the new turbo)
    The Awesome™
    Mar 21 2006
    Lakeland, FL.
    Quote Originally Posted by 317ssayzarc View Post
    I had to do the same thing with my Treadstone mani. If I'd known about the SPA manifold, I'd have went with it.
    I'm back bitches!
