Results 1 to 13 of 13
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Please don't be the control arms...
    So I've noticed a clunking when turning the wheel mostly and when taking off from a stop. I just changed my oil pan so I had to lower my subframe and loosen all the motor and tranny mounts so I'm thinking that's another possible cause? What do you guys think?
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Please don't be the control arms...
    Wishful thinking against things that go bump in the night. Gitur@$$ back under there and check it out. Hoping it's something else won't fix it, and we can't tell you from a bazillion electrons away in time-space.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Did you torque the subframe and stuff while under load? Meaning, you'd tighen everything first, then put the car on ramps so its on its wheels (loaded) and then torque it all down.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Oct 26 2007
    '99 A4 Avant 1.8tqm / '04 S60R
    Nashua, New Hampshire
    Best way to tell is to get under the car with a pry bar and start pushing bushings.
    Please take the effort to make me feel unworthy!
    May 19 2007
    Bay Area
    Quote Originally Posted by nebone22 View Post
    no
    SIXFIVEOHphoto
    May 19 2007
    Bay Area
    I've been driving it for I think around 600 miles since the oil pan like this. You don't have the torque specs for the mounts and subframe handy, do you?
    SIXFIVEOHphoto
    Veteran Member Four Rings ExpLlclT's Avatar
    Nov 24 2005
    1998.5 Audi A4 2.8LQ
    Bay Area CA
    check and see if the subframe is at least all bolts at 90ft lbs thats what our wheel torque spec couldn't image it being any lower but check to see if there equal control arms sound more squeeky than a clunk sound
    1998.5 Audi A4 2.8LQM is what i got.
    pm for photoshoot
    www.flickr.com/photos/explicitphotography
    May 19 2007
    Bay Area
    Ok I haven't had a chance to torque it yet, haven't been driving the car the last few days but I threw it up on ramps and checked the bolts, and it's not like they're LOOSE or anything...
    SIXFIVEOHphoto
    May 19 2007
    Bay Area
    Is there a certain way I should be aligning it before torquing it down? Also, when I got under the car the other day I noticed a little bit of oil dripping near the rear of the tranny.
    SIXFIVEOHphoto
    May 19 2007
    Bay Area
    I just noticed it also makes a small *clunk* when I turn the wheel all the way to the right, then back all the way to the left.
    SIXFIVEOHphoto
    Veteran Member Four Rings Mawhitey's Avatar
    Jan 20 2005
    99 AJL TQS
    UK
    track rod ends??
    -Mark -
    .2008cc Stroker, K04064, ME7.5, Miltek, and other goodies
    My k04064 , ME3 DBC to ME7.5 DBW build thread
    May 19 2007
    Bay Area
    Tie rod ends?
    SIXFIVEOHphoto
    May 19 2007
    Bay Area
    http://www.audizine.com/forum/showth...ght=clunk+turn
    Why are they saying CV joint in this thread? I just changed mine a few months ago, how could this be the case?
    SIXFIVEOHphoto
