    Jan 07 2007
    2001.5 S4 Stage 3 - NJ - INCREDIBLY WELL MAINTAINED *PRICE DROP*
    Few pics of the car from BEFORE I lowered it. Trying to find time to snap some more recent ones. Also lots of detailed pics of the second engine pull and all the work and maintenance I performed.
    Webshots Pics
    Unfortunately, the time has come to sell my 2001.5 Audi S4. This car has been my pride and joy and believe me if I didn't have to sell it, I would never get rid of it. Unfortunately, because of my new job, I just don't have the time to enjoy it anymore. I refused to put the 82 mile round trip to work per day on this car, so I bought an 06 honda civic to get me to work and has basically become my daily driver. On the weekends, I mainly ride my 06 Yamaha R6, which means the audi lives its life in a heated carpeted garage and rarely sees the light of day. In the last 5 months, it has seen about 130 miles of use. I just can't justify to myself to keep it, no matter how much I love the car.
    Here are the stats on the car. Currently has 91,000 miles. Car was a lease return out of South Carolina for the first part of its life. The Audi dealer in Mendham, NJ selected this car to go to their lot for sale, because of its excellent condition. This is where I purchased it, in January of 2005 with 44,000 miles. Every stage of its life has been documented from then on, and I can tell you every single thing you'd ever want to know about this car. I took it from stock to a full Stage 3 where it sits today. All work performed by Mike Moore, Uli, or me and all parts purchased by me. Car has been essentially trouble free for a majority of its life. Most of the work done was due to upgrades and maintenance, not failures. Never tracked, never beat on, only daily driven.
    Orig purchase August 2001
    Second owner, purchased January 2005 from Audi of Mendham NJ
    Car had 44K and was CPO, lease return out of North Carolina
    2001.5 Silver with Silver leather interior. 6speed.
    Cliff Notes:
    Mods- OEM K04's, Homebrew fueling [Greentop injectors, Giac X, Buehn 88mm billet MAF, TCD, AVC-R], AWE IC's, Piggie pipes, Borla 3in catback, poly snub mount, AWE DTS, phenolic spacers, Fully rebuilt and refreshed (ASP) transmission, VAST kevlar\ferramic clutch, RS4 pressure plate, RS4 engine mounts, Piggie short shifter, H&R Sport Springs, Bilstein Shocks, AWE center vent boost guage, LOTS of new parts and maintenance, probably missing a few things but everything is detailed below.
    Spring 2005-
    Giac X
    Boost guage
    Piggie pipes
    H&R Sport Springs
    Bilstein Shocks
    Borla 3in Exhaust system
    VAST short shifter
    Hard wired for V1
    61,000 miles Jan 2006
    Brand new K04 turbos and hardware
    Brand new K04 inlets wrapped with heat tape
    AWE intercoolers
    Greentops
    TCD installed
    Beuhn 88mm billet MAF
    Air box modified to work with MAF
    RS4 accordion installed
    Phenolic spacers
    VAST Kevlar\Ferramic clutch RS4 pressure plate
    Throw-out bearing
    AVC-R installed
    After run low temp thermostat installed
    Fan switch replaced
    Thermostat replaced
    Timing belt, water pump, tensioner roller, idler roller, AND belt tensioner replaced
    Poly snub mount
    AWE drivetrain stabilizer
    Bipipe installed
    Stage 3 was tuned with lemmiwinks by Mike Moore, good ever since. 24psi peak, 21.5 to redline.
    Summer 2006-
    Front brakes- Hawk HPS
    November 2006
    Water pump failed, timing belt and water pump both replaced with OEM parts from dealer
    Winter 2006-2007
    PZero Nero M\S 225\45\17
    Feb 2007 - May 2007 83K
    Transmission rebuilt by ASP - first and second gear replaced, slider, syncros, seals. Complete refresh.
    Both cam tensioner seals replaced
    Both cam plugs replaced
    Cam seals replaced
    Both valve cover gaskets replaced
    Both front wheel bearings replaced
    All front control arms replaced
    Both front tie rod ends replaced
    Both front sway bar end links replaced
    Both rear sway bar end links replaced
    RS4 engine mounts installed
    Upper oil pan power washed and resealed
    Lower oil pan power washed and resealed
    Intake manifold ported and polished
    Intake mani reinstalled with new gaskets
    All front inner and outer CV boots replaced, joints cleaned and inspected
    Every bolt torqued to spec, threads cleaned
    Flywheel and clutch inspected, reinstalled with new hardware to spec
    Turbos inspected, great shape
    New 710n's
    Every hose inspected, hose clamps checked
    Pressure tested
    Winter 2007\2008
    Clutch slave went and was replaced with upgraded OEM unit
    88k-91k all highway, due to new job.
    Always changed with mobil 1 0w40 at 5k with OEM filter
    OEM air filter replaced every 15k
    Plugs changed every 8-10K with NGK coppers
    Coolant always changed with distilled water and G12 when drained
    Known problems that will be taken car of before sale:
    Stock wheels need some refinishing. Will sand out imperfections and repaint\clear them.
    Rear brakes need to be done. Already have the pads, just need to switch them out.
    Plugs need to be changed, already have them and can do them asap.
    Auto dim in the rear view has gone bad, I am shipping this out and having it replaced very shortly.
    known problems:
    Due to the greentop injectors, sometimes the idle is a little shaky and due to their spray pattern (this is widely known) they can throw occasional misfire codes. I always just clear them, this has never caused any other issues. I've tried to track down another source of the misfire but everything else is perfect. It really is just the injectors spray pattern.
    center display, most pixels are shot as with most S4's.
    Brakes have some deposits on the rotors from sitting in the garage so often. Pads need to be re-bedded to take car of some vibration when stopping. I will let the new owner handle that.
    Only major issue: About two years ago the car was keyed on the drivers side. It was taken to a detailer to be buffed out. 80% of this scratch was able to be closed up, the rest was touched up and buffed, with some light wet sanding. I've just lived with it for the last two years. To be properly fixed, it would probably need some paint and blending.
    **Asking $18,500 as is, negotiable.**
    **Asking 16,000 negotiable as bare Stage 3 (Stage 3 minus, ask for parts list)**
    Pics in post below. Any other info available upon request. Thanks for looking.
    Email [email protected]. Located in New Jersey 08731.
    Jan 07 2007
    Re: 2001.5 S4 Stage 3 - NJ - INCREDIBLY WELL MAINTAINED
    http://good-times.webshots.com/album...ost=good-times
    Some pics here. Pics of the last engine pull and all of the work done in 2007. Few pics of the car. Need to take some updated ones.
    Jan 07 2007
    Bump for price drop. Will sell as bare stage 3 if you want for much cheaper, see original post. Email or PM for questions.
    [email protected]
    Jan 07 2007
    bump, updated price and info
    Jan 07 2007
    bump. any interest? PM me or email with offers or questions.
