Results 1 to 40 of 57
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    AEB-VR6 Throttle body swap
    I recently got some throttle codes and went into limp mode, which was nice for gas mileage, but not so great for fun factor.
    so i decided to upgrade instead of just replace.
    i contacted 034 and ordered the adapter plate and VR6 OBD2 throttle body.
    i was planning on it being a direct bolt on, buuuuuuuuuuut . . .
    the adapter cocks the TB 45 degrees, and the bottom bolt hits the ear on the intake manifold for the support bracket.
    so i went the hard(right) way and used some MB trans pan aluminum bolts(ones for the new magnesium pans) and cut em off and re drilled new holes and milled the center bore per the gasket.
    i bent the cable bracket a little towards the TB and removed the plastic holder for cyl 1 & 2 injector connectors and ran the cable through that spot.
    here is where i can't decide what to do.
    the OEM AEB throttle doesnt use the two large vacuum ports that the VR6 has.
    anyone know of an aesthetic way to block them off, or something i could use them for?
    right now i have a length of hose looped between the two, tucked under the manifold.
    i must say, the guys at 034 were, as usual, very helpful. the whole transaction was carried out leisurely on AZ pm's. the adapter, hardware and gaskets were all top notch.
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Re: AEB-VR6 Throttle body swap
    You could weld them shut? or get some vacuum caps.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Those are not vacuum ports. They are just the inlet/outlet of a U for running coolant thru the TB housing.
    Senior Member Three Rings jlien08's Avatar
    Jun 28 2007
    98.5 A4 1.8TQT, 01 ZR2 Blazer
    Woodbury, MN
    liquid cooled TB? WTF?
    1998.5 Audi A4 1.8T Quattro Tiptronic - MagnaFlow - Bilstein - Neuspeed - EvoMS - 034MS - LLTek - FMIC - VDO -
    Jul 07 2004
    socal
    Quote Originally Posted by jlien08 View Post
    You mean liquid heated. It would be hard to cool the TB with coolant seeing that once the engine is at running temps the coolant is going to be hotter then the TB or the air flowing thru it.
    Basically it was designed in the same way the oil/coolant heat exchanger, allowing the coolant to get the oil up to temp quicker.
    Jun 28 2007
    Woodbury, MN
    makes sense. i haven't seen that before.
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    They are vaccuum ports.That is an OBD-II 2.8 V6 throttle body MIke,not OBD-1 VR6 like yours...
    If anyone wants a conversion kit let me know.We have 10 brand new 2.8 V6 throttle bodies in stock @ $225US each
    Established Member Two Rings VTECCURED's Avatar
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    OffRoader:
    any comments on this TB upgrade? Do you have BT setup, or stock?
    Have you noticed any increase in response or power thru the powerband?
    thanks
    JOHN
    Forum Moderator Four Rings docurley's Avatar
    UK London
    How this all work and are there any gains to be had and does it work on ndbw cars, oh and why did you have problems fitting this if its a direct replacement?
    Avus Audi RS4 2007 |Stock| Black optic | intake pipe| Android RSN-E| carbon knob Handbrake Airbag| LED interior & puddle lights
    Jul 07 2004
    socal
    Quote Originally Posted by Issam@034 View Post
    Wow that is weird, seeing that the ports look exactly the same. oh well seems I learned something new today. Just an odd place to put vacuum ports.
    Well I guess all he had to do was blow thru the port and see where the air came out.
    To block them off all he needs to do is visit an autoparts store like Kragen and buy some vacuum covers, just make sure to clamp them down good since they will get boost pressure.
    Quote Originally Posted by docurley View Post
    Gains are most likely going to depend on how much air flow you are trying to force thru the TB, so the higher the hp you are making the more gains you will see.
    Oct 17 2004
    Columbia, SC
    i noticed a big difference in throttle response.
    i am only on a k04 so no real power gains.
    but off idle throttle and part throttle driving are much easier now.
    and i havent found any caps big enough for a clamp to fit on.
    Feb 26 2006
    Earth
    Yup
    Quote Originally Posted by offroader1006 View Post
    There is a power gain to be had....I would wager 4-6whp at least.If you look @ the SIZE of the AEB throttle plate you would laugh.The DBW models come with a larger throttle body but most people dot mention that.
    Regardless the 2.8 V6 throttle body has a 65mm throttle plate.More than enough!
    Jul 07 2004
    socal
    The black ones in this picture aren't big enough?
    BTW JCWhitney sells a kit with 50 caps
    Color-coded vinyl. Includes 10 each of the following sizes: 1/8", 3/16", 1/4", 5/16" and 3/8".
    Feb 26 2006
    Earth
    DBC OBD-II throttle bodies BACK in stock.Who wants?
    Nov 07 2007
    98 audi a4 quattro
    PERTH AMBOY, NJ
    Ok... ill take one...
    with the adaptor...
    Should i go through the website.. or just through u?
    Does it matter whether or not its a v6 or vr6 or even a s4? Is there one bigger then the other ?
    Thanks Issam
    JOHN
    Feb 26 2006
    Earth
    Quote Originally Posted by VTECCURED View Post
    with the adaptor...
    Thanks Issam
    JOHN
    S4's have a DBW throttle body.
    The V6 and VR6 DBC throttle bodies have different vaccuum breather ports.
    Check your pm.
    Feb 26 2006
    Earth
    Bump for High flow Intake manifold porn...sorry to those who missed out on this.5 of these will find homes tomorrow morning
    Oct 30 2006
    B8 A4 Avant 6spd
    Loving the intake manifold porn, details on gains etc?
    -18 718 GTS
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    issam that motor looks damn sexy
    Sep 11 2007
    Dirty Jersey
    dry sump eh?
    Nine [O_O] Eight Tuning
    custom work, fabrication, bumper shaving, fender rolling, plastic & fiberglass fabrication and repair
    Turbo charged and lowered for better grocery getting :screwy:
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Isn't that a transverse 1.8T?
    I just got all sorts of confused trying to figure out how that would fit a Mk4 car....
    Nice dry sump though.
    Have you guys done anything with porting stock AEB intakes? I'm messing with a spare one I have around. There's a handful of places that need some attention inside of that thing. I should be bolting it up tonight, I'll see if it makes a difference.
    Established Member Two Rings DuviVr6's Avatar
    Jun 03 2008
    99.5 Avant 1.8TQM
    OKC, Oklahoma
    this TB used here is from what generation of VR6's?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    That is project 2220 and it is not transverse.
    Jim
    I Do Werk.
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    It all depends on what your car is. If your a DBC then your tb will be from the 12v vr6 wich is dbc, if your dbw then it will come from a 24v vr6 which is also dbw.
    Feb 26 2006
    Earth
    Quote Originally Posted by onemoremile View Post
    So much for deterioration
    DBC upgrades = 2.8 V6 Passat throttle body or VR6 OBD-II DBC throttle body.
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    What is the size of a stock ATW throttle body? Just wondering....
    Feb 26 2006
    Earth
    Quote Originally Posted by VTAudiA4 View Post
    ATW is DBW? if so then its approx 58mm
    Jul 07 2004
    socal
    Yes ATW is dbw, thats the 2000.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    2200? like 2.2L of turbo spoolin fury?
    I realized later that I wasn't thinking correctly. Once I had my car in the "service position" I understood it more.
    Feb 26 2006
    Earth
    Quote Originally Posted by djwimbo View Post
    You do or dont have a VR6 throttle body?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    I do not have a VR6 throttle body. I do have a stock AEB nDBW Throttlw body with about 5mins worth of porting done by yours truly.
    Why do you ask?
    This little throttle body...
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    I have an AEB DBC, can i use the TB of an AAA VR6....?
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
    Aug 16 2007
    Buffalo NY
    So being the dbw tb's are larger can you mod one to be dbc?
    Feb 26 2006
    Earth
    Quote Originally Posted by leon View Post
    Depends on the year of the VR6.
    You need an OBD-II Throttle body from the VR6.
    Quote Originally Posted by slopoke View Post
    I wish but not by a long shot.One of the biggest advantages of DBW is the ability to go Mafless and as large as an 80mm DBW throttle body for peanuts.With DBC you are pretty much stuck @ 65mm unless you go standalone (which most will not do.).
    Nov 28 2004
    This is an ODB 2...?
    A4 1.8T QUATTRO
    Jan 25 2006
    A4 2.0T
    MD
    Wrong AGAIN!
    Jul 07 2004
    socal
    Quote Originally Posted by Don Supreme View Post
    Wrong AGAIN!
    LOL, actual I was 50% right since thats what they are on my OBD1 VR6 TB and if you didn't notice that was pointed out 5 months ago.
    But hey thanks for showing us how slow you are.
    Feb 26 2006
    Earth
    Yup thats OBD-II
    Wrong AGAIN!
    He is actually right.SOme of the OBDII throttle bodies do have coolant feed and return lines as they sat over a hot exhaust manifold on the VR6.The idea was to stop the throttle body for heating up and "shutting".
    Nov 28 2004
    A4 1.8T QUATTRO
    Senior Member Three Rings b5a4gt28's Avatar
    Oct 15 2007
    97 B5 BAT A4 2.0 HTA30R, 01 STG 3 S4, 04 B6 A4
    Telford Pa
    Any pictures of the tb setup on the car? I am curious to how the tb sits on an angle.
