    2009 A3 2.0T Quattro S-Line
    Vancouver, BC Canada
    How to get the Exhaust Housing off from the turbo??
    I am trying to access to the turbine, therefore i need to get the exhaust housing off. I got those 5-6 bolts off already, is there anything to hold the housing intact? Or do i just simply knock it apart?
    Please let me know again, thx very much in advance~
    IG:@steadysupreme
    Pics&Detail
    Feb 27 2005
    North Wales, PA
    Re: How to get the Exhaust Housing off from the turbo??
    you don't need to take the bolts off. just loosen then and move the little moon shaped things away from the recessed part and snug the bolt so it doesn't move. when all the holders are out of the way just knock it with a mallet.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Dont be afraid to knock it off. Just try to do it as straight as possible
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    it is not pressed in right?
    IG:@steadysupreme
    Pics&Detail
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    nope, it is just old and used, so it is on there tight now. Give it a couple good smacks with a dead blow or something
