Page 1 of 4 123 ... LastLast
Results 1 to 40 of 133
    Veteran Member Four Rings VonPooper's Avatar
    Feb 10 2007
    4RUNNER
    CXracing Intercoolers $399? Anybody have them?
    EARTH PEOPLE.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: CXracing Intercoolers $399? Anybody have them?
    most of the fmic's you see on this forum are from those guys ... i hear those are better than rs4 but nowhere near as good as the awe/er setups
    Veteran Member Four Rings lrg8683's Avatar
    Nov 02 2005
    S4
    VA
    i'd also like to say FCUK cxracing.
    -Luis
    Veteran Member Three Rings o3spec's Avatar
    Feb 07 2007
    Dover, DE
    ^^and y?
    Feb 10 2007
    4RUNNER
    hmmm better than the rs4 smics...
    EARTH PEOPLE.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    i guess a good question is, for everyday driving would you benefit anymore from ER/AWE compared to these?
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    I have them. They are better than stock by far and have done good on hot days. That said they are definitely not bolt on. You have to take the mounts off your old ic's and mount them on the new ones. Plus there are no directions so its a trial and error trimming of your lock carrier. They have a fairly rough cast on the end tanks that I had to clean up a little with the dremmel. The welds look good though and they feel solid. I would consider your ultimate power goals before buying them. Up to a mild KO4 car they should be good, but if you are going for anything more powerful I would look awe or er for ic's.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 11 2006
    Boston
    they are definitely on par with AWE.
    for about 150 dollars cheaper you can piece together that exact same kit. just buy their core and find some decent piping.
    Stage 3+ RS6's
    May 04 2004
    00 BB S4
    York, Pa
    Quote Originally Posted by ThirdStrike View Post
    Where is your data?
    The core itself cools betters then awe and er setups.
    It is the core JHM uses that many of us are buying.
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Dec 11 2006
    Boston
    It actually doesn't do a better job than ER's. But that is neither here nor there.
    Stage 3+ RS6's
    Nov 02 2005
    S4
    VA
    Quote Originally Posted by o3spec View Post
    ^^and y?
    sh*tty customer service.
    -Luis
    Active Member Four Rings ///M3 TO S4's Avatar
    Feb 09 2007
    Charlotte, NC
    guess the search button is broken today?
    Learn MANTH America!
    Stage 3....blah...blah...blah... : Sold
    Now: E36 M3 TURBO (GT35R)
    May 04 2004
    00 BB S4
    York, Pa
    Quote Originally Posted by deb38 View Post
    Lets keep this clean , but how do you figure?
    It may not do 100% as well, but it doesn't do any worse.
    And you can't argue $$/performance between the two :)
    00 S4 BB Stg3
    Senior Member Two Rings Tokin's Avatar
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    98a4 did you even click the link? The OP is asking about CXR side-mounts - not the popular front-mount that everyone knows about. AFAIK JHM is not using these side-mount cores for their FMIC kit.
    Feb 10 2007
    4RUNNER
    think im going to buy these puppies.
    EARTH PEOPLE.
    Active Member Four Rings DxC's Avatar
    Nov 16 2006
    Boston
    Quote Originally Posted by 98a4 View Post
    i argue this with a friend all the time. ER vs ebay fmic.
    if you look at IAT data, the delta of the ER IATs stays flatter longer over the range of a FATS pull. something like 0-5 delta, with FMIC, its 0-10 delta.
    also, FMIC has more pressure drop with that piping (though not quantifiable since there are no probes to measure that metric)
    i would say that ebay FMIC is SLIGHTLY better in back to back runs and resisting heatsoak. i also think a eletric fan with a switch is a good idea for FMIC so you can pull air in through the FMIC by turning it on
    1999 Black A4 Avant
    2000 Nogaro S4 Stage 3
    2001 Nogaro S4 Stage 3
    2000 Black S4 - under construction Stage 5?
    2001.5 Santorin S4 Stage 3
    2001 Black S4 - parting out/scrap
    2001 Black Burnt S4 - shell gone, drivetrain remains
    Dec 11 2006
    Boston
    ^what he said...
    but yeah, you really can't argue because it such a good bang for the buck.
    as for customer service...well it's a side show ebay business, what do you expect for $80? you don't really need customer service either, there are so many write-ups and answers on the forums.
    Stage 3+ RS6's
    Nov 28 2007
    Audi S4 and Tiburon
    Daytona Beach
    Anybody besides STi have any input on the OP's question? Since this has nothing to do with FMICs...
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    These Are About Cxracing Side Mounts Not Their Fmics!
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Feb 10 2007
    4RUNNER
    EARTH PEOPLE.
    Veteran Member Three Rings MiniRS4's Avatar
    Aug 11 2005
    customer servicio... MUAHAHHAHAHAHAHAHHA... (pause) MUAHAHHAHAHAHAHAAHAHAA...
    what the shit are you talking about? what do you think this is...? (CS.... lol, meh)
    Sep 11 2007
    00 S4 M6, 03 RS6
    Washington State
    I bought a set of these, but I'm making my own FMIC kit for the single turbo setup. Anyone want mine for $350 Shipped? PM Me, they are new, never installed.
    Veteran Member Three Rings fatezero's Avatar
    Feb 12 2004
    Orange County, CA
    Just wanted to know if anyone had any logs to show with the SMIC's from CXRacing?
    2021 C8 RS6
    2001 S4 Avant 3L Tial 770
    2004 Allroad 6spd EPL Stg 3 SOLD
    2001.5 S4 Avant AWE/GIAC Stg 3 SOLD
    2011 S4 6spd Suzuka Grey Pearl with GIAC Stg 1 SOLD
    2006 S4 Avant SOLD
    2001.5 A4 Avant K04/Jeff Moss Hammer File SOLD
    2001 Porsche 996 Turbo - SOLD
    2001.5 S4 AMS Stg 3 - SOLD
    Dec 03 2007
    Potomac, MD
    they are junk...
    either get their FMIC or get expensive SMICs that will do their job
    Feb 07 2007
    Dover, DE
    Quote Originally Posted by lrg8683 View Post
    i know for a fact thier customer service is better then awe or ecs. i get a response back from cx within a couple hours. it usually takes a few day for awe or ecstuning to return a call. so don't talk about somthing you don't know anything about
    Apr 13 2008
    Tennessee
    Re: I'm silly
    fine, he'll talk about your mom instead, b/c that's a subject that everyone knows something about...
    I am obviously kidding and have nothing to add to this thread. carry on
    Feb 07 2007
    Dover, DE
    Re: I'm silly
    Quote Originally Posted by quickaudi View Post
    LOL right on! this thread has nothing worth while in it anyway.
    we are really beating a dead horse here with this whole cxracing bs. everyone on here just doesn't want to admit that for a fraction of the cost of most intercooler kits for the b5 s4 you can get a intercooler setup from a mass produced sub quality company. but..... it still proforms aswell as most much more exspensive kits. even if its not the best quality (which i have NEVER had a issue) i could still buy 3 of these kits for the price of 1 from anyother company awe, er, rs4. im not like most of the spoiled brats on this forum and i accually have to work my ass off to support my family, take care of my house, and support my car habit. so ill take the $350 intercooler kit from china that works just as good if not better then most other $1000+ kits.
    sorry i just had to vent alittle
    Feb 12 2004
    Orange County, CA
    Re: I'm silly
    Hey, I love your statement and I am all about saving $$ but HOW do you know "works just as good if not better then most other $1000+ kits"?
    Do you have any IAT logs from Vag at least? Dyno maybe? Just curious...anyone?
    2021 C8 RS6
    2006 S4 Avant SOLD
    Nov 13 2007
    denver
    Re: I'm silly
    Quote Originally Posted by fatezero View Post
    Agreed! I hate the time wasting arguements about products without data or experience. I will never follow the forum mentality of paying more to get more either though. I have read countless posts on how great H&R coilovers are, and at the same time others are reporting blown shocks left and right. Yet after all of the bad H&R shock issues, people still insist on these instead of other brands that are looked down upon due to not being endorsed by the forums. I know this isn't a suspension argument, but I think more people should do their own thinking and use the forums for facts not popular opinions. On another note, I would also like to see some data on these side mount intercoolers. I would be surprised if they were better than ERs, but they have got to be better than stock.
    Feb 07 2007
    Dover, DE
    Re: I'm silly
    i could do some logging later tonight but it would do you no good if your interested in the smic since im running cxracings fmic. im just trying to defend cxracing from all the haters.
    Feb 12 2004
    Orange County, CA
    Word... yeah, I was looking into SMIC but I dont think they will work for me as I need to lower my IAT's down a lot. It's got to be ER for me I guess.
    2021 C8 RS6
    2006 S4 Avant SOLD
    Registered Member Two Rings
    Feb 24 2008
    2000 S4, 2008 Nissan Quest
    RI
    I would love to see some data as well, if only to have a bigger pair of boots on when I kick myself for buying RS4 intercoolers (well they do come with APR pipes).
    Someone told me the RS4 intercoolers were made to go with the car, and the pressure drop may be too great with others. He is notoriously conservative about modifications, though, and believes strongly in the Audi engineers.
    (dealer tech, can you tell?)
    jb
    Black 2000 S4, black OZ Ultraleggera 17's, Kumho Ecsta-SPT, Milltek 3", Unitronic 1+ flash, GIAC tip flash, SMOKED turbos being replaced with K04s, also RS4 intercoolers, APR hoses, APR bipipe.
    Senior Member Three Rings Caddy7's Avatar
    May 26 2008
    Silv -00 S4 Tip & -01 A4 2.8L
    Riverside, CA
    Bump..
    Anyone got any more data/experience on these?
    Nov 13 2007
    denver
    2nd!!! I would love to see some logs instead of speculation and butt dyno testemonials.
    Feb 10 2007
    4RUNNER
    indeed my friends.
    EARTH PEOPLE.
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    i have aset of these smic's but i have not had the time to install them i was thinking about smoothing out the tanks on them cause the are very rough castings, but i am the type of person that polished the inside of my apr bi pipe
    Jul 06 2007
    San Jose, CA
    They have done well in the summer heat. I lent my vag-com to my uncle so I can't do logs until he comes back.
    Veteran Member Four Rings Rapter's Avatar
    May 01 2004
    2009 honda CRV
    Jersey
    I have them to, but didn't do any logging before or after install to see how much they really do. I guess I can ask my boy to help me do some logging since the vag that we got is on his laptop.
    Feb 17 2004
    Sterling, VA
    The CX Racing SMICs are not going to out perform the AWE SMICs.
    Stock = Core Size 8.5" X 6.750" X 2.688" = 154.244 cu/in
    RS4 = Core Size 7.125" X 9.125" X 2.5" = 162.540 cu/in (8 cu/in larger than stock)
    CX Racing = Core Size 8" X 7.5" X 3.5" = 210 cu/in (56 cu/in larger than stock)
    AWE = Core Size 8.5" X 8.560" X 3.5" = 254.660 cu/in (100 cu/in larger than stock)
    The CX Racing cores are obviously larger than the RS4 cores but, my feelings on the topic were:
    1. AWEs were larger
    2. AWEs had nicer fit/finish
    3. AWEs had shrouds, mounting brackets and all hardware
    I hate buying things twice so, I wanted to buy the better hardware right off the bat and not screw around trying to save money.
    Brett - Moderator
    Issue?: email me.
    _____________________
    Stage 3 2004 A6 2.7T 6M
    Nov 13 2007
    denver
    Quote Originally Posted by 02alltoad View Post
    Is the inside of the tank rough? Could you post some pics? I have from time to time thought about buying them. The cores look to be better than the RS4s and the IPPs, but logs are the only data that is proof of that.
