Results 1 to 21 of 21
Thread: Stage III?
    Senior Member Two Rings mpower1's Avatar
    Mar 17 2008
    00 S4 stg 3-/ E34 540/6
    Ga
    Stage III?
    Got a question for you guys with stage 3 setups. I'm on the verge of becoming a stage 3 s4 owner and a little concerned about reliability for dd. I'm currently a Bmw enthusiast but decided to do a little change for a bit.any input would be great. Thanks.
    Veteran Member Four Rings S4evr's Avatar
    Mar 07 2007
    Belmont, MA
    Re: Stage III?
    technically all the weak links motor based are replaced when doing stage 3. if you plan on driving your car aggressively to fully use the capabilities of the stage 3 power, then other components may start to see failure. i.e. tranny/motor mounts, snycro's, excess oil temps etc. if you do general maintenance like any other car, and keep driving habits within reason it will be more reliable than stock.
    ThorTechnik.com
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Re: Stage III?
    stick around this forum. you will see the various issues s4's have. they can be either very reliable or not reliable at all. mine is one of the amazingly reliable ones (and im stage 3) some people will not say the same all depends on the car.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Stage III?
    ^^ same. my car is great. VAST stage 3, I dont usually hit boost on my drives, but every so often i will get on it just in a gear or two. great daily driver with SHITloads of power.
    Apr 05 2007
    Re: Stage III?
    Quote Originally Posted by mpower1 View Post
    just replace your o2 sensors, EGT sensors, N75 sensor, brake booster vacuum lines, new fuel filter, buy ECUx for logging, pressure test once a week (and fix/replace parts with any leak), make sure spark plugs are right type and gap, install injectors correct direction depending on injector, replace all worn/brittle vacuum lines with silicone, buy good clamps for everything.
    then it will be solid. unless you have one of the random 'possessed' S4's.
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Re: Stage III?
    Quote Originally Posted by exorcet View Post
    How do you know if your injectors are positioned right? I get random miss-fires but I never get a flashing CEL. Could this be from the injectors?
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    Dec 06 2007
    Calgary, AB, Canada
    Re: Stage III?
    Could be, which injectors do you have?
    Veteran Member Four Rings Audi S4 Turbo's Avatar
    Feb 11 2005
    E46 Bmw M3
    Encinitas,San Diego,California
    Re: Stage III?
    Is this all Adam?
    -Justin
    EVT 700 997 Turbo 6MT
    TDI A3 Prestige
    Registered Member Three Rings updaboost's Avatar
    Mar 08 2006
    S4, 997 4S & S2000
    Chicago
    Re: Stage III?
    Quote Originally Posted by alias747 View Post
    me too...
    01.5 Nogaro Blue S4, 6sp
    VAST Stage 3 - Piggies - Neuspeed - RS4 Clutch - Samco - Hyperboost DVs - AMS TBB - Stratmosphere SS - Flik Justice/SSR Comps - Vogtland - AWE DTS - H-Sport Sway
    360whp/400wtq
    Feb 19 2007
    La Crescent, MN
    Re: Stage III?
    Quote Originally Posted by The_Jerbel View Post
    Well I am supposed to have the AWE fuel kit and my injectors have green tops. So I am assuming I have the Bosch 440cc injectors. I believe that is what comes with the AWE kit. Thanks!
    Apr 05 2007
    Re: Stage III?
    i *think* green tops should have connectors facing the fenders. but let someone else confirm that before you go twisting your injectors around
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    Re: Stage III?
    I've always driven BMW's and I just recently sold my M Roadster for my 2000 Audi S4 awe stage 3 and I haven't regreted it one bit. This car is amazing.
    Senior Member Two Rings sweetmeat's Avatar
    Mar 03 2008
    '18 S4, '16 Q5 TDI
    Collegeville, PA
    Re: Stage III?
    according to the install instructions on the AWE website, this is true.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Stage III?
    Is the entire body of the injector green? (green giants)
    or
    Is the bottom black and the top green?
    Senior Member Two Rings readimag's Avatar
    Jun 28 2008
    2000 s4, 2011 acadia, 2010 s4
    Savannah, GA
    Re: Stage III?
    mine is just green on the top like a top hat
    2000 s4
    Dec 06 2007
    Calgary, AB, Canada
    Re: Stage III?
    Those are called green tops.
    Position them so that the electrical connectors are facing the fenders.
    Feb 19 2007
    La Crescent, MN
    Re: Stage III?
    I am pretty sure those are the kind I have too, I will have to run out and check once it stops raining... What affect does the positioning have on them? Do I just twist them in place or is there a procedure I need to do? Thanks!
    Dec 06 2007
    Calgary, AB, Canada
    Re: Stage III?
    Just twist them in place. It affects the angle of the spray pattern into the cylinder.
    Feb 19 2007
    La Crescent, MN
    Re: Stage III?
    Ok I just went out and looked and none of mine are facing the fenders. I turned a few of them but they are kind of tough to get to. And the top 2 don't look like they are even going to be able to face the fenders becuase there is a vent line on the top of the valve covers that looks like it will be in the way.
    Dec 06 2007
    Calgary, AB, Canada
    Re: Stage III?
    Get them as close as you can.
    Active Member Three Rings antoanS4's Avatar
    Jul 05 2008
    miami
    Re: Stage III?
    Hi guys i just bougth stage 3 for my 01 s4, they just started today, and before they install the turbos, have the vast K04, why should i do,stay with the RS4 K04 or get the RS6 K04
