Results 1 to 25 of 25
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    How good is South Bend Stage 3 OFE HD?
    I'm looking into using this clutch with stock dual mass flywheel on my 2001 1.8T for daily driving with occasional 1/4 mile and track time. I want to be able to drop the hammer sometime and actually lanch the car w/o issues.
    Future plans involve 2871R at the most.
    I'd like to hear personal experience and feel and performance of this clutch.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: How good is South Bend Stage 3 OFE HD?
    Stage 3 wont be able to hold a hard launch with a well tuned 2871, but it might be able to handle normal driving.
    BTW I sent you a PM.
    Feb 27 2005
    North Wales, PA
    it will hold the power but i think launching will be an issue.
    97 A4 2.0TQM
    Rochester, NY
    didn't one or two people on here separate the friction material from the clutch when launching with the stg3?
    Jan 21 2006
    6MT BT Avant Ti
    RI
    I also plan to toss in a B5 2.8 Quattro transmission to replace my B5 1.8T Quattro transmission.
    Feb 27 2005
    North Wales, PA
    thats just gonna increase the load on the clutch.
    Jul 07 2004
    socal
    Quote Originally Posted by pac1085 View Post
    Yes, but the stage 3 for the DMFW uses a unsprung iron disk vs the OFE style sprung disk for the LWFW.The people that separated the friction material from the disk were using the OFE disk. This is why I suggest the SB stage 5 for people that plan on drag racing.
    I can get a modified SB stage 3 kit for the DMFW that basically has the clamping pressure of a SS prssure plate. I mainly sell those to 2.8 guys that are making too much power for the normal stage 3 and SB doesn't offer a stage 4 for the 2.8.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Stage 3 for the 2.8 is rated much higher (430 ft*lb) than Stage 3 for the 1.8T (300 ft*lb).
    Might not be a strong clutch after all. I have no slipping at all on my stock one with 128k miles unless I launch it on a hot day.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    wanna take my 2.8 lol?
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    Dont try to tell yourself that you only need a stage3 and wont need a stage 5 because i tired, and here i am 6months later with a stg5 sitting next to me to support my build.
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Quote Originally Posted by 317ssayzarc View Post
    We'll see. I seen that thing hit 70 mph in 2nd so me likey.
    So I guess Stage 3 is weak sauce.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    go with the sb stage 5, I have the sb stage 4 OFE. the stage 5 will take heat better than the stage 4 because of the organic side on the stage 4.
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Jul 07 2004
    socal
    Quote Originally Posted by nebone22 View Post
    Yeah but it just takes longer to get up to that 70 mph then if it had a 1.8 trans in it.
    That is because the 2.8 uses a 240mm clutch setup while the 1.8T uses a 228mm. So the same clamping force and disk can handle more power because it is further from the center of the flywheel.
    The stage 3 and stage 4 for the LWFW use the same disk but the SS presssure plate has more clamping force which is why it is rated at 450 vs the HD pressure plate stage 3 at 300.
    So looking at that the modified stage 3 with the higher clamping force should bring the rating up closer to 400.
    Senior Member Three Rings bernB5's Avatar
    Nov 13 2007
    Long Island, NY/ Hartford, CT
    I run the Stage 4 OFE on my 30r setup and it's handled the power and a few launches at 25 pounds. We'll see how it holds up soon though, my car will be running much better. Andy assured me it would fit my needs and goals etc..
    Old: 97 30r'd A4 ---> headaches
    New: Evo IX MR ---> 354awhp/349tq and couldn't be happier
    BERNSTEINphotography
    Jul 07 2004
    socal
    Might hold up on street tires, but if you put some sticky DR's on it might not hold.
    Nov 13 2007
    i have a feeling... that with 130k on the axles and driveshaft, 60k on the tranny and 2k on the clutch, something else will surely break with some sticky dr's before the clutch goes.. we'll see. if it can't handle it, i'll go back to andy @ southbend and tell him I'm not happy with the clutch he recommended and stands by and I'll upgrade.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    So we know the SB Stage 3 OFE won't take launching well on Quattro, but how about FWD?
    Jul 07 2004
    socal
    It would be fine on a FWD car since it then has a higher rating since there is less load on the driveline on a FWD car.
    Quote Originally Posted by bernB5 View Post
    Then please explain how my OEM driveline holds up to launching with 600whp on DR's. 3 of the axles I have on my car and my driveshaft came on my car when I bought it new in 2000 and they have about 130k+ miles on them with 8 years of drag racing abuse. The 1 axle only got replaced because the CV broke.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Only way I can explain it that Audi gave it Strenght rating of 4 or more which is very high and that your car has good bearings and hubs not causing vibration or wabble which would normally kill axles. If the launching shear won't kill them, then normal driving won't come close.
    After seeing the Launching 101...
    Nov 13 2007
    I thought you had less miles on your car and was never aware of your part-replacement history.... I guess that's good news then. I'm really not worried about the clutch, the worst thing that can happen is it doesn't hold the power. oh well.
    Jul 07 2004
    socal
    Well the axles tend to snap when you get wheel hop during a launch, remove any wheel hop and you really decrease the chance of a axle snapping.
    I put 90K miles on the car in 24 months when I first bought it. Right now the cluster reads 125,497 miles, but the car has been driven without the cluster plugged in.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Now it adds miles 1/4 mile at a time.
    Jul 07 2004
    socal
    Actually 1 mile at a time.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    How different is clutch engagement with the South Bend clutches? Different than stock as in pedal travel?
    Jul 07 2004
    socal
    Most of the aftermarket clutchs put the engagement between the middle and bottom.
