Results 1 to 8 of 8
    Active Member Two Rings Audi Mind Trick's Avatar
    Oct 27 2006
    Federal Way, WA
    Secondary Air Injection pump
    Anyone know of a way to test this to see if its working properly?
    2000 A4 1.8T Quattro Ebony Black Mica | APR 1.0 bar ECU chip | Forge 004 BOV | Borla Exhaust | Snub Mount | Drop in K&N | 20% Window Tint <--it actually adds 5hp
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: Secondary Air Injection pump
    Start you car up when the engine is cold like morning before work and listen for a spool, electric motor sound. Thats when it would kick in.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Senior Member Two Rings dynomike's Avatar
    Jan 26 2008
    los angeles
    yeah my car threw that code last week. i was quoted 400+ for parts alone....
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Its not something that the engine needs. It can be just removed and open ports can be blocked off. It will throw a CEL and stay on.
    Active Member Two Rings Big-Pat's Avatar
    May 28 2007
    St. Paul, MN
    Before you go and replace it, take the flexible hose off. If water comes out you have a bad combi(sp?) valve. (the pump could still be ruined)
    Registered Member Two Rings
    Jul 17 2007
    Langhorne, PA
    i have a cel for this as well. we replaced the rubber hose which was very worn out the the cel has stayed on.
    what is the next step to try to diagnose here? hoping to find the problem before i just start throwing money at it.
    thanks...
    bryan
    -1994 Black Supra TT 6MT - Tucked, Big Single, 600+ whp (Pic)
    -2003 Blue WRX with complete 2007 STi Engine/Drivetrain transplant (Pic)
    -2000 Audi A4 1.8T Quattro - The DD
    TriStateTuners.com | Bryan Troll Photography
    Apr 25 2007
    millersville, maryland
    My SAI pump has been unplugged for about two months now, due to it shorting out on me. The pump is what helps with the functionality of your catalytic converter(s); although the possible harm that can be done without it i am not sure of. The combi valve on the other hand, if there is water in the pump lines, can be the cause of failure. I have heard that the valve is a little bit harder to replace though. I've been to a few pull your own parts junkyards around my way and found i can get the pump for about $30.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    It warms the CAT up when you start the car in order to reduce emissions. I pulled the pump out and I have a CEL, but F-it, itll go back in one day.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
