Results 1 to 12 of 12
    Veteran Member Three Rings alias747's Avatar
    Feb 19 2007
    La Crescent, MN
    Has anyone's VDO ever burnt out?
    About 3 months ago I was driving at night, I stopped somewhere and started my car up again, and my boost gauge didn't light up. I was like what the heck, a wire must have wiggled loose or something. I had checked the connections on the back of the gauge itself, and they seemed fine. I had been to lazy/busy to tear out the panel below my steering wheel to check the other ends of the connection. Last night i tore it out and they seemed fine too, I touched the wires together at the boost gauge end and they sparked really good, so that isn't the issue.
    I just can't believe a freakin bulb burnt out on a boost gauge! Is there a way to fix this, or should I just invest in a new gauge?
    2010 S4 Meteor Gray | S-Tronic | Sport Diff | Nav
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Re: Has anyone's VDO ever burnt out?
    check ecs tuning. they have the bulbs for them. They're $5.95+shipping
    http://www.ecstuning.com/stage/edpd/...ategory=Gauges
    Feb 19 2007
    La Crescent, MN
    Thanks for the link, but I am not even sure how to go about opening the boost gauge to fix it. Anyone ever done it?
    Veteran Member Three Rings 2ndEngineS4's Avatar
    Mar 21 2006
    JHM Brewed 00 S4
    TN
    How is your gauge mounted? Pillar pod, vent gauge, etc?
    JHM.Vast.034.ER.SR.AWE.RS4.Apikol.APR.Innovate.Stg III
    Feb 19 2007
    La Crescent, MN
    Its a vent gauge.
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Should Be Easy, And Look Around For The Led Replacement Bulb And You Don't Have To Replace It Again. The Bulb Is Easily Removed From The Rear Of A Vdo Gauge. Just Pop Out Your Vent And It Should Be Self Explanatory From There.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by obijohn22 View Post
    I just had my boost gauge out a couple of nights ago and I wouldn't say that it was "self explanatory". There is only one way I can think of to get to the bulb from the back of it and it would be through where the electrical connector attaches. But I pulled on that thing hard and doesn't seem like it was meant to come out. It just sits there and turns in place. Have you done this before since you say its easy?
    May 18 2007
    Baytown, TX
    i have. i put the LED in when i first installed the gauge to avoid having to change the bulb and to have the red matching color. You're looking in the right spot. It's where the wires hook up to the gauge. it should be squeeze and pull if I remember correctly. look for little tabs that you can squeeze. you may need a pair of needle nose pliers.
    Senior Member Two Rings Allaidback's Avatar
    May 23 2008
    Columbia, SC
    My awe gauge is still lighting up the majority of the face but the 30 on the vacuum section is really dim? any suggestions?
    Feb 19 2007
    La Crescent, MN
    Quote Originally Posted by RedRocketS4 View Post
    Ok thanks, I will have to take a look again! I appreciate the help!
    The ones from ECS are supposed to be much brighter than the original bulbs becuase they use 3 LED's. You could try that.
    Feb 19 2007
    La Crescent, MN
    I wonder if these would work?
    http://cgi.ebay.com/ebaymotors/2-Sup...spagenameZWDVW
    The ones on ECS are a bit expensive plus once put the shipping on the total comes to almost 18 bucks!!! There is no way on earth I am going to pay that for a little light bulb!
    I wonder if that one on ebay would be too bright or whatever. What do you guys think?
    May 18 2007
    Baytown, TX
    I guess make sure the size is correct first. Then order it.
    Also, search this website, it's where I got my ultra white blinkers to give the clear corners a better look and to have white blinkers.
    http://autolumination.com/3157_3156.htm
    Also, take the bulb to your local radio shack and see if you can match up an LED bulb.
    maybe try to call ECS and explain the situation and tell them it's ridiculous to pay $12 shipping on a <1in^3 bulb. they might come down on shipping or might not, but its worth a shot cause you already know its the right part
