Results 1 to 12 of 12
    Senior Member Three Rings mianol's Avatar
    Jan 19 2008
    help! my car got upgrades but got slower...
    i put an ATP 3" cat delete dp with APR stage 2+
    and in low revs the cars seems slower than before im thinking
    it could be a result of lost of back pressure.Could that be the case? if so what can i do? if not what would be causing this? up until 3k it just seems slow
    help appreciated
    07 A3 S-Line, DSG, APR stage II+, ATP dp, NEUSPEED intake, BBS ta rep, alpine deck, 2x alpine amp, JL 10", black badgessold
    2011 DGM STi
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: help! my car got upgrades but got slower...
    Quote Originally Posted by mianol View Post
    help appreciated
    Less back pressure= less torque in some pump/pipe combinations. More flow, and better HP eventually. Should spin faster, so get up "on the pipe" as we used to say in 2-cycle days.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Registered Member Two Rings kwanja_a3's Avatar
    Mar 28 2007
    2007 Audi A3 2.0T S-Line
    Toronto, Canada
    help appreciated
    That's just it Vince, the larger diameter DP reduces pressure, slightly lowering your low end torque, but is increasing the overall HP band across all RPM, especially in the upper RPM.
    I felt the same thing when I first switched to 3" TBE.
    It's not so bad, less wheel spin, harder and longer pulling at higher speeds
    2007 Audi A3 2.0T S-Line 6MT
    http://mydubspace.com/kwanja3
    Jan 19 2008
    its not so bad....but it feels so wierd!!!
    cuz of this ive stopped myself from getting a catback thinking i might just loose even more pressure freeing up the whole pipe....should i get one ? lol
    2011 DGM STi
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    damn, my cat is shot so i have been looking into getting a test pipe.. but this is kind of unsettling to hear about.
    {99.5 Avant}
    Veteran Member Four Rings Meesh's Avatar
    '06 a3 sport 6 speed
    City of Champions
    did you upgrade your fuel pump with the stage 2+??
    that might be an issue.
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Quote Originally Posted by Jibberific View Post
    easy answere= smaller diameter dp
    May 22 2008
    az
    I have been looking around and all the good name brand test pipes are 3 inches. The only place i can find 2.5 inch test pipes is ebay.
    I have a 2.5" magnaflow exhaust without resonators and chipped k03. do you think i will lose too much backpressure with this combo if i go for a 3 inch test pipe?
    {99.5 Avant}
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Have to also remember since the turbo is a internal WG, so when you decrease the back pressure behind the turbo outlet you also decrease the resistance at the WG flap which means now more exhaust gas will follow that path vs going thru the exhaust wheel. This is one of the reasons you feel a decrease in low end tq since the turbo is taking slightly longer to spool up.
    The TP from Eurocode is 2.5", if you guys want one let me know and maybe I can get a better price.
    What size is the ID (inner diameter) of the EuroCode Tuning TestPipe?
    Our TesPipe starts off at the back of the turbo with a 2.75" ID and transitions to 2.5" ID down at the factory downpipe flange.
    Dec 03 2007
    2016 Toyota TRD Pro 4Runner
    Salt Lake City, UT
    This is probably a noob question, but do I have to chip my car to run a test pipe or can run stock with out throwing codes??
    '15 Q5 3.0 TDI
    SOLD '08 Sprint Blue A3 2.0T | EVOMS MKV/A3 CAI | AWE MKV/A3 Cat-Back Exhaust | AWE Vent Gauge | Falken FK452's
    Veteran Member Three Rings Killerteve's Avatar
    Nov 09 2006
    02 A4 1.8TQM
    SF
    A test pipe on stock tuning WILL cause a CEL. Even with a chip you will need a extra file to prevent CEL's as your ECU needs to know there is not cat.
    REVO GT2871r Elim - 034 - Southbend - Racetec - Forge - HID's - RS4 reps - Podi - APR Snub - Tein - Genesis - Neuspeed
    Dec 03 2007
    Salt Lake City, UT
    Quote Originally Posted by Killerteve View Post
    Thanks
    '15 Q5 3.0 TDI
