Results 1 to 11 of 11
    Established Member Two Rings esee135's Avatar
    Jun 21 2008
    Question Jacking and Supporting a B5 in the front
    I've been jacking my A4 using the stock jack, and I just made a kick ass unibody jack (two moon shape autobody dolleys welded back to back with a 1/2" space between, onto a jack adapter, cost me $17!!!) so I don't crush my pinch welds.
    Problem is, when I was using the factory jack on the front pinch welds, I had lots of room to put my jack stand near by, beside the jack just behind the pinch weld. Now with my 3.5ton floor jack, I can't get the stand in because the jack is too wide. I read people are placing jacks on the sub frame connector in the front, is this safe, and should I be putting a wood softener/hockey puck between the jack stand and the sub frame connector?
    I know about using the lower control arm, but I'm doing suspension work, so it won't work in this case.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Jacking and Supporting a B5 in the front
    I place mine on these 2 metal mount looking things.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Place the jacks under the rear subframe bolts. I usually put a piece of wood between the jack and that subframe point.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Jun 21 2008
    Quote Originally Posted by nebone22 View Post
    kind of like in this picture?
    http://www.fastaudi.net/a4/library/mini/oilchange1.jpg
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by esee135 View Post
    i believe so.
    My 5-Speed Swap DIY
    - B6 USP
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    I just slide my jack in a little further so they go under the sub frame bolts, then once it is up in the air I just put my jack stands where you put the OEM jack.
    Jun 21 2008
    This might be a simple question, but which jack cup do you have? Deep dish, shallow dish, square steel, rubber padded steel? I've got a ~5" cup, great for jacking the differential on my 1/2 ton, not so great on the A4. Also got the flat square cup, which is what I think I'll be using for the sub frame location you mentioned.
    I'm just itching to use my custom hammer dolley unibody jack that I made last night :)
    Jul 07 2004
    socal
    I use a low profile aluminum jack that I ordered from Summit last year.
    Looks just like this but in full scale.
    Jun 21 2008
    Nice one with the miniature pic.
    I was thinking instead of using a block of wood, I could make one of these for my jack...say ~3.5" round stock, 1" thick, with 1/2" deep bore to receive a hockey puck....replaceable lifting surface....I have the inventor/drawing plans if anyone wants, maybe I'll make it next week on the mini-lathe.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Looks like a jack plate and a hockey puck in it.
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    http://www.purems.com/products/product.php/II=833
    I've been using one of these for years and it has held up fine. It gets used for the pinch welds but when I need to lift the whole front or rear I use a 2x4 with anti-slip toolbox liner stapled around it and go under the front subframe or rear diff. These cars really should have had six jacking points like my old saab 9000 did.
    My normal procedure for getting the car more than a foot off the ground in 5 minutes:
    Drive the front onto Rhino ramps.
    Jack the rear diff as high as it will go and insert SUV jack stands.
    Do the same for the front and slide out the ramps.
    Jim
    I Do Werk.
