Results 1 to 4 of 4
    Veteran Member Three Rings K04B5's Avatar
    May 28 2007
    Northern Virginia
    Question A few VAG-com questions
    1) is there a write up or does anyone know how to reset the the millage on a new cluster, after replacing the old one because of the shitty info screen??? Also with that installation, the EPC light came on... wasn't on before I switched. Do I need to clear something in VAG-com?
    2) is the TCU from a 00 A4 1.8T fwd the same as the TCU used in a 1.8T quattro? If not, can something be coded in VAG-com?? Thanks to all you who hopefully answer
    3) i need to find a shop locally to install my GIAC chip, any ideas? The local GIAC dealer does not do it IN-shop.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: A few VAG-com questions
    Dont know about 1 /3, but im pretty sure for #2 you can recode with vag
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Senior Member Two Rings suju82's Avatar
    Jun 02 2007
    1999.5 a4 1.8tq k04+giac, tt dv, bosch 4 bar fpr, DP back 2.5" magnaflow, k&n drop-in.
    Toronto, Canada
    Just had a vag question and didn't want to open a new thread for it. Should i vag the car with the car running or only in the ignition position without starting? Thanx.
    May 28 2007
    Northern Virginia
    Quote Originally Posted by suju82 View Post
    Pretty sure you do it with the ignition in the ON position, but engine not running. To log runs, you'd obviously need the car running.
