Results 1 to 39 of 39
    Veteran Member Three Rings Lugi20's Avatar
    Sep 24 2007
    Chicago
    Hit a speed bump, leaking oil!
    Alright, I hit a sadistically placed, ridiculously massive speed bump that was probably intended to slow down tanks circa WWII, and now I'm leaking oil... and I mean all of it.
    The car is a 99' 2.8 V6 Quattro. Its tricklinking out at a relatively fast pace, the car was running and everything was fine after the speed bump, but as I was getting home the oil indicator started flashing. Looks like its coming out somewhere in front of the roll bar... where is the oil pan located on this car? I'm worried that I might have damaged the engine, but if its the oil pan I can live with that.
    Anyone have shots from under the car that I could possibly look at and photoshop an arrow pointing to the damaged area? All help is greatly appreciated!
    Feb 27 2005
    North Wales, PA
    Re: Hit a speed bump, leaking oil!
    just take a look....its pretty obvious where the oil pan is.
    Sep 24 2007
    Chicago
    I'm not a car expert man, its really not obvious to me. Pretend you're explaining this to your wife.
    I'd really like helpful information if anyone has some, I'm kind of in a bind thats why I turn to Audizine for help, not remarks on what I should or should not be able to recognize myself.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    take off your skid plate and just look for a large pan that has many bolts around it. If it did break it, I would complain to the place that had the bump bc thats just dangerous.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    if you have never gotten under your car, its not the one that is obvious!!! you have to take the skid plate off then you will see it. the other is the trans.
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Oct 25 2006
    oregon
    First option is jack it up. You'll see a big black piece of plastic covering the bottom area held in by multiple bolts?(took mine off so long ago I can't remember if they were bolts or not).
    Next if there isn't an obvious spot it's leaking from such as everywhere being drenched in oil take some rags and wipe it down. Watch it for a couple minutes and see where it is coming from.
    Other option is take it to a jiffy lube and ask them to inspect. They shouldn't be able to screw that up.
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Don't drive it as is if the oil pressure light came on do NOT start the engine you WILL BE DAMAGING your engine.
    My money is that you busted your oil pan.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
    Established Member Four Rings Yaktizzle417's Avatar
    Aug 05 2007
    2000 A4 1.8TQM
    SpringVegas, MO
    Quote Originally Posted by Oricle View Post
    Yes, lets drive a car with a demolished oil pan to total morons, who will refuse to service the car because it has a damaged pan..
    Brilliant idea. Why don't we just suck some sand into the manifold, and then try running the car on plain octane booster and urine? Cause I mean, the urine will mix with the octane booster, and create 93 octane.
    Wow.
    OK, here's what you need to do.
    Call the place where the speed bump anally raped your B5. Tell them their speedbump caused your car to leak. Show them the spots where oil leaked out in their lot, and where you stopped and etc. Tell them they're paying for a tow truck, and the bill for whatever your car will need. Which will be a skid plate and likely an oil pan. Then tell them to have a nice day.
    Next: Call the truck, make sure you get a flatbed if your car is Quattro. DON'T SETTLE FOR ANYTHING BUT A FLATBED. Unless, you want to break more stuff, that costs 159181085x more to service than an oil pan.
    Tell the shop what happened, then tell them to take up any needed funds with the place that destroyed your pan. Then get your car back, and enjoy it!
    ÖMGHI2Ü
    Photography
    Sep 24 2007
    Chicago
    Ok, there I'm fairly confident it was the oil pan, and there is a shop literally around the block from where I live, so I could pretty easily push it there.
    I found that the oil pans are ~$130 online, what kind of labor are we talking about here? This can't be more than 2 hours, I would imagine less.
    Account Terminated Three Rings lotusgardener's Avatar
    Dec 24 2006
    1997 Audi A4
    NW & NE
    2 hours - HAHAHAHAHA, it's an Audi, not a Honda. You have to loosen the engine mounts, lift the engine slightly, then unbolt the subframe...... Then you can take the oil pan off. Installation is reverse (lol).
    Oct 25 2006
    oregon
    You honestly think the city will pay for that.
    depending on how fast it leaks I'd fill my oil up and drive it 5 minutes if I had to.
    Not sure on how far a jiffy lube is or how fast it is leaking-which would be the deciding factor.
    Oct 25 2006
    oregon
    Quote Originally Posted by Lugi20 View Post
    Be prepared to be raped by dealer prices.
    Feb 27 2005
    North Wales, PA
    my friend just cracked her r32 oil pan and the city paid for it in no time.
    Dec 04 2007
    New York, NY
    i cracked my oil pan in brooklyn driving around craters in the road. Fortunately for me i missed the first 3 craters but ended up in the 4th one.
    I was leaking oil but not to bad. I sealed it up using some epoxy stuff which seems to be holding well. Still going to replace the pan though.
    I think it should take no more than 1 hour to remove the pan.
    I also have a 99 2.8Q.
    1.Jack up the car
    2. remove skid plate
    3. may have to remove the sway bar because its covering a few bolts on the pan that will need to be removed.
    4. remove pan. Also, make certain that your not leaking oil from that box that the oil filter sits in.
    Sep 24 2007
    Chicago
    Anybody have a Bentley Publishing manual that can put light on the situation? If it really is a PITA job to do then I'd like to know, but IMO any oilpan should be a fairly easy fix. Yes, I'm sure the front sway has to come down or at least get loosened, other than that I don't see why this is more complicated that any other car.
    Sep 24 2007
    Chicago
    Quote Originally Posted by lotusgardener View Post
    First of all I don't appreciate the disrespectful way you responded. And you are right if its a 1.8T, but since you clearly can't read, you didn't notice that I have a 2.8 V6.
    I just got off the phone with my trusted Audi dealer (Continental Audi of Naperville - the absolute best in the business), and they confirmed that its a 1.5 hour job on the 2.8, but the service rep also mentioned I was "lucky" it wasn't a 1.8T because those are a 5 hour job since you have to drop the subframe.
    All in all, doesn't sound like it will be too bad.
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    I could be wrong but I think the oil pan is up under the subframe, not sure if you have clearance to remove it without droping the subframe or not.
    Did you check to make sure the oil pan was the culprit and it didnt just rip your oil filter off? That COULD be a much easier fix.
    Either way good luck, it wont be fun no matter what happens
    Just make sure you document really well what happened, where, waht time, any pictures with a measurement of the speed bump as well as witnesses. Just make sure you get pictures or some good evidence that will help your case. And obviously dont take the pr!ck position on the issue because they will straight up blow you off, then you'll goto court and by the time thats done ull be in the whole.....
    good luck
    josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Veteran Member Four Rings gotaudi's Avatar
    Jan 26 2006
    2001 A4 1.8T
    Socal
    it isnt a hard job, it is just nuts and bolts. you should do it yourself
    BetaAlphaTau Member#22
    Mods:
    GTRS Elim+Unitronics+ATP high flow mani+Neuspeed TIP+Custom intake+Labree HFC+Apexi AVC-R+APR Exhaust+Precision FMIC+SB OFE Stage 4+034 street density motor mounts+Purems snub+S4 Front bumper+18" BBS RC rims+Neuspeed race springs+Bilstein shocks+Nuespeed sways=
    73 74 69 6c 6c 20 73 6c 6f 77 <--- Look it up
    Jan 07 2007
    really easy to do yourself!!! get under there and look its obvious.
    Sep 24 2007
    Chicago
    Sorry, haven't posted in a few days. I realize this is a pretty easy job on the 2.8, do I have to loosen or remove the front sway bar to get at everything on the oil pan or can I just lift it up and swap?
    Registered Member Two Rings whoace's Avatar
    Oct 10 2007
    01.5 A4 1.8tqms, 90 VW Corrado
    ON, Canada
    Not to be offensive, but if you are not confident in looking for a leak, you definitely do not have the required skills to replace an oil pan properly. It's not as simple as removing the old pan and bolting up the new one, despite what others might lead you to believe. Take what you read with the whole shaker of salt.
    Veteran Member Four Rings Ewok_Fetus's Avatar
    Mar 04 2007
    nothing
    nowhere
    What the fuck are some of you guys thinking? Have the city pay for it? Fuck no! Have the guy that hit the speed bump too fast pay for it! A fuckin speed bump is there to slow people down! You hit it too fast, too bad... That's like going through a red light and getting t-boned and blaming it on the city! If it was a pot hole or something related to mad road maintenance, then yes, proceed from there, but a fucking speed bump! This country is going just where I thought... Anyone here seen Idiocracy?
    ΜΟΛΩΝ ΛΑΒΕ
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by whoace View Post
    I think this dude needs a whole mine...
    ΜΟΛΩΝ ΛΑΒΕ
    Oct 10 2007
    ON, Canada
    Yes, I saw that movie...It was great. Pro Wrestler for President!! And that is truly what is happening to our society.
    It was a speed bump, not a pot hole. If your car can't clear a speed bump without thrashing the underside, it is not safe to drive, PERIOD.
    Veteran Member Four Rings audiness's Avatar
    Jan 26 2007
    Charleston SC
    Quote Originally Posted by Ewok_Fetus View Post
    they are making speed bumps bigger and bigger to accomodate the Hummer H2's out there.
    Dec 24 2006
    1997 Audi A4
    NW & NE
    Quote Originally Posted by Poopie View Post
    I'm still waiting for the Water and Sewer authority to pay for mine, and that's since December.
    OP, sorry for coming off rude, didn't mean for it sound that way.
    Sep 24 2007
    Chicago
    This post proves that it is 100% headed toward Idiocracy.
    Were you there when I hit it? What if it was unmarked? Just a pavement-colored mega-huge bump in the ground? No sign, no stripes, night time driving. I probably took it somewhere between 25-30 mph, the posted limit, and that was PLENTY to completely rocket my car.
    Idiocracy started when Suburbans and Hummers started rolling off the lot like candy, so cities had to make speed bumps that they could notice. Thanks for your ridiculously out of line rant, good luck in life.
    Mar 04 2007
    nothing
    nowhere
    No I wasn't there when you hit it... But it is called being cautious, knowing your surroundings, being alert... I really don't care if it was a clear speed bump, I still say it is your fault... And last I checked posted speed limits were not two different values... It was either 25 or 30... Just because the speed limit is 70 on the freeway, doesn't mean if I see a hazard I keep doing that speed, I slow down or go around... Post pics of this so called speed bump cause I don't believe you that it wasn't marked in any way, nor was it in a posted 25-30 zone... Plus if you don't even know how to spot a wet spot under your car and call it a leak, you should be the one to have "good luck in life" because I know I am fairly sucessful and have a happy family...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings sixfiveoh's Avatar
    May 19 2007
    Bay Area
    Oh god.
    This thread makes me cringe. Good luck.
    SIXFIVEOHphoto
    2001 Brilliant Black 1.8TMS A4
    Unitronic|APR|H&R|Neuspeed|Falken|Carbonio|Apex'i| VDO|VMR
    FS: Buncha B5 parts, CLICK
    Oct 26 2007
    '99 A4 Avant 1.8tqm / '04 S60R
    Nashua, New Hampshire
    Op, if you can look at a sink and tell where the water comes from, you can look under your car, and tell where the oil is coming from.
    It will be really, really noticeable. Good luck with whatever happens.
    Please take the effort to make me feel unworthy!
    Oct 10 2007
    ON, Canada
    What?!? I don't think you know what he means when he says "Idiocracy".
    This is the funniest usage of the word to date. LOL! Using words that you don't know the meaning of, makes you look like an idiot. Especially, when you tell him, "good luck in life". And if these bumps were made so that Hummers and Suburbans could see them, why couldn't you?
    If the bump was as big as you say it is, no matter what colour it is or what time of day it is, you should be able to see it. If you can't, you need glasses. It's a bloody bump protruding out of an otherwise FLAT road.
    Active Member Two Rings redsky's Avatar
    Jun 26 2008
    1.8t Avant (AEB) !!!
    Florida
    Lower oil pan dealer's price is $205, and replacment time 1.6 hours. It actually is fairly easy to do yourself. You have to make sure that sealing surfaces are clean from old sealant, and I belive you may have to loosen up stabilizer bar, not sure however.
    1) Invest you must
    2) Time is your friend
    3) Impulse is your enemy
    4) Basic arithmetic works
    5) Stick to simplicity
    6) Stay on the course
    Registered Member One Ring 3point0's Avatar
    Jun 20 2008
    Burlington, VT
    Wow, as someone speaking strictly objectively, ewok_fetus and whoace are being huuuge douchebags. The point is not whom should pay for it, and as we have already established that it's a relatively easy and inexpensive job to do which the OP has stated he can complete himself, why are you still posting? He was just asking for help. I hope ignorance engulfs your response the next time you ask for help, as you have demonstrated so wholeheartedly in this thread. A few last words:
    Ewok: if you are old enough to have a family, act your f****** age.
    I'm done. Now proceed with your untiring batter of immaturity. Lugi20, good luck with your repairs.
    B5 2.8LQM SOLD!
    2001.5 2.8LQM Sport, blue on gray • S-Line • 20% all-around tint • debadged • 6000k Xenons • chrome mirror and pillar covers • Kenwood 1200W amp, 2 Kenwood 12" subs • Escort 8500x50B RADAR/LIDAR detector • Kenwood in-dash navigation • 18" Avarus AV5, Toyo rubber • Eibach-lowered • Borla exhaust with 2.5" pipes • B&M SS
    Mar 04 2007
    nothing
    nowhere
    Quote Originally Posted by 3point0 View Post
    Sorry God, I won't do it again...
    ΜΟΛΩΝ ΛΑΒΕ
    Oct 10 2007
    ON, Canada
    3point0 STFU! How many people have you helped on this forum? How many people have Ewok and I helped? I clearly stated that if you can't figure out where oil is leaking from, an oil pan job is way out of your league. Did I start the bashing? Tell me, how do you change an oil pan? What are the torque specs and how many times do you have to divide it? What is the tightening sequence? A proper job is a little more complicated than you think.
    Established Member Two Rings Dlay's Avatar
    Apr 22 2007
    2006 A6 4.2 Quattro
    Greensburg, Pennsylvania
    Quote Originally Posted by sixfiveoh View Post
    Oh god.
    Haha I agree.
    If it was unmarked wouldn't you just called it a bump in the first post instead of a speed bump which is something that is always marked. Unmarked "speed" bumps don't ex hist.
    Hope everything works out for you though and you don't have a problem with your car.
    Jun 20 2008
    Burlington, VT
    3point0 STFU!
    Stoppzorz speaking inn 1337 speex! U R confuzorizing meeee!
    B5 2.8LQM SOLD!
    Mar 04 2007
    nothing
    nowhere
    A few last words:
    I am acting my age... It is called "Growing up and taking responsability for your actions." Unlike your childish immature actions...
    ΜΟΛΩΝ ΛΑΒΕ
    Veteran Member Four Rings Tiluleshpingen's Avatar
    Nov 14 2006
    97 AS4 ,08 A5 MKVI Jetta
    Land of the Eagles
    IDIOCRACY is so funny. its got electrolyte.......
    but speed bumps are not ment to be on the highway!!!!
    GIAC-X, STASIS TS,VAST,034 MS
