Results 1 to 16 of 16
    May 21 2007
    Florida
    headlight conversion questions.
    so ive found a couple sets of ecodes i think are a good price. problem is that they are for halogens. can anyone fill me in on why my xenon bulbs and ballasts will not work in these housings? what would i need to do in order to retrofit these into my car? im just really confused on the difference between the two setups(besides brightness, and im guessing xenons run hotter since theyre brighter?) so any info on them would be helpful. thanks!
    2018 Navarro Blue Q5
    Veteran Member Four Rings pOrKcHoP07's Avatar
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Re: headlight conversion questions.
    I think they will work, but its a question about the glare. I guess the only real way to do it is to retrofit real xenon hid projectors in place of the halogen projector.
    Supposely, theres a ecode replica on ebay for $199.99. I think osofast, sorry if I botched your name, bought a set and they look great!
    2003 Audi A4 1.8T Quattro
    AKA: masterforu2nv
    Current Mods:
    Debadge. 3000k DDM Tuning HID Fogs. 5000k DDM Tuning HID Kit. AWE Exhaust. Window/Fog Vag Mod. VMAXX Coilovers. Enkei Raijins. Adam Rotors. Hawk HPS Pads. SS Brake Lines. RAI Testpipe. Racetec FMIC. JHM SS. Motoza Stage 1 Chip.Evolution Racewerks TIP.
    May 21 2007
    Florida
    now call be dumb, but what are the projectors?
    Veteran Member Four Rings pyro's Avatar
    Mar 18 2007
    '05 A4
    Tampa, FL
    no the projectors are the same, or at least not different enough to make a difference. the projector is the round piece the bulb goes in. its the glass dome the light reflects off of. i would just get an aftermarket kit as you will be cutting the housing anyways, i wouldnt spend the extra to try and fit stock.
    Oct 13 2007
    '85 E30 318i
    Yonkers, NY
    Quote Originally Posted by pyro View Post
    huh? I thought the halogen projectors were way different and unsafe to use if an HID system were used because of glare. I thought the best legal way to do it was to get an oem projector already made to take an hid kit. If this isn't true, the bi-xenons I bought were a waste of money.
    AKA: masterforu2nv
    Current Mods:
    Dec 06 2007
    the HID projectors are different and are larger! u can use HID kits in whatever u want unless ur ocd and have to say oh i have xenon projectors!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Four Rings T0M3K's Avatar
    Sep 14 2007
    Valley Stream, NY
    Either way, retrofitting halogens is first of all in most cases illegal, but not checked in states. Proper HID lens/set will give you proper beam pattern that's focused. Retrofitting will give better looking light but could in the end reduce visibility and piss off oncoming drivers. There was a discussion about it some time ago. In Europe laws are very strict about headlights.
    Sep 02 2005
    Montreal
    HID projectors are optically different, even if they're not different in apearance and physical size and shape. And no, HIDs do not run hotter, they run considerably cooler than halogens. Buy a set of Valeo HID projectors and retrofit them into the housing, then buy 5GL ballasts and D1S bulbs. That's the right way of doing it.
    May 21 2007
    Florida
    ^how much would all of that run me? to me, it sounds like im better off just getting the $500 xenon ecodes housings. man, i never thought i would want my halogens from my old car back haha
    Sep 02 2005
    Montreal
    The projectors can be found on eBay for less than 100$ a pair. Then, get this: http://www.hidconcept.com/Kits-valeo-d1s.html
    Mar 18 2007
    '05 A4
    Tampa, FL
    i have both a halogen and single xenon projector sitting on my desk and i can guarantee you that the cutoff plates are identicle, as are the lenses. retrofitting xenons into anything other than projectors is another story, but a retrofit in halogen projectors is perfectly fine and wont blind anyone.
    Sep 02 2005
    Montreal
    The lenses are not. HID lenses have different photometric properties. Halogen lenses with HID arcs behind them do not throw the correct beam pattern. It is conceptually impossible.
    May 21 2007
    Florida
    can i just take the bulbs and ballasts out of my stock lights and use them? instead of spending $300 on other ones? if not, i might as well buy xenon ecodes which i can just swap my stock stuff over to. it would be cheaper.
    Sep 02 2005
    Montreal
    Sorry, I forgot that you already have the ballasts and bulbs. Yes, you can re-use them, if they are OE.
    May 21 2007
    Florida
    any reason why i couldnt take my projectors out of my stock headlights and put them in the other ones?
    Registered User Four Rings
    Oct 27 2007
    NA
    You can simply transfer your existing ballasts + bulbs to your E-code if your e-code headlights use the same D1S type bulbs. If they use halogen bulbs, you can still use your ballasts and we can get you a set of ignitors, D2S bulbs, and H7 adapters (PM me).
    The projector is the magnifying glass looking lens inside the headlight housing.
    Ecode projector provides sharper cut-off line as well as better lighting output than US version.
    Buying a set of E-code valeo projectors to replace your halogen projectors, would not be a good option if you have not done a similar procedure before because it's is not easy to do. Hope this helps.
