Results 1 to 8 of 8
    Veteran Member Four Rings Kronic Budz's Avatar
    Oct 01 2007
    1997 A4 2.8 QM
    San Diego, California
    Question does anyone have a pic of sway bar links installed?
    ok well i inspected my car on a lift today while i was getting my a/c diagnosed.
    Which happens to be that my lower hose going to the compressor is leaking and is a $350 part. So all together its gunna cost $800 to fix my a/c...
    anyways...
    i noticed that my sway bar end links did not match in how they looked being installed. The part of the endlink where the bushing sticks out a little was on opposite sides of the right and left.(sorry there isnt an easy way to describe this) part of the link was touching up against the lower control arm when the other side wasnt. also when we took out one of the links and inspected it the bushing kinda looked chewed up and fell out of the link easily. These links have only 3k miles on them and got them with the control arm kit off FCP groton. Are the links shit? or were they just installed wrong? i took some pics to help out but i cant find my damn chord to upload pics.
    1997 Audi A4 2.8 QM black on black
    bilstein sports w/ vogtland sports ~ S4/sport sway bars ~ 17x8 Bremmer Kraft Br05 wheels et33~ BF G's Sport COMP 2's 225/45/17 ~ Custom Exhaust ~ CAI ~ Ebay SS ~ SS brake lines + EBC red stuff ~ 35% tint/70% front tint ~ face lift headlights w/ 5000k HID + tails ~ blacked out grill trim~ kenwood mp3 ~ Polk comp 5.25" Front mm speakers ~ Infinity REF 6.5" rear speaks ~ 10" Rockford Fosgate p2 in sealed box ~ ED nine.4 4ch. amp powering woofer/polks[/I]
    Oct 27 2006
    Pearl 98.5 Audi A4 1.8T
    Fargo, ND
    Re: does anyone have a pic of sway bar links installed?
    http://audizine.com/forum/showthread.php?t=74853
    Switch the top bolt around VS what they show. This will allow you to work on your suspension without having to remove the shock next time.
    1998.5 1.8TQT (SOLD)
    Joined the Dark Side
    2008 Honda Pilot SE
    Oct 01 2007
    1997 A4 2.8 QM
    Quote Originally Posted by akielb View Post
    thanks, so there should be no bend to the bushings when they are tightened down. Becuase mine had some bending going on
    Registered Member Two Rings manufan's Avatar
    Nov 16 2007
    98 A4 2.8 QM 93 Ducati 900ss
    northern pa
    Quote Originally Posted by Kronic Budz View Post
    I had the exact same thing happen to mine. The line was rubbing against the core support and wore a hole in the aluminum tubing. I took mine to the welder next to our machine shop and he tig welded it. Good as new. I'd look into getting it fixed.
    Oct 01 2007
    1997 A4 2.8 QM
    ok well here are a few shitty pics of what my sway bar links look like. The bushings arent even and they just look like they are on wrong, maybe the links were just bad parts, not sure. But im beginning to think thats where my little clunking sound(wheel sounds if its loose and gunna fall off when hitting pot holes sound) is coming from.
    right
    left(side that clunks)
    *****notice how the bolts go through the nuts on the top of one side and then the bottom of the other, so maybe the link is the wrong way??******
    Oct 27 2006
    Fargo, ND
    install the link so that the spacer side is mounted to the sway bar.
    2008 Honda Pilot SE
    Senior Member Three Rings erikas3's Avatar
    Feb 08 2008
    2003 Jetta GLI 24V
    Tinley Park, IL
    So the links aren't supposed to move by hand?? Damn, looks like another thing that needs to be replaced on this car =(
    1998.5 Audi A4 1.8T (Hibiscus Red)
    Soon to be BT...
    Oct 01 2007
    1997 A4 2.8 QM
    would it even be worth it to buy new links now since they have been on the wrong way for some time now, does it mess them up? whoever i had install these control arms and links was an idiot becuase they messed up a lot. Maybe im the idiot for paying them.
