OK so i've been having misfire problems and it's always cyclinder #4,
my 1st went after the starter motor died. The night before i had washed my car, while replacing the starter motor i had forgotten to ground out the power wire beofre changing the starter and sparked while loosening the power cable.
I thought that shorting out had caused it to go bad so i replaced it and either i got a bad one or i shorted it out when i put it in cause immediatly it was bad. got another one put it in and it wasn't working...then all of a sudden it started working.
Washed the car last night not thinking it might have something to do with the ICM going bad and it started to misfire a little, today went to drive it to school, horrible. Waiting on my volt meter so i can test the ICM.
the first ICM was bad on #1 and #3 they next two went bad on #4 and sometimes #2.
Any idea on what to start looking at and possible tests to run? I want to find something before i put a new ICM in and fry it...
All i want to do is start tuning the car so i can boost it up, thanks guys!!!
