Results 1 to 18 of 18
    Sep 20 2004
    2001 a4 quattro
    Sactown
    New Side Skirts?
    I'm about to purchase Avant Garde Side skirts but the guy doesnt have the mounting equipment. do you guys think it would be really difficult to find an alternative way of mounting them? also in general can you keep the stock lower door trims with aftermarket side skirts? here is a picture of the skirts
    does it seem that stock lower door trim can work with these skirts?
    Feb 27 2005
    North Wales, PA
    Re: New Side Skirts?
    those look like generic trim to me.
    Sep 20 2004
    2001 a4 quattro
    Sactown
    Quote Originally Posted by Poopie View Post
    what do u mean by that?
    Registered Member Two Rings kingdon's Avatar
    Jul 07 2007
    new york
    Hi guys how to you post up a picture.
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    Quote Originally Posted by a4rings View Post
    As in not OEM. It's trim guard. OEM will fit with those, if that's what you want. Trim once pulled will never seat right again, it's the luck of the draw if you get to pull it and have it go back on the same. You don't need any hardware for mounting them. 2 sheet metal screws with good washers with the neoprene skirt (prevents cracking the skirts) up front and in the rear along with 3m tape underneath the whole length of the skirt and you're done.
    I have the reps, which are what you're looking at buying. True A!avantgarde skirts are impossible to get.
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by kingdon View Post
    Host it on a photo hosting site, copy image location, and use the insert picture function.
    Dec 05 2007
    Hey Bassed, if you don't mind me asking, may I inquire where did you purchase yours from? Thanks!
    Feb 15 2007
    marimont
    x2
    Sep 24 2005
    always in design
    Quote Originally Posted by solowb5 View Post
    x2
    Sorry gents! They are no longer making the real deal or the reps. I was quick to snag these up from a GB on here about 2 years ago. Keep an eye out that's about all you can do.
    Jul 07 2007
    new york
    YES Mr. four rings I have the same drop H&R coilovers Looking good.
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    http://www.tinypic.com or www.photobucket.com or www.fotki.com are a few.
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Nice skirts, i knew a guy that had them and they look liked the next best thing compared to the s4 ones.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 08 2006
    Cincinnati
    Here are the same ones on my Black A4. You don't need anything special to mount the side skirts. Remove the stock side trim (in door jam), then put avantgardes on with double sided sticky tape and a single screw in each end (in wheel well). Remove door trim and cut it, keep it off, trim the pins, or use trim gaurd. With a black car the pins don't bother me on mine...
    Dec 08 2006
    Cincinnati
    Quote Originally Posted by bassed View Post
    Sorry gents! I was quick to snag these up from a GB on here about 2 years ago. Keep an eye out that's about all you can do.
    Same here, I get lots of emails asking where to find them. I just direct them to DTM autohaus (where the GB was from)...
    Sep 24 2005
    always in design
    Quote Originally Posted by kingtr View Post
    I called them and had a chat 2 months back,they ended the rep run with that GB
    Dec 08 2006
    Cincinnati
    Well even though they were initially meant for my silver A4, I am still glad I jumped on the GB and ended up with them on current car. Cursh kept saying he wanted to buy them, then let his car fall apart. Finally figured it was time to put them to use (instead of leaning in bedroom corner)..
    Sep 20 2004
    2001 a4 quattro
    Sactown
    i bought them yesterday for 75 bucks. good deal?
    Dec 05 2007
    Can anyone on here do me a biggie? If you find an individual whom is selling them, PM me so I can purchase them? Thanks!
