Results 1 to 40 of 40
    Veteran Member Four Rings Audi_S4's Avatar
    Feb 20 2008
    belgium
    Why no bolt on Garret Turbo's?
    about 6 months ago I saw this...
    http://www.atpturbo.com/root/releases/release041205.htm
    http://www.atpturbo.com/root/release...se102705_2.htm
    but it seems nothing really came out of it or what??? are they for sale now or ...
    I don't want a full gt kit to blast out 500whp , I just want garret turbos in my S and it seems they can be made to fit stock downpipes and manifolds.
    tomorrow or friday I'm going to Turboservice Belgium
    http://www.turboservicebelgium.com/Engels/index.html
    I know the guy , just called him and told me lately indeed KKK RS4 K04's seem to die quicker then they used to, just had 2 sets in from this week from RS4's that only had 10-20k km on them and were totally screwed
    he also told me it was better to go GT that these turbos were better made ,stronger and could push more hp with less boost, also due to dual ballbearing.
    tomorrow he is going to take a look to make A GT2554r be a direct bolt on to stock downpipes and manifolds !
    A3 8P DSG 3.2 S-Line : Billstein PSS / OZ Superleggera / 034 Sway / 034 Spherical bushes
    May 04 2004
    00 BB S4
    York, Pa
    Re: Why no bolt on Garret Turbo's?
    I dont know what happened to the eliminators, but I would sure be interestd if they came out. Tuning/Software is the only problem, but I'm sure someone would figure that out quickly
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Active Member Three Rings panix73's Avatar
    Mar 17 2006
    Battleship Kruzer
    Long Island, NY
    Apparently ATP was planning releasing an eliminator series GT turbo or doing research on doing so back in 05-06. They even went as far as releasing a news letter about it, although unfortunately the project died.
    Since then, TiAL has released a GT turbo kit that will not only bolt up to stock exhaust manifolds, although you'll even be able to use stock downpipes as well. They offer two kits, one utilizing a journal bearing turbo based off of a GT25, and another ball bearing based off a GT28 series. Both turbos utilize internal wastegates and are DIRECT bolt ons.
    If you are interested in either of the following contact Johnny Bravo at TiAL. He is the man to speak to.
    Innovate.
    Feb 20 2008
    belgium
    damn, direct bolt on using stock manifolds and downpipes?
    anybody now someting more about these Tial Elimanators????
    I saw the 650 kit with external wastegates and stuff but I just need Replacements for the K03's to use with AWE downpipes and stuff , just the basic stage 3 upgrade but with other turbo's
    Veteran Member Three Rings NogaroWonda00's Avatar
    Jun 13 2008
    Rocky Mountains
    maybe you are hearing about re manufactured k04s failing. i just got a stage 3 kit from awe the box said borg warner and they were brand new....i had re man'd k03s put it in at first they failed right away. anyways not what i need to be hearing right after i bought this kit
    Feb 20 2008
    belgium
    Quote Originally Posted by NogaroWonda00 View Post
    no man, I talked to turbo service themselves, they sell those turbos and even they say the turbo's are weak in comparison to GT turbo with ballbearing. they told me garret GT series are made to handle 25+ psi boost levels for a long time and big heat , but the RS4 turbos are not designed to run high boost levels and can die sooner...
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Quote Originally Posted by Audi_S4 View Post
    well of coarse. the larger the turbo, the higher effeciency it has.
    and k04's are small. very small turbo's. they are not weak turbo's by any means though. supra guys run larger BW turbo's at 50psi no problem making 1500hp.
    most likely the main reasons that k04's are failing(the small percentage at least) is that, 1-people don't know how to take care of a turbo'd car(not letting the oil warm up before they romp on it, and not letting the turbo's cool down after a hard drive. 2- people again, pushing them past their effeciency. you shouldn't really push them past ~24psi. but if you constantly push that, or more, the turbo will wear extremely fast and fail. it is this way with EVERY turbo
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Account Terminated Four Rings
    Mar 14 2007
    michigan
    I think you might of misunderstood.. The eliminator kit isn't for S4sss the tial kit is....
    Theres no way to make a garrett fit the stock manifolds unless your starter isn't important...
    May 04 2004
    00 BB S4
    York, Pa
    NO, that was the who point of elims. Building kits at your own pace, they are designed to fit stock dp,s with a recasting of the turbine stection and a garret chra and compressor side.
    00 S4 BB Stg3
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by generationjdm View Post
    push starting isnt so bad
    - Clint
    Mar 14 2007
    michigan
    Theres no bolt on garrett turbo anywhere for the stock manifolds period... I've built several GT kits to date and it doesn't fit as I tried to make it work for 4 weeks.. Theres no way possible to make any of the gt25ss or gt28ss to work... The compressor housing is to large for 1 the starters in the way 2 the actuators don't fit 3 how many more because i think theres at least a half dozens more reasons
    Jan 18 2005
    North NJ
    pic of the tial650 kit
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Hand Cranking - Safe and Easy
    Feb 23 2008
    Atlanta, GA
    I am installing the tial 650 kit literally right now in my garage. There is some grinding, etc required, but not a big deal. I have the turbos all bolted up and am just waiting on motor mounts and a few other parts
    Mar 14 2007
    michigan
    Grinding on what the compressor housing where its touching the manifold or by the starter?
    Feb 20 2008
    belgium
    aren't there smaller versions then the 650 kit?
    Veteran Member Three Rings OneSickSedan's Avatar
    Feb 23 2005
    2001.5 Audi S4 6-Speed WMS Stage 3-
    Southern California
    ^Yeah Johnny from Tial said they were offering two kits. The smaller ones are journal bearing turbos as panix73 said. But lately I heard that they might not offer it anymore because of how well the 650 kit was doing in terms of spool. Skydive@AI had them installed and loved how quickly they spooled up.
    2001.5 6-Speed Santorin Blue S4 (WMS Stage 3-,mod list in my profile)
    "Who, after all, speaks today of the annihilation of the Armenians?" - Adolph Htiler
    Let's end the cycle of genocide by recognizing the Armenian Genocide and end the Darfur Genocide.
    "If you're not first, you're last." -Ricky Bobby from Taladega Nights
    "LIVESTRONG" - Lance Armstrong
    Mar 20 2008
    Italy
    a link to TIAL website?
    RS4 B5
    May 04 2004
    00 BB S4
    York, Pa
    Your right, but ATP had a running elim car on stock manifolds. They could have just made an extention or spacer between the manifold and the turbo. Or included a smaller starter with the kit easily.
    1.8t, the entire point of the elims was the ability to do a slow, or budget build. Concept doesnt work as well on the 2.7t because of the location of everything :(
    00 S4 BB Stg3
    Feb 20 2008
    belgium
    where to go with the tial GT questions? I sent a mail to tial website...
    Feb 23 2008
    Atlanta, GA
    I had to beat the outer wall of the driver side manifold in a little bit to make room, and grind down the flashing off the drivers side engine mount to make room for the inlet, and remove some brackets off the stock coolant lines. Nothing a dremel and hammer can't take care of.
    For info on the tial kit, check tial's website, and tapp auto.
    Nov 30 2006
    01.5 pearl white S4 6speed
    annapolis, maryland
    I would agree alot with GenX on this one.
    First of all I dont see a point in running the Tial's or any other decent sized turbo for that matter without changing out the manifolds.
    Secondly if your running 24psi on a daily driver, and doing it all the time.. Then no shit your ko4 is failing.. it can take it on days at the track here and there, but not everyday. Thats like saying hey these 28rs are failing because were trying to run them at 35psi, yet our gt45r is doing just great.. Ya think?
    Like Sean said.. Its not Borg Warner turbo's that are the issue.. Its the consumer or tuner that has picked the wrong said up for an individuals desire's. Borg Warner makes bullseye turbo's and a TON of people are out there running them on Supra's, Grand Nationals, Mustang's, etc. with Absolutely No problem. Actualy alot of people would rather takea bullseye over a Garret as they feel that the Bullseye makes more boost quicker then that of the same sized garret.
    Veteran Member Four Rings Reich's Avatar
    Oct 14 2007
    2001 s4 ; 2001 jetta tdi
    Val-Belair
    Quote Originally Posted by purchasers4 View Post
    I don't think there's grinding to do. I have f..king big bullseye turbos, Which is a slightly biger than gt28, on my stock mani and no grinding at all. I only did some grinding on head gasket that protute to fit biger holset waistegate. Waistegate comes preaty close to the head but fit.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    Quote Originally Posted by Dr.Duct View Post
    people will ALWAYS blame either 1. their software or 2. the turbo design when their shit fails.
    95% of the time money says they NEVER did boost leak and or cyl leak down tests on their car, or like earlier said they are overboosting the k04's that fail on them.
    vacuum leaks, boost leaks, and bad compression kills parts. when are we gonna learn that?
    im just defending the kkk turbo. no its not a better design than the dual BB garrett but its certainly proven and does work well when the car is taken care of.
    Nov 30 2006
    annapolis, maryland
    Quote Originally Posted by ThirdStrike View Post
    ko4's are money, and awesome for running 19psi and below.. anything to 23 is tinkering with death, anything about 23 is as certain as death and tax's.
    GenX's kit is ideal for someone looking to do bigger and better things. Id prolly go with his kit vs. any of the others.
    Feb 20 2008
    belgium
    yeah okay I understand that, but they told me recently there were more K04 failures then in the past few years... and this is not just someone , this is one of the biggest turbo shops in the country here, they only sell turbos from every brand so they would have no reason to tell crapp.
    I just want to have 400-420chp and 300-330 whp with a safe moderate tune with bolt on turbos that don't fall apart after a few miles like some have done recently...I have them here and AWE downpipes so I could just have them installed but I have some fear with all the shit lately and I'm such a lucky boy with those things and I would just TRIPP if that happens...
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    please explain to me how 23 psi (or 11psi per turbo) is too much for the k04. i dont understand.
    Oct 14 2007
    Val-Belair
    K04 have the same thrust bearing as k03. Much like a star washer, those thrust only have 270 deg of thrust surface instead of 360. They'll have the same issue as k03 if pushed to the limit.
    Nov 30 2006
    annapolis, maryland
    Look at the spec's and what they were designed for when put in the B5 RS4.
    They can be ran at more, but for conservative everyday driving its not the best of idea's. Not saying it wouldnt last, but not likely.
    To the other fella.
    You can go Ko4's, A good custom tune, decent turbo back, and a nice set of intercoolers and youll be fine.
    Veteran Member Four Rings JMTx86's Avatar
    Oct 03 2005
    b/c both turbos are pushing out 23 psi not 11 lol
    00 b5 s4 Single turbo
    1969 Chevy Nova 396 (Full resto, completed in 2016)
    1969 Chevy Camaro 454 (built 454/th400, body is a work in progress)
    11 Chevy z71 5.3 shop truck (Vortech V2 build in progress)
    Veteran Member Three Rings TalipseAWD's Avatar
    Apr 08 2007
    Stamford, CT
    Quote Originally Posted by JMTx86 View Post
    lol
    2000 S4
    Nov 30 2006
    annapolis, maryland
    no.. actually its a total of 46 psi.. lol I wasnt even gonna go there. It felt to easy..
    Oct 03 2005
    so what your saying is that if im running 20 psi, each one of my turbos is producing 10 psi?
    OR
    they are both pushing 20 psi.
    You run 2 compressor 120 psi each, you hook them up to the same air line with a t fitting or what ever, they are gonna push 240 psi, i dont think so
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    which is it? 20psi(2400mbar) from the map sensor = 10 per turbo or 20 per turbo?
    Mar 14 2007
    michigan
    20 per turbo
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    20 per turbo
    thanks.
    Oct 03 2005
    Quote Originally Posted by TalipseAWD View Post
    lol
    so sad, and your the pres of the free 10 sec s4 club. Damn.
    May 04 2004
    00 BB S4
    York, Pa
    Each turbo runs the same boost.
    00 S4 BB Stg3
    Sep 17 2006
    SLC, UT
    Quote Originally Posted by 98a4 View Post
    you almost contributed to the conversation
    Current:
    Previous:
    May 04 2004
    00 BB S4
    York, Pa
    Quote Originally Posted by sean1.8t View Post
    I have some long drawn out post, but i just edited it. I was sippin the sauce...
    00 S4 BB Stg3
