Results 1 to 25 of 25
Thread: noise?
    Mar 14 2007
    MN
    noise?
    so my car makes a loud tick at start up could this be the oil pump? It eventually gets a bit quiter, but not sure what it could be any ideas? I took a cell phone video for the noise if i could send it to anyone to post up
    Jun 14 2007
    2000 S4
    Connecticut
    Re: noise?
    ticking? is it from the motor or no? a ticking noise is usually an exhaust leak... maybe that will help you. try to look under the car thats where you should hear the ticking hopefully.... a dying fuel pump sounds like a dying fuel pump lol it whines!
    Oct 31 2005
    Ashburn
    Re: noise?
    Not sure what is actually inside are motors, but from when i had my eclipse they were notorious for ticking/tapping during cold starts and that was due to a bad hydralic lifter.
    - Instagram: @Sinister_rs5-
    Mar 14 2007
    MN
    Re: noise?
    it is comming from the engine and is kind of loud at start and then once the car idles for a min or two it dies down to almost nothing
    Veteran Member Four Rings obijohn22's Avatar
    Dec 02 2007
    2001.5 S4, 2013 ZL1 Camaro, 2013 Jetta SE
    michigan
    Re: noise?
    Some valve noise at startup is normal. The aging upper end of our heads do not have the tolerances that they did when they were new. Cam lobes have worn a little etc. As the heads fill with oil, the noise subsides and will still be there a little. and actually will become a little more noisy again as the oil thins and warms up. The 2.7t is known for valvetrain noise. As long as it goes away after about 5-15 seconds, you should be fine. Most owners manuals even describe this as being normal operating issues. the key is if it is coming from the top of the engine or somewhere else. Have someone who is experienced listen to your car at a cold start. They should be able to determine if you have an issue or not.
    "NIGHTMARE" Stage 3+ 2001.5 Brilliant Black S4. VAST sauce
    My shit goes like whoosh boom pshhh and like vroom and junk. So fast.
    Mar 14 2007
    MN
    Re: noise?
    a friend said cam belts could that be it
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: noise?
    Just a guess, but I'll second the lifter tap. Pretty common. How many miles on your car? Last oil change?
    Mar 14 2007
    MN
    Re: noise?
    87,XXX miles and oil changed recent.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: noise?
    the belt could be the trick... has the timing belt ever been done? i ask because when you replace that you have new fresh belts in there everything is tight again
    Mar 14 2007
    MN
    Re: noise?
    timing belt was done in december....
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: noise?
    Quote Originally Posted by mthomas141 View Post
    I still think lifters. Any chance you can get a short video/audio of start up?
    Mar 14 2007
    MN
    Re: noise?
    i have one on my cell phone can i send it to you i dont know how to post it
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: noise?
    I just PM'd you.
    Mar 14 2007
    MN
    Re: noise?
    video is sent!
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: noise?
    Hmm..now I'm leaning more toward an exhaust leak...
    http://pictures.sprintpcs.com/share....tate=RETRIEVED
    Mar 14 2007
    MN
    Re: noise?
    it goes away though which is weird so im confused
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: noise?
    The leak could be going away after the exhaust is warmed up. But it's not a very high quality video from a phone, so it's difficult without actually hearing it to tell.
    Mar 14 2007
    MN
    Re: noise?
    lets just say not exhaust then any other ideas or still lifters?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: noise?
    If not exhaust, maybe lifters. But again, just a guess without actually hearing it. The videos up so maybe others will chime in.
    Veteran Member Four Rings Jeff's Avatar
    Feb 18 2004
    Los Angeles, CA
    Re: noise?
    It's your valves (lifters). What kind of oil are you running? I've found better luck w/ Castrol, Redline, and RP over Mobil 1 (which tends to be louder when cold). My experience w/ Mobil 1, they always give you more audible lifter tick than other oils.
    Feb 18 2004
    Los Angeles, CA
    Re: noise?
    Yes...4G63's do this as well, but it's not always the lifter (for a fresh motor will do this as well).
    Oct 31 2005
    Ashburn
    Re: noise?
    Quote Originally Posted by Jeff View Post
    Yeah that's what it sounded like to me. but yes a valve issue sounds the same. or i've even heard in some cars you can hear the ticking for the injectors? not sure though. Hope you find out what it is
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    Re: noise?
    i get the same exact noise, but mine occurs if i drive like a granny for a while and dont push it... i'm currently running amsoil 5w-40. this is the 1st time I've used amsoil in this car. i normally run castrol. Would it be good to change back to castrol? or do you think it could be the cam tensioner? My noise is specifially coming from the driver's side front of the engine where the tensioner is located. should i try to change the tensioner gasket first? or what? not really ready to drop the cash on a new tensioner seeing how it is $500+ for parts alone.
    The car rarely makes the sounds when cold, but rather after a slow drive. do you think i just have some crappy carbon build up?
    May 18 2007
    Baytown, TX
    Re: noise?
    Anyone have any luck with this? I was looking throught the bentley dvd last night and looked into the valves and read how to check them. I noticed a note at the bottom of the screen that read:
    "If irregular valve noise occurs repeatedly during short journeys and disappears after extended driving, the oil check valve must be replaced."
    It gave me a link on how to replace them. I printed and scanned it if anyone wants to look at it to maybe see if it's the issue. Has anyone ever had to change an "oil check valve"???
    May 18 2007
    Baytown, TX
    Re: noise?
    Anyone resolve this problem yet? I have yet to change my oil. seeing if anyone has had any luck?
