Results 1 to 21 of 21
    Registered Member Two Rings
    Jun 23 2008
    Iowa
    B7 RS4 side reflector options (Euro, painted etc...)?
    Ok, the USDM side reflectors on the RS4 while probably very useful are absolutly ghastly and need replacement.
    The orange in the front bumper and red in the rear bumper are an eyesore to say the least.
    Is there any euro options such as clear, smoked or perhaps painted? The 335i has a body colored marker for up front that replaces the orange in the bumper and thats sorta what I would like to find for the RS4...
    Any suggestions...pics would be great.
    Also anyone know how to pop them out for paint or replacement. A DIY would be awesome.
    EDIT - Here is a pic which shows the aforementioned nasties in plain sight...
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Re: B7 RS4 side reflector options (Euro, painted etc...)?
    Paint them. Sorry I'm at work so I have to link instead of embed, but here you go. These are OLLLLD pics, but you get the idea...
    http://audizine.com/forum/showthread.php?t=209306
    Veteran Member Four Rings EuroA4's Avatar
    Feb 12 2004
    PA-NJ
    Try Lamin-X film...I ordered a dark tint color and custom cut them to apply over the lens.
    Feb 15 2007
    I painted mine..... To remove the front ones, you have to remove the bumper. Each front reflector is held on with wimpy alu. metal nuts. There is a way to pry off the nuts while keeping the bumper intact, but it's VERY difficult (I know from experience!).
    I just recently found out how to remove the rears without removing the rear bumper. First, you should stick your head under the rear bumper near the exhaust (please make sure your car is cold) Then with a bright flashlight, look for a black plastic piece with white tabs on the inside of the bumper (sorry, couldn't get pics of this) Next carefully stick your hand between the exhaust/exhaust shield and the bumper and feel around for the black plastic piece. Then there will be two tabs, one on the bottom and one on the top of the reflector. Squeeze these tabs together and the reflector will pop out.
    I hope I explained it well......
    The Euro bumpers are much nicer. They have bigger slits, rather than the reflector:
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2024 Tesla Model 3 Dual Motor - Stealth Grey
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    heres a shot of mine (im on the right) zachf88 explained it right
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Registered Member One Ring AudRS4inIowa's Avatar
    Jun 24 2008
    Baghdad, Iraq
    richib86,
    Are you using the 10mm spacers and 275s? Also, are those different bulbs for your foglights? I thought about running a spacer but I've read mixed reviews on rubbing with 275s.
    I've got the Stasis MS suspension w/aggressive springs, hotchkis sways and 275s waiting at KCs house today. I'm sure he'll love that when he gets home from work!
    Cheers!
    --Ryan
    Nov 05 2006
    Fair Lawn
    yea im running 10 mm spacers and 265x30x19 with an agressive drop and theres ZERO rubbing i love em. the fogs are aftermarket hid's (6000k)
    Senior Member Two Rings mfresh2k2's Avatar
    Jun 23 2008
    Florida
    BLACKSHEEP, here ya go, the smoked lenses would look good
    http://www.ecstuning.com/stage/edpd/...egory=Lighting
    Jun 23 2008
    Iowa
    Wow, thanks guys esp for the tips and tricks to remove the rear ones as posted above...
    Ryan - your call now. Do you want smoked or body matched? Too bad ECS don't sell the rear smoked as well, which they should. We should petition them to!
    Else - I could have R Jones paint the reflectors for you, maybe?
    Lamin-X is a PITA to do and I have done that before...They are easier pre-cut!
    Jun 23 2008
    Iowa
    Quote Originally Posted by richib86 View Post
    Off topic - Does the 10mm come with extended lugs - I have 25mm spacers for my Evo and they come with built-in lugs and bolts to attach to stock hub.
    Trick piece...
    Feb 15 2007
    10mm spacers need longer bolts.... 15mm and higher need stud conversion (like your 25mm) usually. But, please do not smoke the reflectors!! COLOR-MATCH them!!
    Jan 17 2008
    Evolution X
    Texas
    Euro bumper looks amazing! I'm sure that's quite spendy though, so I definitely reccomend painting them. Smoked just isn't *quite* right.
    Edit: Especially on a blue car. I was thinking black just because that's what mine is. Looking at the pictures again, 100% without a doubt paint them.
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    stock ftw
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Jun 23 2008
    Iowa
    Quote Originally Posted by swoyekr. View Post
    stock Ftl
    Qft
    Jun 24 2008
    Baghdad, Iraq
    I think painting them will look best as well.
    Jan 17 2008
    Evolution X
    Texas
    Good call! Since your color is probably fairly difficult to match, have the dealer hook you up with the paint or paint code. Hey, you bought an RS4, see if they'll do it for you! It's amazing what a difference getting rid of the glaring orange and red makes on the car. Have I mentioned how awesome it is yet?!
    Aug 26 2013
    Belgium
    Hi,
    I live in belgium, i had a dream to own a rs4 cabrio.
    But here in belgium you had to pay allot of taxes, so i bought a A4 cabrio an started my conversion in a rs4 cabrio.
    I changes nearlly everything expectly the SML on the front bumper.
    I couldn't find the SML for the front bumper of a rs4.
    Can someone please post the part numbers of it?
    Ps: sorry for my bad english
    Veteran Member Four Rings FastEddie's Avatar
    Apr 01 2012
    Queens
    Honestly i think you should wrap them. I had mine wrapped. Now if i want to sell i can either remove or keep on. You cant even tell its wrapped. Guy did a an amazing job on them.
    Veteran Member Four Rings dparm's Avatar
    Apr 24 2009
    Frisco, TX
    I think it depends on the color of the car.
    On some colors it adds visual interest and breaks up the monotony of having a big area of a single color. For others, it looks out of place. I think it comes down to personal preference.
    now: 2021 Mercedes AMG C63 S, 2017 Chevrolet Corvette Grand Sport
    past: 2005 Audi S4, 2011 Audi S4
    Veteran Member Four Rings Datadatum's Avatar
    Mar 12 2013
    Jax, FL
    Wow - 5 year old thread bump!
    Veteran Member Four Rings singleframe's Avatar
    Apr 25 2010
    2007 Phantom Black RS4, VW eGolf
    Venice Beach baby!!! 🌞
    also lamin-xed mine. actually wasn't that bad to do and looks good to me!
    IG @myRS4 | 2007 RS4 | Phantom Black | Milltek'ed | KW H.A.S. kitted | Rotiformed (SPF DDT 19X10 +25) | PSSed 275/30/19 | LED DRL'ed | H&R wheel spaced | 034 Density Line control armed | Hotchkis F + R Sway Barred | Apikol rear-diff mounted | K&N Filtered | Ziza lit | Passport 9500ix hardwired | Dension Pro BT'ed | StopTech Brake Padded | window trim matte black vinyl wrapped
