Hey guys:
I've searched the forums and I have a grasp of what's going on, just not sure of the trouble shooting options.
I was boosting normally for a K04, between 22-25 psi up until about a month ago. I put in Shell 91 and all of the sudden I don't boost past 10! I figured it was the ECU compensating for the fuel, but when I put Sunoco 94 back in it didn't boost any higher. I searched and found out I can disconnect the wastegate and see what I boost. I just did that and I'm all the way up to 25psi.
So.....obviously the turbo's ok, but is it the wastegate or the N75 that is causing the problem? I don't want to have to pull the turbo, but I will if necessary......any thoughts?
