Results 1 to 4 of 4
    Senior Member Three Rings tgiblin's Avatar
    Mar 27 2008
    2001 S4, 1957 Bel Air, 1972 CT70
    Don't Steal My Car
    DPs without Rewelding?
    What can I do? With parts from Pep Boys, not the Vast Kit. I can weld but need them done ASAP so would be quicker to not. What do you do with the O2 sensors when you put simulator/defoulers in? Cut them off? Ziptie?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: DPs without Rewelding?
    I didn't relocate mine, I stacked two non foulers, one drilled out to fit the O2 sensor and put it back in the stock location in front of the main cat. No codes in over a year. Your mileage may vary. Those non foulers can be found at pep boys, autozone, etc.
    Mar 27 2008
    Don't Steal My Car
    Which do I drill? Top or bottom? And to what size?
    Jan 29 2007
    08 S4 00 S4
    MD
