Results 1 to 3 of 3
    Registered Member Two Rings 2screwed's Avatar
    May 22 2008
    Vista, Ca
    Coolant leak locations
    I have to fill my reservoir for coolant every 2 days now. I have a leak but can't seem to find it. Sometimes there is coolant under the car and sometimes not.
    What are the most likely places coolant leaks occur on these cars.
    I think I see some coolant by the temperature switch (green switch, driver side of motor) and I saw some liquid dripping from the passenger side, firewall behind the heat shield. What is there? Heater core? that might have been condensation from the air conditioner though?
    Water pump?
    I have considered that the head gasket might be done but I don't have a lack of power and no smoke out the tailpipes.
    Where have your coolant leaks been?
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: Coolant leak locations
    - Coolant flange on LS of engine, under the cover.
    - WP o-ring to block, under center F of engine
    - coolant lines (4) to/from turbocharger scroll
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    May 22 2008
    Vista, Ca
    Quote Originally Posted by InTTruder View Post
    thanks, could be the coolant lines to the turbo. It was recently replaced with a KO4. I'll check that out tonight
