Results 1 to 19 of 19
    Veteran Member Four Rings evil_O's Avatar
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Suspension Short List
    Looking to get a different suspension setup for the S4 ('06). I am not happy with the current setup it has... no worries this is my ONLY complaint about the car. A local (trustworthy) shop took a quick peak at it and it appears the original owner just put new springs in it with the stock sport shocks. Not too bad but I would like something shall we say, a bit better?
    With that said, I am looking at several suspensions. Here is the short list:
    KW-V3 - $2048.29
    H&R Street Perf. Coilover - $1258.00
    FK Konig sport coilovers (dampening adj.) - $1249.95
    PSS9 Coilover kit - $1695.95
    Keep in mind, I am doing coilovers to get my exact look dialed in while maintaining ride quality. As far as adjusting... I am just not sure it will happen. I know the Koni Yellows (FK coilovers) are adjustable from the top, so it would be a one time adjustment as it does not appear I can get to the perch from inside the engine bay (unless I am missing something)....
    I will NOT be tracking the car. So I guess I don't want to "overdo" my needs. Hence the reason I am not going STaSIS. I have heard great things about STaSIS but I just can't justify the 500 over the KW-V3 (again... I am not sure even KW is what I want as I don't think I will need dampening/rebound adjusting. In the end... it sounds like I would drive myself nuts always tinkering with the thing)
    In the end, I guess I am just looking for experience with and thoughts surrounding my short list. I think I would be happy with any of them... especially over what I have now.
    If it helps... I am really leaning towards the H&Rs. Good price, good name, install, adjust height, and I would be done....
    Thoughts? I have searched and read many thoughts surrounding suspensions... so I guess I just needed to create my own thread to address my own selfish needs.
    TIA
    2013 Ibis White S4||P+||DSG||Sport Diff||B&O||Black-Chestnut Interior|| Unitronic Stage II+ & TCU Stage II||Luft-Technik Intake||20% Tint || KW H.A.S. Kit||TSW Bathurst ||Magnaflow res X-pipe||Copious amounts of Xpel| PIAA Plasma Ion Yellow Fogs||ECS 2-Piece Wave Rotors
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    Re: Suspension Short List
    I've always been a fan of koni/eibach/ground control setups
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Veteran Member Three Rings cam's Avatar
    Oct 11 2007
    NYC / west palm / las Vegas
    from what i hear the vogtland setup is the most cost effective, and although it isnt dampening adjustable they say the ride is very compliant.
    i have a set of koni coils on my s4, from a v6 a4, i have them set to full stiff all around, the ride is good, and i am "slammed" as you guys would say.
    Veteran Member Four Rings littleredwagen's Avatar
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    I love my h&r coils
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    2011 S4 Prestige 6mt Black
    2001.5 S4 EPL Stage 3 Yellow
    2005 S4 Avant 6spd Red
    Veteran Member Three Rings fitzS4's Avatar
    Mar 17 2007
    audi s4 chevy 2500 HD
    new york
    people live by the pss9's...and i think kw's prices just went up too.....when it is time i am goin to go with pss9's
    May 30 2008
    2017 Infiniti QX30
    Colorado
    OK... just got off the phone with H&R (Stephanie). As it turns out, these are the current springs on the car (pulled the wheel a bit ago and found out). I wanted to double check with H&Rand make sure they are the CORRECT spring... and they are.
    With all that said, they recommended I call and speak with Mike at AWE about shocks. I really like the ride height of the spring that is in the car... just don't like the mild bouncy bouncy. So... with all of that said... it looks like I am going to stay with the springs and get new shocks. For me, I think this will be a good setup. I just don't see myself adjusting the suspension at all once it is in... and did I mention I like how she is sitting now?
    Jan 08 2008
    2019 Tango Red TTRS
    Vero Beach, FL
    Quote Originally Posted by evil_O View Post
    Mike at AWE
    good guy and company
    -Matt
    2019 TTRS Tango Red
    2017 Ara Blue S3
    Dec 05 2006
    So. Cal.
    ok, Evil O, get some pics posted after the install.
    Registered Member Two Rings docjester9's Avatar
    Mar 30 2007
    St. Paul, MN
    Just installed PSS9s and the ride is still really smooth, but stiffens up in the corners when needed, but in my opinion the best bang for the buck is going to be Hsport sways, really flattened out the body roll in the corners at speed
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Will do. Already have some posted in another thread. The ride height won't change but the ride should. Here is the thread with pics...
    http://www.audizine.com/forum/showth...ghlight=evil_O
    I am going out soon to wash and what not. I will see if my fiance can snap some extra photos.
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    Yeah. Your ride height looks really good as is. I'm probably going to get H&R springs and a set of Koni adustable shocks when I can afford it. I just can't justify the price of coilovers when I know I won't ever adjust the ride height. Let us know what shocks Mike @ AWE recommends. I think Koni's are the only shocks available but I wonder if he'll say Bilstein.
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Quote Originally Posted by FastB7S4 View Post
    +1
    I was a little disappointed this morning when I talked with AWE. Not in them but rather the options that are out there. They were hoping to fit the car with Bilsteins but as it turns out Bilstein does not have an application for my car. They (of course) are not big fans of Koni. With that said they recommended COs... either H&R or PSS9s.
    Not liking that answer, I called and spoke with Koni. They indicated their sports are a great setup (of course) with the H&R sports.
    Talking with Koni about the drop, car, and my driving, they recommended adjusting the shock with 3/4 to 1 full turn (from full soft). If I set them on full hard 2-2.5 turns, I might rattle my teeth out.
    Sooooo..... I think next week, I will be ordering up a set of Koni Yellows.
    Is anyone currently running the Yellows with the H&R Sport Springs? If so... how soft/hard do you have it set? What is the ride like???
    TIA
    Mar 01 2008
    I posed this same question in another post a couple weeks ago. I got this response from likewater who has this set-up, except with h-sport sways as well:
    Quote Originally Posted by likewater View Post
    Well, the ride can be a little bouncy at times on some roads but otherwise it feels really good and I'm very happy with it. I think I would have preferred the coilovers in terms of the overall ride, but I have no way to compare the shock/spring setup to coilovers since I've never had them on my car. I also went with Hotchkis Sways front and rear and I'm sure that also makes a difference. I have my Koni's on the Medium setting and it's stiff but not overly so.
    Hope this helps.
    May 30 2008
    2017 Infiniti QX30
    Colorado
    Fast^^
    Thanks for the info. I wish I could ride in something comparable around here. I would like to know what he means by a bit bouncy at times. It can't be as bad as with the stock shocks.... I mean it would have to be better right????
    Mar 01 2008
    I think by bouncy he means that when he hits a big dip, there is a rebound effect that feels like you are kind of bouncing. I'm sure it's definitely not as bad as aftermarket springs with stock shocks. Your ride should be much better as well as handling. I think you'll be happy. I'm going to do the same when I can afford it. In the mean time, post up your impressions when you get them installed.
    May 30 2008
    2017 Infiniti QX30
    Colorado
    I think you are right. I think i will be more than happy...especially comparing it to what I have. I will most definitley post impressions. Should be in the next couple of weeks.
    May 30 2008
    2017 Infiniti QX30
    Colorado
    I have one other person double checking the availabilty of the Bilstein sports. I will let you know what I find out. If not.. Konis it is.
    Established Member Two Rings ichibunz's Avatar
    Jun 03 2008
    Danbury,CT
    Love my H&R and ride is great!!
    Senior Member Two Rings XwalkerX's Avatar
    Dec 04 2007
    2005 s4 avant
    tuffalo, NY
    i just put kw variant 3's on my avant and its sooo much better...
    2004 Audi A4 Ultrasport [daily]
    2001 911 Turbo [fast]
    2005 Triumph Speed Triple [faster]
    1995 BMW M3 [sold]
    2005 Audi S4 avant [sold]
