Results 1 to 8 of 8
Thread: shit HELPPPP!!!
    Established Member Two Rings dakine86's Avatar
    Dec 12 2007
    chicago
    shit HELPPPP!!!
    OKAY SO HERES THE LOW DOWN ON THE SITUATION. retarded buddy of mine went to fill my power steering fluid yesterday well.. he failed to notice it was clutch fluid... my pumps fritsing out locking up every 10-15 seconds then releasing to full power. i used a turkey baster too suck it out filled it back up with regular prestone steering fluid to get the crap out. but its still doing it does it need special fluid? and any tips on how to fully get that crap out? helppp pleaseee!
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: shit HELPPPP!!!
    Thats some horrible shit dude. Im thinking you might need to get a new power steering pump if things dont work out. See if you can drain the fuild out, and you HAVE to fill it with Audi PS fluid. And another tip, never overfill the PS fluid! Try to find the DIY on draining the fluid online, or you can disconnect one of the hoses, but my guess is that the damage is already done.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Dec 12 2007
    chicago
    Re: shit HELPPPP!!!
    Quote Originally Posted by biketsai View Post
    im HOPING not. it was about a 24 hour timespan since the fill and the suctioning out. im gonna be uberly pissed if i have to replace that pump.. any clue if theres a diy on here?
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Re: shit HELPPPP!!!
    The only easy way to change the pump is by tearing the front of the car off. It can be done from the service position (front slid a few inches forward) but it is difficult and time consuming that way.
    Yes, Audi uses special power steering fluid. Regardless of how much the fluid costs it is a lot less than a new rack. A good place to get a deal on a pump is http://toms4n.com/. I used them for mine.
    Jim
    I Do Werk.
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: shit HELPPPP!!!
    If you will need a pump, let me know, I have a brand new one in the garage.
    You just mixed 3 different hydraulic fluids together and they are all different.
    - VW Power Steering Fluid
    - Brake Bluid
    - Prestone Power Steering Fluid
    You definitely need a full flush. To flush it, you need to have the new OEM VW/Audi Power Steering Fluid or Pentosin CHF 11S or Febi/Bilstein Power Steering Fluid push out the old mixture.
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings jaredpgh's Avatar
    Feb 17 2005
    08.5 MS3 GT MGM
    Pittsburgh, PA
    Re: shit HELPPPP!!!
    it doesn't have to be the Audi fluid, it just has to be mineral based.
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: shit HELPPPP!!!
    It's not made by Audi. If it has an Audi/VW logo on it, it means its an approved product.
    Veteran Member Three Rings audinutt's Avatar
    Jan 11 2007
    2001 A8l 2001 A4TQM Avant
    texas
    Re: shit HELPPPP!!!
    Either VW/Audi fluid or in a pinch Mobil 1 synthetic trans fluid.
    I use the Pentosin 11s which is recommmended, you might get lucky but don't drive it till you flush the whole system with pentosin 11s or mobil 1 atf.
    -richard
    2001 Audi S8
    2011 Q7 TDI
    2001 A4 TQ Avant
