Results 1 to 8 of 8
    Established Member Two Rings OrangeWuN's Avatar
    Oct 10 2006
    Jeeps
    Vancouver, WA
    I want these wheels for my car... v.noob
    http://www.audizine.com/forum/showthread.php?t=213083
    would i need to buy anything for them to fit? spacers?
    im still on stock suspension, for at least another month
    Oct 10 2006
    Jeeps
    Vancouver, WA
    Re: I want these wheels for my car... v.noob
    47 views, 0 answers.
    Veteran Member Three Rings mwbunns4's Avatar
    Feb 20 2008
    2011 Audi S4 6MT, Audi A3 TDI
    Savannah, GA
    you would need some spacers. something like 16mm or so. not 100% sure but you will need some.
    Veteran Member Three Rings mattro's Avatar
    Nov 28 2007
    Moncton, NB, Canada
    if i'd run them i'd put 15mm spacers in the front and 20mm in the rear.
    bringing the offset to 35 in front and 30 rear... should look pretty good.
    S4
    This | is | where | people | usually | list | their | mods | separated | by | these | vertical | lines
    Sep 17 2006
    07 cbr600
    Quote Originally Posted by OrangeWuN View Post
    Member since 2006, 0 knowledge
    Senior Member Two Rings deux321's Avatar
    Oct 21 2004
    2001 a4 1.8tqms
    central cali
    yeah et50 is pretty craze!
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Sounds like 15mm spacers. A long wheel stud kit would be a good thing to install at the time too. With open ended lug nuts you can just slide the spacer on and crank the wheel down. Without the stud kit you'll have to figure out what length stud will work and then try to pierce the wheel, spacer, rotor, and hub.
    Jim
    I Do Werk.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by onemoremile View Post
    Exactly.
    15mm would put you at a nice stance and not mess with your rim centerline, thus pissing off your wheel bearings
