Results 1 to 12 of 12
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    need a decent writeup on how to install sub
    I'm still deliberating whether or not to sell or install hte sub i bought from Frimmel a while back. I haven't come across a good tutorial on how to install it. it's just a JL audio sub with an amp. i have no wiring, but all the necessary tools to do it. i have access to all the wiring i will need. anyone care to point me in the right direction? the only ones i saw were really crappy writeups with bad pictures
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    May 04 2004
    00 BB S4
    York, Pa
    Re: need a decent writeup on how to install sub
    Take it to a shop, or just start digging in there. Its very easy.
    I can help you through it if you need.
    00 S4 BB Stg3
    Stolen Tune|K&N|STACK|DAR|KW V1|VAST - MBC |JHM SS Knob - SS lines - FMIC - Shifter - Trans Rebuild - 2pcs Rotors|AWE DTS - Boost Guage - DPs |BW K04|Southbend Stg 3|ASP Cat Back|V1|034 Snub - Race Tranny mount - Street Motor Mounts - Intake Hose - DVs|HAWK HPS|APIKOL RDM|H Sport RSB|6000k HID|Mille 12"|Hifonics|Focal|WOTBOX|AVIC910
    Dec 11 2006
    Boston
    He needs your help, that is why he created the thread...
    Stage 3+ RS6's
    May 04 2004
    00 BB S4
    York, Pa
    Most useful post ever. WTF is your problem?
    I offered to help, I'm not going through 100 steps, but I'm sure he can get 90% of the way there and I'm happy to help, I've done pleanty of installs. I try to be helpful and you come in with a smart ass comment? Get over yourself.
    00 S4 BB Stg3
    Veteran Member Three Rings saucys4's Avatar
    May 30 2007
    San Diego/SF Bay Area
    Here are a few pics of my setup. To better assist you, how many watts is your system going to be? http://www.audizine.com/forum/showthread.php?t=204378
    J Fonz Stage II+
    Account Terminated Four Rings
    Aug 05 2007
    B5 Nazi Sled
    Indiana
    Quote Originally Posted by deb38 View Post
    Lulz
    Jul 07 2007
    Tempe, AZ
    i wire home theater systems, but this seems more complicated lol... so i cannot just run the sub inline with my rear deck speakers and hook the amp up to the sub? like take the wires from the rear decks and hook them to the sub, with the sub powered by the amp? fuck how do i get power to the amp then?
    Active Member Four Rings RogueStatus's Avatar
    Nov 13 2007
    B5 S4 Avant
    Boston
    maybe out of order but you get the idea...its real easy...
    -run a power cable from battery to trunk (w/out a fuse in it to start off)
    -buy a "line out converter" (if you have stock radio).
    -tap LOC into a stock speaker in rear (pos and neg)
    -run wires from LOC to amp (pos and neg)
    -mount a ground in trunk (shaving down to bare metal obviously)
    -plug in power and ground to amp.
    -run an amp turn-on wire from amp to under dash to the accesory wire of car (usually found in ignition harness)
    -wire amp to sub
    -put fuse in power wire near battery.
    turn on car/radio. no fire,then youre good haha.
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    the only thing that sucks tho is I'm assuming there is no way of adjusting your bass other than through your amp.
    2010 Brilliant Black/Magma Red S4
    May 04 2004
    00 BB S4
    York, Pa
    What deck are you using? You can always get a remote bass adjustment, depending on your amp.
    00 S4 BB Stg3
    Jul 07 2007
    Tempe, AZ
    i remembered,the cock who had the car before me put in infinity rear deck speakers in that are pretty beefy looking, but there are no amps for them, like hte stock boses had amps on each speaker. i looked at the amp, and it has 250 on it, which i would take as being 250 watts, and there's an output adjuster on the side. could i possibly just run the amp in line with these speakers and hook up power for the amp?
    Jul 07 2007
    Tempe, AZ
    anyone know if i can do this?
