Results 1 to 6 of 6
Thread: Clutch going?
    Registered Member Three Rings int2str's Avatar
    Jan 16 2007
    2002 Audi A4 3.0 Quattro (M)
    San Diego, CA
    Question Clutch going?
    Hey all!
    I bought a 2002 A4 3.0 Quattro 6-speed a while ago with 72k miles. On a few hard launches early on I noticed the clutch slipped a few times quite badly. Somehow recently it hasn't slipped much anymore, but I still suspect it's going - or at least I'm hoping.
    Now, at 95k miles on the odo, the car often shifts a bit rough. The new gear often engages with a "jerk" even with fairly delicate clutch work. Keeping in mind that I usually drive pretty, uhm, "inspired"?! But more importantly, I can feel and hear some "grinding" when I engage the clutch. The steering wheel will transmit some subtle vibes and I can hear a certain grind at a certain RPM range.
    I can make this happen parked in neutral as well.
    Here's my theory:
    The clutch is worn and adjusted itself to the max (our cars have auto-adjusting clutches, right?). Now the clutch plates don't really disengage completely sometime and cause friction at certain RPM.
    What do you guys think?
    Could it be my transmission itself being busted?
    Anything else that could be biting the dust?
    Center diff?
    2002 Audio A4
    3.0 Quattro 6-Speed
    RNS-E GPS, MP3 + Bluetooth
    19" VMR RS4 reps w/ Toyo T1R's
    LED tail lights
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: Clutch going?
    I believe that the "clunk" you hear inbetween shift and even with delicate clutch work is either a bad snub mount, either of the two motor mounts or the tranny mount. Hell, I wouldnt be surprised if all 4 mounts are completely shot.
    Look underneath the engine bay and see if you see some red fluid the motor mounts, and while you are under there check out the snub mount (it is probably crumbling away as I type).
    -Sami-
    Jan 16 2007
    San Diego, CA
    Re: Clutch going?
    Hmm, sounds plausible.
    Does anybody have a picture or diagram of the 3.0 motor where I can locate the snub mount and the motor mounts.
    Also, are they all DIY capable or do the motor mounts require shop attention?
    2002 Audio A4
    3.0 Quattro 6-Speed
    LED tail lights
    Veteran Member Four Rings 04QuattroTurbo's Avatar
    Jun 15 2008
    Fairfield, CA
    Re: Clutch going?
    The grinding noise while shifting or while the clutch is engaged on other cars is usually the clutch throw out bearing.
    2004 (B6) Audi A4 Quattro 1.8L Turbo 6-Spd Man
    Premium Pkg, Cold Weather Pkg, Ultra Sport Pkg, Lighting Pkg, Sirius Satellite. Dolphin Grey
    APR Stage I, K&N 33-2209 Drop-in filter, Apr Snub mount, RS4 pedals
    VIN Decoded: http://www.motoverse.com/tools/vinDe...LC68E84A219972
    USP Member 110
    WANTED: Roof Spoiler, PM me with Offers.
    Jan 16 2007
    San Diego, CA
    Re: Clutch going?
    Are the snub mounts the same for the 3.0 as the 1.8?
    2002 Audio A4
    3.0 Quattro 6-Speed
    LED tail lights
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    Re: Clutch going?
    Quote Originally Posted by int2str View Post
    Yes.
    Stern snub mount
