Results 1 to 12 of 12
    Sep 17 2007
    Olympia, WA
    Alarm stopped working
    I NOTICED THAT MY ALARM STOPPED WORKING.
    Normally when I use my remote to lock the doors, I will get a single beep. I do not get this anymore.
    I also tried my panic button, and this does not work either. (There is no sound)
    My remote works fine.
    What could it be?
    Veteran Member Three Rings freeflow's Avatar
    Apr 18 2008
    2007 A4 2.0T
    Manhattan/Miami
    Re: Alarm stopped working
    that happened to me once... check all the doors, trunk, and hood, as it will not sound if anything is left ajar. my hood somehow popped without me knowing and i just closed it and then got the beep
    2007 A4 2.0T - Brilliant Black on Black - Premium - 5% tint - 7 spd multitronic - APR 93/Stock - RS4 Sway - FLY's LEDs - CC'd - LED License Plate - Interior xenonmatch - Hoen Fogs - Debadged - VAGed
    Wish list: Stassis Coils, Carbonio CAI, HFC, 19" R8s, Ecode CF Hood, CF Rear Wing, ECS Blackout RS4 grille, S4 blades,
    Sep 17 2007
    Olympia, WA
    All of the doors and hoods are closed.
    What else can it be?
    Apr 18 2008
    2007 A4 2.0T
    Manhattan/Miami
    that fixed it for me... might be vag-com time.
    Sep 17 2007
    Olympia, WA
    What is vag com?
    Veteran Member Four Rings Pr0n's Avatar
    Jul 10 2007
    Bus pass + 2004.5 A4 1.8TQM6
    trunk
    Quote Originally Posted by moustafasou View Post
    What is vag com?
    http://www.ross-tech.com/vag-com/index.html
    2004.5 B6 A4 6 speed Transmission 02X AWD Quattro GJW + rear diff for sale
    Red on Black Team Member #1 (sorry you can't join, invite only)
    Red on Black leather interior makes me feel special
    Stage 0 minus - .5
    Running an ST (small turbo) making mine the slowest B6 A4 "evar!"
    Aug 26 2005
    What could it be?
    VCDS/VAG-COM is a PC based tool to access the controllers used in the Audis electrical and engine controls. You can scan the comfort/convenience module for any stored fault code/s that may exist regarding the alarm horn, if there is a DTC, it may pinpoint why the alarm horn isn't working.
    Dec 06 2007
    ^^mine doesn't work either!
    -Kirk
    BetaAlphaTau Member #58
    Veteran Member Three Rings evola4's Avatar
    Sep 03 2007
    05' Audi A4 Ultrasport
    henderson, nv
    I have a the same problem and vag'd my car to find that there is a light sensor in the trunk that tends to be the culprit and makes the ecu think that the trunk lid is open. Mine is sporadic so sometimes when it's real hot out (i live in the desert) and I open my trunk it will then cause it to mal function. I have no idea where the sensor is otherwise I would fix it. When it does happen I can still lock my doors w/o the alarm being on. I just kill my engine w/ my flashloader for safety.
    WTB K04 turbo ASAP
    http://etektuning.com
    Sep 17 2007
    Olympia, WA
    I did hear some weird noises in my trunk. I stuck my head in there and it was coming out of the passenger rear light area.
    Is this a sign of something?
    Senior Member Two Rings NoUDont's Avatar
    May 16 2007
    South Florida
    lol...my car has the noise...i thought it was coming from the gas cap area and my alarm isnt working either...bah
    Oct 29 2005
    10speed
    San Francisco, CA
    mine does this sometimes also... but its because my rear right door's control module is shorting or somethign
    - Clint
