    Registered Member Two Rings R4zzleD4zzle's Avatar
    Mar 04 2008
    '01 S4
    San Antonio
    Lightbulb Tiptronic Tranny Issues
    This is not a thread asking for help, just a thread about a personal experience that I want to share with others to possibly help them out in the long run.
    My vehicle is a 1998 1.8t with tip tranny.
    Out of the blue when I would drive on the highway the car would beep & on the info display it would say to check the transmission & had the tranny pic. This happened once or twice before the tranny decided to completely give out on me. When I would hit the gas it was like I was trying to accelerate in the highest gear & the pick up was awful. I tried to shift down the tip tranny but there was no reaction after countless attempts. I pulled off to the side of the road & shifted it into neutral and park then drive again thinking it might reset the tranny but only gave me a large jerk. The car would then die & after start up I would press the gas slowly but once it got over 1250rpm the engine would shut off & would not allow me to hit the gas whatsoever. When shifting into reverse, the gear would not engage & still jerked when shifting into other gears. Towed the car to my new mechanic who had just replaced my timing belt & rebuilt the heads & valves after my timing belt broke on me a couple weeks prior (A job that cost me $3500 & carless for over a month). This guy was a mechanic for VW for 12yrs btw. After he looked at my car he said the whole tranny was going to need to be replaced & was going to cost about $4500. I was frustrated & very short on cash after just buying this car & have two main issues with the car in less than 2 1/2 months. Spoke to several other local mechanics (one being a good family friend) who did not get a chance to look at the vehicle but they said it sounded like the torque converter was blown. Took the car to a very respectable mechanic to try what he had to say. Turns out that the problem was just my tcm (transmission control module) which only cost me $210 with the new part & labor! At first the car would not shift into reverse but after a couple days & playing with the reverse gear began to engage. The mechanic told me to keep working the tranny into drive then into reverse every chance I get to work the valve. He said normally the valves get damaged when a TCM goes out but I guess I was just lucky. I think it might have just been it took a while for the car to recognize the new tcm & thats why the reverse did not work at first (my only guess). I have been driving now with the new tcm for a little over 1500 miles (about a month & half) & there are no problems whatsoever.
    If you're experiencing tranny problems, don't take the first guys word for it. Take it to another shop, & get that second opinion.
    Guess you can't trust all those old mechanics who took care of you before!
    Hope this helps some of you guys out.
    Nov 17 2004
    The Audi and a 56 Buick
    KC
    Re: Tiptronic Tranny Issues
    Dude....feel your pain...but mine was after 9 years of ownership. I am going to check into the TCM right now as my trans is having shifting issues.
    Good luck...
    Veteran Member Four Rings MattzWarsteiner's Avatar
    May 22 2008
    is full of crap
    sandville
    Moral of the story - don't always take the word of mechanics. Agreed R4 D4.
    Unless it is a common failure, they have to guess a lot and sometimes the guesses are wrong.
    We pay extra for the wrong ones.
    I had a Tip problem and thought is was the TCM since there was water in the pass floor pan.
    Gear display light up all ranges and had only 4th gear, the infamous limp mode.
    Mech told me I needed a new transmission. Thanks buddy.
    A visit to a Euro shop said buy a new TCM. Thanks alot fellas.
    I VAG'ed it and trouble shot the thing myself and found the #6 solenoid had an intermittent short.
    Measured that circuit and sure enough that was true. 10 ohms to ground.
    Unplugged the TCM. Still there. Unplugged the harness connector at the trans. Still there.
    Aha! Don't need to go mucking around the magic gearbox.
    Don't need to spend my money on an unneeded TCM.
    I had a shorted wire on that circuit. Easy fix.
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    this post was made nearly a year ago :P
    TEAM|AXION
    May 22 2008
    is full of crap
    sandville
    Wow.
