Results 1 to 19 of 19
Thread: anodizing FMIC
    Dec 03 2005
    2 pedals 1FG
    connecticut
    anodizing FMIC
    Thinking against painting my FMIC with Eastwood's Radiator paint and anodizing my FMIC.
    What type of anodizing is best for a FMIC? I'm thinking Type III (Mil-A-8625). Do I want non-dyed or dyed?
    http://www.difruscia.com/MIL_A_8625_F.pdf
    Why? I want my FMIC to be black. I don't want to be able to see it through the lower grilles of my bumper. I don't like the flashy look.
    Thanks in advance. I'm going to post in the B5 forum too.
    -Doug
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: anodizing FMIC
    I've heard that it will reduce the effectiveness for cooling, but I bet it's very, very minimal.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Veteran Member Four Rings sean1.8t's Avatar
    Sep 17 2006
    I wish I had a garage.
    SLC, UT
    Re: anodizing FMIC
    just paint it. i used the eastwood rad paint and it's holding up perfectly after 2 months. IAT's are great also.
    it's said that it will actually help heat disipation(and im not just talking about what it says on the can lol)
    Current:
    '16 Mercedes-Benz C450 "AMG": Stage 2 w/downpipes & 19" BBS CH-R's
    '88 Harley-Davidson Sporty 880: 1200 bottom - Ported & Cam'd top - S&S In - Screamin' Eagle Out
    Previous:
    '02 Audi A4 1.8TQM: Full GT28RS on meth w/everything else.
    '01.5 Audi A4 1.8TQMS: Tune and exhaust.
    '99 Subaru Legacy Outback wagon Manual: Bone stock.
    I don't even want to remember the others
    Mar 11 2008
    B7RS4 & e46Ms
    Re: anodizing FMIC
    I've been painting my fmics for years... logged IATs before and after and never had a problem. no special paint necessary, just enough to get the desired effect.
    Buncha motorcycles
    Memphis, TN
    Re: anodizing FMIC
    making a sleeper huh? i doubt it would hurt any as long as its put on light, but im sure u got it handled!
    APR Stage 2/AWE Intake
    Veteran Member Four Rings jcg05c's Avatar
    Jun 07 2007
    350z
    orlando
    Re: anodizing FMIC
    Is the Military going to come to my house after reading this MILITARY Document:) Black would look good on your car if i remember correctly what your car looks like.
    19in Privat Netz 10mm front/17.5mm rear
    Apr 1+
    TurboSmart Bov/Dv
    Roof Spoiler
    Jeff Lee Test Pipe
    NS Boost Gauge
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: anodizing FMIC
    Oh yeah. Super Sleeper Avant! That's my style.
    If I do wind up painting with the Eastwood paint it'll be very thin layers. There was some talk of this in the B5 forum the other day.
    Going to call around and see what the going rate is to get this anodized first.
    Quote Originally Posted by jcg05c View Post
    I found that through google so I presume its cleared for public use. haha. Its a spec anyway so it should be available to the public.
    my car: http://farm3.static.flickr.com/2187/...500853495b.jpg
    -Doug
    Registered Member Two Rings
    Jun 12 2008
    900hp '99 Camaro SS / '04 A4Q
    So*Cal
    Re: anodizing FMIC
    It's a Mil Spec...nothing secret in it. They are military standards on how certain things are to be done by military requirements.
    900hp '99 Camaro SS: - Slightly modded
    '04 B6 A4 Quattro - Stock for now
    Veteran Member Four Rings vdubstreets's Avatar
    Feb 20 2007
    02 a4, 97 Gti, 90 wrangler
    ct
    Re: anodizing FMIC
    you can paint the entire core fins and all with the eastwood paint?
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Re: anodizing FMIC
    if you anodize, go group 3 since its not just cosmetic and actually is hard enough to prevent most damage done by sand/ most little rocks... wrc cars have been using it for years for this reason and mines done that way too
    Senior Member Three Rings B6 Dude's Avatar
    May 31 2008
    B6 Avant, Shelby Cobra, Stang
    Palm Beach, FL
    Re: anodizing FMIC
    Can you even get that specific type of anodizing done? The anodizing shops I've dealt with just know "anodizing", and not specific types.
    Anodizing generally does reduce the thermal conductivity, and quite a bit, but in the actual application, it may not be a problem and there may be differences between the various types of anodizing. Google for a company called "caswell plating" (or something like that). They should be able to inform you for sure. Also, I remember wikipedia has some info on anodizing.
    May 31 2008
    Palm Beach, FL
    Re: anodizing FMIC
    Interesting thermal conductivity info here too... http://www.frostytech.com/articleview.cfm?articleID=233
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: anodizing FMIC
    As long as the paint is applied in very thin coats I don't see why the Eastwood paint would be a problem. I am still going to get some quotes to anodize my IC.
    To Jake's point, anodizing Type-III will be more durable than paint. It is, effectively, a hardcoating. Anodizing is also a very thin layer (0.001 inch) so you won't really see any losses in cooling effectiveness. Same goes for paint if you put a very thin layer of paint on.
    -Doug
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: anodizing FMIC
    Go with type III hard anodizing. not the dye shit or paint. The core takes a beating on the road. Hard coat anodizing will provide better corrosion resistance and high durability. I can get your core anodized in Berthoud CO for $50.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: anodizing FMIC
    Quote Originally Posted by CO AVANT View Post
    If I can't find anything by Friday I'll be calling you and shipping you my core.
    -Doug
    Veteran Member Four Rings InTTruder's Avatar
    Aug 21 2007
    2019 VW Tiguan
    Kennesaw GA
    Re: anodizing FMIC
    Increases delta-T cross the core, cuts down on cooling enough to matter. Question: WHY?
    The Spartans do not enquire how many enemy there are. They enquire only where they are.
    Sep 17 2006
    SLC, UT
    Re: anodizing FMIC
    Quote Originally Posted by InTTruder View Post
    source?
    Current:
    Previous:
    Veteran Member Four Rings GTMRS4's Avatar
    Sep 14 2006
    New York, NY
    Re: anodizing FMIC
    just go and get the evo comp fmic andonized black
    BetaAlphaTau # 18
    2007 Q7 4.2 Premium
    2007 997 Midnight Blue
    2005 Lotus Elise Magnetic Blue
    2004 B6 APR STGIII+ (SOLD but not forgotten)
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: anodizing FMIC
    Yes, but I'm keeping my ASP intercooler. Its going into the mail today and Jordan is getting is anodized for me.
    -Doug
