Results 1 to 18 of 18
    Veteran Member Four Rings Jet Jockey's Avatar
    Jun 17 2004
    2017 B9 A4 Quattro/DSG/Technik/S-Line... 2004 B6 A4 1.8T Quattro race car
    Montreal, Canada.
    UPDATE: The new pedals and their installation related problems (new floor)…
    Well this turned out to be more problematic then we thought. Because the master cylinders are installed aft of the pedals it increases the total length of the unit by ~ 3.25 inches we quickly realised that if we installed the new pedal set as far back as we could on the original OEM floor, the pedals would be too close to the driver. This would be unacceptable to the driver’s leg angles (knees really bent).
    The solution was to make a new floor which we had to do anyway because the OEM floor is not strait but undulates with up to 2 inches in depth differences in some spot. To get what I would say is an acceptable leg position for me as the main driver we raised the floor by 4 to 6 inches depending on where you measured from the OEM floor.
    So here we go…
    You can see that attaching the master cylinders to the pedal set add about 3.25 inches in length overall. We also need room back there to add the fittings for the hard lines for both the front and rear brakes and for the stainless steel line for the clutch.
    To make the new floor we used a 6061 aluminium plate a ¼ inch thick and we cut it to the shape required for it to fit in place.
    To secure the aluminium plate in place we welded a right angle of steel to the tranny tunnel.
    We did the same thing on the left side approximately where the OEM dead pedal used to be located.
    Now to make sure the new floor wasn’t going to flex and move under heavy braking activity we braced the end closest to the driver with another right angle piece of steel that is welded to the rocker panel side and the tranny tunnel side. We also used a square tubing in the middle welded to the floor to avoid any vertical movement.
    Everything was checked to be level and properly fitting before the final assembly.
    Once the fitting was successful and the aluminium plate removed the whole assembly was cleaned and primed.
    Once the primer had dried, several coats of red paint were added.
    Here’s what the semi finished product looks like with the pedals in place.
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    Re: UPDATE: The new pedals and their installation related problems (new floor)…
    how are you financing all this? drug trade?
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Good lord
    Veteran Member Three Rings J3RR3L's Avatar
    Dec 10 2006
    2003B6A4
    this is beyond a hobby to you
    Marin, Ca
    So freakin' awesome man. But my pedals are clearly better than yours.
    J/K
    -Tony
    '68 Datsun 520
    '71 2002 Tii
    '22 Mercedes-Benz Sprinter
    '22 RS6 Avant
    '20 L405 RR P525
    Senior Member Three Rings demea's Avatar
    Jun 12 2008
    2004 A41.8q | 05 Tr. Blzr LT
    Warminster, PA
    On an unrelated topic...
    The 1/4 mile in 13.3 sec. @ 107.3 MPH! Possibly the world's fastest K04 powered A4
    Boy is that sad to think that all the $$$ that goes into the mods and the claim for the WORLDS FASTEST is 13.3 :(
    Man we should have bought faster cars ;)
    Veteran Member Four Rings Groove1797's Avatar
    Apr 08 2004
    Your mom on a unicycle
    Eating Cheese Curds
    That is before it was gutted. 13.3 on basically full weight is fast as hell for a ko4
    4Runner, Rs5 and Alfa Guilia QV
    Nov 14 2006
    600hp glorified Beetle, e-tron, 1G DSM
    Gig Harbor, WA
    Quote Originally Posted by demea View Post
    That's pretty damn fast considering his turbo was barely larger than stock.
    And speaking of the engine (maybe I missed it in the other threads), what are the plans for the engine? Are you going to keep the ko3 (as per class regulations?), or are you planning on moving up to a larger unit?
    I can't wait until this car is "done".
    -Darrick
    Dec 06 2007
    ur crazy man crazy! looks good though!
    -Kirk
    BetaAlphaTau Member #58
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by Capt. Obvious View Post
    For now there are no engine plans. I will keep my K04 set up until I see how the car performs on the track with its new mods.
    I still have to work with STaSIS in finishing my suspension mods and once the chassis/suspension stuff is all sorted out I will perhaps attack the motor.
    Dec 06 2007
    ^^how long till ur finished with the weight reduction and suspension??
    -Kirk
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    How are you going to control the throttle?
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by AudiA4Turbo22 View Post
    I still have so much stuff to install and do tto the car that time and money are a problem.
    For now I want to finish the brake/pedal system, the Aim data logger with its GPS and paint theinterior/roll cage.
    The rest will have to wait until fal/winter.
    I still have the fuel cell, the new exhaust and some suspension components to install.
    Jun 17 2004
    Montreal, Canada.
    Quote Originally Posted by dirtybrd View Post
    You'll see in the next post perhaps tomorrow.
    Dec 06 2007
    WOW MAN! so this turned into a year long project huh? Power to u man, all i know is ur gonna be a featured audiziner and be on the cover of Eurotuner!
    -Kirk
    Jun 12 2008
    Warminster, PA
    Sure, no doubt. I'd love for my A4 to go that fast.
    THIS IS NOT KNOCKING YOU!!!
    I just think its funny that the "worlds fastest" is a 13.3 ET.
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    awesome
    Some fast things and some slow things
    ~Josh~
    Jun 17 2004
    Montreal, Canada.
    I say "possibly" and "with a K04". Two very important statements.
