Originally Posted by
AudiA4Turbo22
^^so why is it a joke?? please explain, i don't understand why half the Audi World uses this setup and sees a big improvement in handling and they're all imagining it?? i understand that they aren't coilovers, but they still are a decent improvement, matched with an RS4 sway bar, it should be much better!
Because race springs are too low, even for Bilstein shocks. At such low ride heights, the suspension geometry is moving way out of optimal range, and when you go over bumps or take sharp corners, the wheels will tow-in or out (
depending on the alignment), which becomes unpredictable, and if it starts happening in the back, it can seriously hurt stability and induce snap oversteer. Bump steer, suspension bottoming out, and tire edging (
not riding on the full contact patch) all make for shitty handling and less traction.
And yes, people with this setup (
hardly half of AW, way to exaggerate), are mostly imagining better handling, simply because they think less body roll, less suspension compliance = better handling. The sway bar upgrade is also a compromise. It helps reduce understeer, but at what expense, did you ever ask yourself that? I'll tell you what price you pay for less understeer; less traction from the rear wheels when cornering or when going over uneven surfaces. Maybe you should think about why some race cars, instead of having bigger/stiffer sway bars, don't have them... at all.
