Results 1 to 24 of 24
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    ALL members with Vag-com/ PALM IIIc VAG-OBDII/ Post ALL CODES YOU KNOW OF!*EDIT*
    I know there are millions of post of vag-com but is the PALM IIIc VAG-OBDII the same thing or no. I'm getting mine in today and want to do seat belt chime delete, the turn signal on only when turning, and the city light delete. Please provide my the info or if this is the same as the other post please provide me the link, thank you
    ***EDIT: FOR THOSE WHO HAVE THIS PLEASE POST ALL RE-CODES, DELETES, ECT THAT YOU KNOW!!! THANKS A LOT***
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Re: ALL members with Vag-com/ PALM IIIc VAG-OBDII
    the control modules and adaptation channels you access are the same. the exact procedure to do this are not since the applications are different.
    Oct 08 2007
    Syracuse, NY
    Ah..well anyone with the PALM IIIc VAG-OBDII please help me before i get this is around 3pm est
    Veteran Member Four Rings airbornerifleman's Avatar
    May 20 2008
    2013 Passat TDI
    Toronto Ontario, Canada
    I did not know you can delete the city lights with vag-com
    Oct 08 2007
    Syracuse, NY
    Quote Originally Posted by airborneriflema View Post
    thought there was a code so only the bixeon would be on and the tun signal and city light would be off? may be wrong. but i do need all help on the palm vag product a.s.a.p if anyone can help!!
    Nov 12 2007
    Grand Junction, CO
    Will you be able to clear/read codes with that?
    Oct 08 2007
    Syracuse, NY
    Quote Originally Posted by AudiWxGuy View Post
    yes
    Veteran Member Four Rings ABanT's Avatar
    Aug 07 2007
    B7 ABT Avant
    Did you purchase that device through the group buy? I was under the impression that it wouldn't be able to read codes and what not on our cars?
    Changing the lights to amber, seat belt and that jazz would work though.
    Oct 08 2007
    Syracuse, NY
    not through the GB but same thing from Adam. All i need it to do it erase the check engine light and what u listed. so i hope it can do the erase check engine light(due to my chip)
    Aug 07 2007
    B7 ABT Avant
    Hmm.. you might be out of luck on the engine light thing. That should be controlled by the CAN BUS system and that device insn't compatible with that system.
    Here's the original link to the group buy and in the first few posts someone asks that question.
    http://www.audizine.com/forum/showthread.php?t=201612
    But I might be mistaken, maybe it isn't controlled by the CAN BUS system.
    Oct 08 2007
    Syracuse, NY
    Quote Originally Posted by ABanT View Post
    hmm then im gonna have to get the cel delete for $59 added onto my chip...I'll play around with it tonight and leave feedback for all i guess...
    Oct 08 2007
    Syracuse, NY
    I think you can tho:
    "other then the fairly in depth list of capabilities posted in the OP?
    ...if your honestly asking what a vag does in general, im not sure youd have much use for one of these in the first place to tell you the truth...
    its a diagnostic tool. this one in particular...for what its worth in size and convenience, is GREAT for those pesky CELs, and can clear them on the run (even when your on the freeway heading to work! )
    VAG owners know, check engines are a fairly normal thing with own wonderful ECU of a brain.
    it also allows for vag mods like the fog mod, or window roll-down on b6s for example...
    ...and can log certain blocks for more advanced modders/VAG owners..."
    Nov 12 2007
    Grand Junction, CO
    Re: ALL members with Vag-com/ PALM IIIc VAG-OBDII/ Post ALL CODES YOU KNOW OF!*EDIT*
    let us know how it works!
    Oct 08 2007
    Syracuse, NY
    ok just got it in...will write a write-up in the coming days.Wish me luck
    DUH! an Audi
    los angeles, CA
    whats a vag-com??? I never heard of that, I have heard of VCDS
    Oct 08 2007
    Syracuse, NY
    Quote Originally Posted by Quattro View Post
    funny
    DUH! an Audi
    los angeles, CA
    haha i know, I am jping...vag com is no longer called that its VCDS now.
    also for the basic codes you can go to the FAQ, it has the ones you might need.
    On a side note, is the palm a full version of VCDS (capable of data logging, etc) or is it similar to the eBay one? and can only do basic functions AND is the palm can bus?
    Oct 08 2007
    Syracuse, NY
    ask Adam@SPP i literally just got it and ill try it out tonight. I'm at work i just know it was delivered
    Oct 08 2007
    Syracuse, NY
    Vag-Com Codes
    Euro Headlights & DRL
    Module 09 (Central Electrical), recode to ###XY, where:
    X = DRL
    0 – Halogen without DRL
    1 – Halogen with DRL
    2 – Bi-Xenon with DRL
    3 – Bi-Xenon without DRL
    4 – Bi-Xenon with DRL / tail light / license plate light
    Y = Locale
    1 – Rest of World / Nordic Countries / Denmark / Croatia / Baltic Countries with Bi-Xenon
    2 – Nordic Countries / Denmark / Croatia / Baltic Countries without Bi-Xenon
    3 – USA / Canada with Bi-Xenon
    4 – Canada without Bi-Xenon
    5 – Special Vehicles
    *Bonus 1* Enable Dashboard Headlight Indicator
    Module 17 (Instruments), recode to ??###, where ?? = [existing 2 digit value - 2]
    NOTE - This mod tested on bi-xenon cars only; halogen cars may not work as intended.
    ok im trying to figure where i enter the code for bi-xeon without DRL and also whats the code to disable turn signal to only be on when blinker is set?
    Oct 08 2007
    Syracuse, NY
    ok Got the amber blinkers to only be on when they are activated to turn and the seat belt charm is disabled!! :-)
    Aug 07 2007
    B7 ABT Avant
    So were you able to clear your cel?
    Oct 08 2007
    Syracuse, NY
    Hasn't been on in a few days it will come and go due to the chip. So once its back on i will let you know. But seatbelt chime delete and turn signal is great. Still trying to figure everything out then i'll do the write-up
    May 20 2008
    2013 Passat TDI
    Dude you'r a four ringer, I hope you'r joking. If not got to www.ross-tech.com.
    Oct 08 2007
    Syracuse, NY
    he was lol
