Results 1 to 13 of 13
    Veteran Member Three Rings ThePaintballGuy's Avatar
    Mar 14 2007
    Phoenix Arizona
    Exclamation Running SUPER lean when W/M kit kicks in....
    Ok, So I got my A/F gauge installed the other day and tonight I got it all calibrated and working correctly. Then I went out on a test drive. What I saw is REALLY scaring me.
    When I am just cruising around my A/F stays around 14.3-14.5 which is pretty much were it should be. However as soon as I get on it and the W/M comes on my A/F drops down into the 10.2-11.2 range!!!! THAT IS LEAN! This can not be good for my engine. I am almost thinking about taking it all out of the car so i don't blow something up! Should I be worried about this? I need your opinions.
    Josh
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    Re: Running SUPER lean when W/M kit kicks in....
    Quote Originally Posted by ThePaintballGuy View Post
    Josh
    ummm 10.2-11.2 is rich.. Stoich Cruising is 14.8 If your AFR goes over 12.3 Then its going lean.
    Mar 14 2007
    Phoenix Arizona
    Oh... I thought it was the other way around... LOL. Nevermind then... I guess I am a retard. HAHA. now if I am cruising at 14.3-14.5 is that ok? Or should I go into vagcom and lean it out a bit?
    Josh
    Long Island, NY
    you have to log the car and see what is going on with timing and IAT also before you start leaning stuff out. Also you have to check first that WI is working properly
    Veteran Member Four Rings Evilevo's Avatar
    May 26 2008
    2018 TTRS, 2014 Q5 TDI, 2020 Supra, 2022 F150, 2004 V70R
    MD
    You cant control part throttle i dont think. The ECU trys to hit Stoich which is 14.8 IIRC
    Veteran Member Three Rings michael66899's Avatar
    Oct 26 2006
    A lot of B5 S4's
    WA
    I'm no expert on W/M injection so maybe someone else will chime in, but from what I recall when the W/M comes on it causes a false rich reading when using a downstream A/F gauge...I just can't remember why though.
    Dec 06 2007
    Calgary, AB, Canada
    Stoich is actually 14.7
    You will run a little richer with W/M, and if you are getting good timing, low IAT's, etc, you can pull some fuel so that you're hitting 11.8-12 under WOT.
    Dec 03 2007
    Potomac, MD
    lean that sucker out!
    Feb 17 2008
    Ottawa Ont.
    dont touch it. its fine.
    Nov 17 2006
    b5S4, b8.5 Allroad
    Las Vegas
    if you are running rich with w/m injecting, advance timing!
    Veteran Member Four Rings McKennaS4's Avatar
    Sep 25 2006
    2500 dodge ram diesel
    Boston, MA
    this whole thread is hilarious in that there is so many confused ppl blurting stuff out. scary scary stuff haha
    01 Casa sedan 6MT, sport, cold
    Senior Member Three Rings BlackS4TT(Josh)'s Avatar
    Jan 24 2006
    Ohio
    Josh....sell your car.
    B7 S4 Avant
    Mar 14 2007
    Phoenix Arizona
    LOL, there are a lot of different opinions. And why sell my car?
    Josh
