    Established Member Two Rings stifler474's Avatar
    Mar 15 2008
    Santa Barbara, CA
    resonator delete
    has anyone had a resonator delete? if so does it sound better to you?
    Silver B7 2007 A4 2.0T Quattro
    30% Tint
    De-badged
    Hoen Xenonmatch lights
    Clear Corner Mod
    Carbon Fiber B Pillars
    Colormatched Sidemarkers
    (H&R springs, and 19" rims soon to come...)
    Veteran Member Four Rings RedS-line's Avatar
    Mar 19 2008
    2019 S5, 1990 944 S2
    Re: resonator delete
    i read somewhere on here that the resonator eliminates drone and deleting it will only increase drone, not deepness of sound. still an idea tho. can the resonator be simply pulled out or do u have to cut it off an replace with new pipe?
    2019 S5 BO.SS
    1990 944S2 Cabriolet
    2009 R8 6 Volt :)
    Registered Member Two Rings WhiteVenomA4's Avatar
    May 23 2008
    B7 Audi A4 '08 S-Line Ibis
    Los Angeles, CA
    For RES. Delete on a turbo.. wont make much of a difference. [Stock]
    RES. DELETE on non-turbo .. sounds loud [Stock]
    Muffler/Tips with RES. Delete will sound clean. [Custom Piping]
    I just got mine done.. Quad Exhaust. with RES. Delete. My car is new.. i'll need to break it in.. then remove my CATB. to get it even louder.
    '08 A4 2.0T SLine
    White on Black. 15% Tint All Around.
    5% SUN STRIP
    Quad Muffler/Tips MagnaFlow Exhaust + Custom Piping. (Including RES. DELETE)
    (Work in Progress)
    Registered Member Two Rings ytlee89's Avatar
    May 04 2008
    Diamond Bar, CA 91765
    I have a customized downpipe with creative testpipe and no res. Sounds much louder than w/res. Only neg. thing is that it smells awfully bad. Smells literally like a bus....
    Veteran Member Four Rings Fobia's Avatar
    Oct 04 2005
    Minnesota
    2010 ibis white s4
    CTS Turbo intake
