Results 1 to 11 of 11
    Sep 23 2006
    Houston TX
    looking for carrier and caliper bolt torque specs
    I've found some variability in front and rear caliper and carrier bolt torque specs. I'm guessing some are for B5. Anyway what I have now are:
    Front carrier bolts: 120 ft/lbs
    Front caliper bolts: 60 ft/lbs
    Rear carrier bolts: 75 Nm
    Rear caliper bolts: ?
    I should also mention, front will be upgraded to Brembo 4 piston 355 and rears are OEM B6 S4.
    Do these sound correct, and what about rear caliper bolts?
    Thanks
    Veteran Member Four Rings CO AVANT's Avatar
    Feb 12 2004
    '03 B6 Avant, '15 B8 A4, '14 S8, '15 Duramax
    Everywhere
    Re: looking for carrier and caliper bolt torque specs
    As the saying goes.....tight is tight Many parts on this car don't need to be torqued down to "spec". With that big of calipers front and rear I'd upgrade my master cylinder if I were you. If I went S4 rear calipers, i'd have done that.
    Sep 23 2006
    Houston TX
    Quote Originally Posted by CO AVANT View Post
    Ha, I like "good and tight" just as much as anyone else. I'm just being anal at the moment since I recently broke a suspension related bolt without even trying. Drilling that out was not a good time. I know these bolts can handle it, just trying to get a number to be safe.
    Master cylinder should be fine. The front Brembo kit was designed for stock mc, and JJ experimented a while back with upgraded S4 mc on S4 rears and found no benefit. I'll keep it in mind though since every setup is a little different.
    Feb 12 2004
    Everywhere
    there's no problem being on the safe side ever.
    Feb 12 2004
    Everywhere
    I'll grab my bentley today and check though for you if someone doesn't beat me to the punch...
    Sep 23 2006
    Houston TX
    would definitely appreciate it
    Veteran Member Four Rings JBM's Avatar
    NorFOLK, VA
    75NM is for the rear
    "Give a Man a Fish, Feed Him For a Day. Teach a Man to Fish, Feed Him For a Lifetime"
    '02 B6 1.8T, UnitedMotorsport Tuned FrankTurbo L21, 550CC, 3" MAF, BB Intercooler, 007, 034 HFC, Neuspeed Exhaust, B5 S4 Brakes, KW Suspension, S4 Recaro, and the list goes on.
    Buncha motorcycles
    Memphis, TN
    tighten the shit outta it! been working fine for me for 40k miles!
    APR Stage 2/AWE Intake
    Sep 23 2006
    Houston TX
    yeah, that's all I did in the end. They're on and definitely kick ass. Pics tomorrow.
    Senior Member Three Rings CapstoneJHS's Avatar
    Nov 12 2006
    '06 A4 2.0T Quattro
    Marysville, OH
    Haven't you guys ever heard of tightening things to German Spec?
    "Guten Tight"
    Oct 29 2005
    10speed
    San Francisco, CA
    Ive done like 4 brake jobs and tight does the trick.
    - Clint
