Results 1 to 9 of 9
Thread: Lost Key?
    Established Member Two Rings lak2881's Avatar
    Mar 12 2007
    A4 B7 Sline Ti pkg.
    Lost Key?
    So i think i lost one of my keys. I'm hoping it will show up but if it doesn't where is the best/cheapest place to get a new one. I see them on ebay sometimes but where could i take my key and get it cut/programmed other than the dealership?
    2010 A4, 6sp quattro, Sport package, Bluetooth, Homelink.
    2007 A4 S-Line Ti Pkg 2.0t 6sp fronttrack, H&R Sport Springs, H&R rear sway bar, Front filler plate, debadged, 35% window tint, REVO, 10mm front 12mm rear H&R spacers.
    2004 A4 1.8t 5sp fronttrack, H&R sport springs. Forge diverter valve.
    Veteran Member Four Rings Erocko's Avatar
    Feb 16 2008
    Honolulu, HI
    Re: Lost Key?
    I had a third one cut at the dealership. It shouldn't be too bad, but it is a couple hundred bucks to avoid if possible.
    The dealership on Maui was dumb. Nobody mentioned that it had to be reprogrammed with the car and existing keys. I had to go out to my car, try and use it, then look like a dumbass. Then I had to go through the hassle of scheduling the appointment and bring everything in a week later and pay for it to be reprogrammed on top of the price of the key. It was stupid. I'm so glad I'm on Oahu now, the dealership here isn't quite as full of it.
    Current: 2019 B9 A4 Quattro
    Former: 2016 8V A3 Quattro, 2011 Mk6 GTI DSG 4-door, 2005.5 B7 A4 2.0T FWD CVT
    Veteran Member Four Rings cstarky15's Avatar
    Feb 16 2008
    Oakdale, MN
    Re: Lost Key?
    make sure the FCC # is the same. Some dealers will cut them for free others with charge you $60. I'm not sure how to porgram the B7 keys. b5 were easy!
    The usual things!!
    Resistor Install
    Mar 12 2007
    A4 B7 Sline Ti pkg.
    Re: Lost Key?
    k i will call my service advisor. I know it won't be difficult to get but im trying to avoid the expensive part.
    Veteran Member Three Rings mksap11's Avatar
    Apr 06 2005
    Boston, MA
    Re: Lost Key?
    Quote Originally Posted by lak2881 View Post
    You need to get it programmed at the dealership as your car needs to be connected to their computer which communicates back to Germany to get the new key codes.
    Veteran Member Four Rings Glassnpowder98's Avatar
    Mar 07 2008
    Audi A4 B7
    VA
    Re: Lost Key?
    I would suggest ebay to get the key for cheap. It is still going to cost you at least $150 to get your key cut and programmed but at least you will save around $100 on the key. Definitely make sure that you bring all of your keys with you to the dealership because they will have to reprogram all of them. If you forget the keys and they don't program them with your car, you won't be able to start your car with them, you will only be able to unlock your doors.
    05.5 A4 2.0T Brilliant Red 6MT: Put some money and time into it...
    The only standing start, straight line racing I enjoy is on the way to the first corner.
    Veteran Member Four Rings Vito Roma's Avatar
    Oct 08 2007
    Syracuse, NY
    Re: Lost Key?
    i've heard through dealer could cost $200-$300 for new key/re programming. thats why they give you 2 keys, a back up valet key, and the small ass one to equal 4
    '12 Bril. Black A4 2.0T/Quattro/Prem+/Sports package
    SLine body/Sline Door sills/3 spoke pref wheel w.Paddles/Sport seats/VMR 708 Matte Black(19x8.5) **For Sale**/Custom Black OEM caps/35% Tint/Needle Swipe/Fob/"Wink" & Amber Delete/More VagCom/RS4 Grille/ Hoen Endurance Fogs/ST Coilovers *Sold* /Debadged/V1 w. Concealed display *Sold*
    Mar 12 2007
    A4 B7 Sline Ti pkg.
    Re: Lost Key?
    So my friends dad owns a VW dealership could i get the key cut and programmed there? Is it the same system? I would buy the key on ebay or something.
    Feb 16 2008
    Oakdale, MN
    Re: Lost Key?
    ummm, i dont think so. I got my car from a VW dealer but it had Audi service stickers from they getting it serviced! the vw dealer i went to for my B5 wouldn't touch my audi or it's keys.
    The usual things!!
    Resistor Install
