1.8tqm, k04 with chip. Car has been sitting for about two months or so. I started it the first time a couple weeks after it had been sitting and it started fine. Then I started it a second time about a month after and it ran for about six minutes and then all of a sudden it shut down. so i started it again and it ran for a minute or so and shut down again so i let it stay off as i had to do something else. Now started it the third time after a week and a bit and it wouldn't start. It was idling everytime i left it on and the whole time it was parked i left the negative from battery disconnected. When i started it and left it on ignition for 60 seconds for it to learn the position and it kept making a clicking noise from under the hood and from around the speedo and fuse area. I changed the plugs and made sure there's pressure coming from the fuel pump. After i changed the plugs and cranked it a few times and it started but would only stay on for two seconds. Finally i reved once i heard it start and it stays on if i keep reving it but if i hold the gas at whatever rpm it shuts off. what could it be? any suggestions before i have to take it down to my mechanic? Car worked perfectly right before it was stored and I had the battery and alternator replaced a couple days before it was parked away.
