Results 1 to 31 of 31
    Veteran Member Four Rings KryptoniK's Avatar
    Jan 29 2006
    08 RS4
    My new RS4 - Mods, Dyno, Weights, Pics..
    Well everyone I sold my B7 S4 a few months back and am now a proud owner of one of my dream cars.. a 2008 Daytona Grey RS4 fully loaded. To keep things short.. after having my S4 modded the way it was, I couldn't resist to do the same mods to my RS4 and offer the community with some hard numbers on the mods.
    I'm not going to get into too much detail on reviews of the mods since most people here know what they're all about and how they improve performance on these cars.
    Before I start, I owe a big thanks to KMD Tuning for the clean and professional installation of all these mods. The entire staff there was incredibly helpful with all their advice and worked extremely hard to get everything done ASAP. They also did a great job on the dyno runs giving me a lot of info on how the car runs. If anyone in the Tri-State area is looking for a reputable shop I would strongly recommend KMD.
    =============================== INDEX ====================
    ==== MODIFICATIONS
    Tires: Bridgestone Potenza RE0-1R 275/30/19
    Suspension: KW-V3 - Corner Weight Balanced
    Sways: H-Sport
    Shifter: KMD Short Shifter
    SS Lines: StopTech
    Intake: K&N Drop-in Filter
    Exhaust: Milltek Full Non-Resonated
    ECU: Revo
    ==== CHARTS
    Dyno Run: Stock
    Exhaust/K&N
    Exhaust/K&N/Revo
    Weight: Stock
    Full Mods
    Alignment: Lowered Height
    ========================= MODIFICATIONS ====================
    No rubbing at all on stock wheels with KW-V3 installed. Only the front tires rubbed on the top fender liner screw, just removed it and absolutely no rubbing under any circumstances.
    Suspension: KW-V3
    AMAZING handling suspension, compared to the Tein SS I had on the S4 there is just no comparison. Although the dynamics of the RS4 might be different than the S4, there is a major difference in ride quality and as well as product quality. Unfortunately for me when I had put the S4 back to stock suspension, we discovered that the dampening adjustment knobs on the Tein SS had all seized. Had to trash them
    Sways: H-Sport
    Added a little bit of harshness going over uneven pavement, other than that it is totally worth the handling improvement. It's like driving on rails.
    Quality construction. Shorter shift travel feels smooth.
    SS Lines: StopTech
    Small noticeable difference, would probably appreciate it more on a track day under extremely heavy braking.
    Great sound and saved a good amount of weight, about 30lbs. Increased WHP. Check below for dyno charts.
    ECU: Revo
    Great re-flash that noticeably opened up the engine and made it more peppy. Increase in WHP. Check below for dyno charts.
    ============================= CHARTS ====================
    Dyno Run:
    READ HERE BEFORE you read these charts. The first chart is my final dyno run of my B7 S4 with K&N/Full Labree/Revo, it's to be used as sort of a reference as to how power is measured on this dyno.
    The stock chart of the RS4 had some kind of error on the readings. Working on getting a ligitimate copy. I'm posting it up to show the Air/Fuel ratio reading which is accurate so we can compare the difference after the Revo flash is done.
    The Revo flash alone showed a gain of 7 whp. I think it might be safe to assume that I gained atleast 15 whp from the exhaust. According to Fourtitude.com's dyno test which was done with only a cat-back milltek exhaust, there was a gain of 9whp in that alone. Although it was done on a Mustang dyno, I don't think it should be too far off.
    B7 S4 Modded
    Stock B7 RS4
    Exhaust/K&N
    Exhaust/K&N/Revo
    Weight:
    READ HERE BEFORE you read these charts. Unfortunately I didn't take the fuel levels into consideration when weighing stock and modified. The stock measure was done with the tank almost down to the last red marking. The fully modified measure was done with half a tank full.
    My estimated guess goes as follows (I could be wrong). 1 gallon of gas equals +/- 6 lbs. Stock comes out to around 3,946. After installing the suspension, sways, (heavier) tires, exhaust, I come out to about 3,900. So I think it could be safe to claim a savings of 46 lbs total.
    Stock
    Full Mods - Corner Weights Adjusted
    Alignment:
    Lowered Height
    =============================== PHOTOS ====================
    Hope you all find this information useful in future mod decisions, or even as a good read to pass time Feel free to ask me any questions.
    -Dave-
    Established Member Two Rings skiaudi's Avatar
    Nov 12 2007
    06 A4 2.0T quattro 6MT
    Re: My new RS4 - Mods, Dyno, Weights, Pics..
    congrats- rs4 is an incredible car
    Light Silver Metallic | Ebony
    Veteran Member Four Rings Cargo8's Avatar
    Dec 06 2006
    beautiful! and props for all the data keeping. very nice, enjoy the ride!
    Established Member Two Rings maybachgt's Avatar
    Feb 13 2007
    los angeles
    Wow! Thank you very much for doing this dyno. I have the same mods on my car so its cool to know I gained some power, even though I definitely felt it. How do you like your tires?
    Veteran Member Four Rings nimski62's Avatar
    Mar 11 2008
    2005.5 B7 S4 6mt, 2002 b6 3.0Q
    Pierceton, Indiana
    JESUS CHRIST, thats beautiful!
    Sep 19 2007
    seattle
    Amazingly beautiful!
    Dec 30 2007
    Constantly changing.
    DC
    Thanks for taking the time to post this data. Also like the new stance of the RS4!
    Registered Member Two Rings swoyekr.'s Avatar
    Feb 21 2008
    SE PA
    sick stance!
    04 s4 - .Milltek catback SOLD
    Current daily - RSX TYPE S
    Jan 29 2006
    08 RS4
    Thanks for the compliments everyone. My love for Audi's has grown greater with the purchase of this car.. absolutely love it!
    Quote Originally Posted by maybachgt View Post
    The tires feel rigid and accurate. Insane grip over the stock tires, I've made a few people sick to their stomachs on some tight jug handle highway on-ramps.
    Active Member Two Rings gelkad's Avatar
    May 07 2008
    RS5,911 TTS,911TT 2010 (Sold), Panamera 2009 (Sold),R8 2008 ( sold ),RS4 2008 (sold),R32 2006(Sold)
    Saint Cloud, MN.
    Hi,
    I have the same car, I was wondering where can i reflash my ECU.. in tri state area,
    thanks
    Jan 29 2006
    08 RS4
    Quote Originally Posted by gelkad View Post
    Hi,
    thanks
    Ah sorry I didn't mention where KMD Tuning is located. They're actually in Mountainside, N.J. on Rt. 22 West. http://kmdtuning.com/store/ for directions.
    Veteran Member Three Rings s4_fishingbean's Avatar
    Apr 13 2008
    B7 S4
    Ft. Lauderdale
    oh my......
    Veteran Member Three Rings johntesi's Avatar
    Jan 17 2008
    Evolution X
    Texas
    Looks amazing! You always post some of the most in-depth and helpful reviews I've seen!
    Any idea on how many miles you can expect out of those tires? Any experience with them?
    I have been tempted to get some for a while now...
    Senior Member Three Rings asurugger's Avatar
    Mar 12 2008
    2008 Cadillac Escalade
    Phoenix, AZ
    Thanks for all the data...very sweet. Love the color
    2016 Audi A6 Prestige
    Veteran Member Three Rings likewater's Avatar
    Sep 18 2006
    2012 Honda Pilot, 2005 F150 FX4
    So Cal
    Just beautiful man. The car and the write up. Bravo!!!!
    Current - 2011 B8 S4 DSG Presitge - APR Stg 1 | RS4 Grill | Magnaflow Xpipe and Mufflers | K&N | Apikol Rear Diff Mount (Race)| H&R OE Sports | Avant Garde M310 19X9.5 ET 40
    SOLD - 2005 B6 S4 6MT with many mods.
    May 28 2008
    Dubai, United Arab Emirates
    Thanks for the amazing post. I was wondering if the sway bars would make much of a difference, and if so, what.
    Any reason for swopping out the stock sports suspension for the KW V3s? How do the V3s compare against stock?
    I'm pretty impressed with the gains you got from the K&N, exhaust and Revo -- 392 to 439 bhp is no mean gain. My only concern would be the drone from the aftermarket exhaust and I've been told that there is no way to get away from that. Reason I bought the RS4 was because I wanted something fast and quiet on the highway, and the stock exhaust makes a great sound when I'm driving with a heavy right foot, which I'm loathe to give up for a permanent, albeit impressive, soundtrack
    Any numbers on how the Revo delivers to a stock exhaust and intake?
    Nov 27 2006
    07 RS4-E63 M6-07 A3 2.0T
    San Diego
    so from stock to exhaust and k&n your trying to tell me you got 86 whp. i find that a bit hard to believe if im reading correctly. Also Rs4's put down approx 310-320 stock. im not sure i understand the graphs.
    Audi RS4 | Mugello Blue on Black | Premium Package | Valentine 1 | SOLD
    Audi A3 | Ibis White on Black | DSG | S-Line | Cold Weather | Open Sky | Audi Navigation | Technology Package | Premium Sound | APR Stage 2 | GHL Exhaust | KWV2 | Neuspeed Intake | APR Fuel Pump | Hotchkis Sways | AWE Vent Boost Gauge Soon | Blackout S-Line Grille | JL Audio Full Sound System | EuroJet FMIC Soon | Weight Reduction | SOLD
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    Quote Originally Posted by SoCalRS4 View Post
    op said that there was some trouble on the stock run.
    damn if the stock run was accurate....420chp to 230 whp..almost 50% drivetrain lost!
    TEAM|AXION
    Senior Member Two Rings Snipps's Avatar
    Sep 30 2007
    B7 A4 2.0 Quattro
    Did I see you at a gas station in Scarsdale,NY last night? I saw a daytona RS4 and it looked pretty low, don't see many of them really.
    Go APR 93
    Coming Soon:AWE Tuning Tip Exhaust
    Jan 29 2006
    08 RS4
    you,re absolutely right.. The stock chart is wrong.. I stated to disregard the numbers because they are innacurate.. Apparently they input the carinto the system as a watercooled turbo motor on the stock run... The only reading on there that is right is the stock Air/Fuel reading..
    I wish it was a gain of 80 whp ;)
    Jan 29 2006
    08 RS4
    Quote Originally Posted by Snipps View Post
    Hmmm not me.. Although I am doing a job in that town tomorrow.. I drive a toyota pickup during the week.
    Feb 15 2007
    very nice. Too low for me though!!
    2007 Audi RS4 - Daytona Grey - Original Owner
    1957 MG MGA 1800 - Austin Healey Spruce Green
    2020 Mercedes-Benz GLC 63 AMG - designo Cardinal Red
    2023 Mini Cooper SE - White Silver Metallic
    Account Terminated Four Rings
    Apr 16 2007
    New Jersey
    you would have made more power if you took it to 8k. thats where these cars make they're power. next time you get dyno'd, rev it out and see the difference
    Registered Member Two Rings Lake Powell's Avatar
    Apr 07 2008
    2007' RS 4
    Salt Lake City
    Is there any way I can get the REVO ecu mod without taking the car to a shop. The closest listed dealer is 360 miles away in Denver, I'm in Salt Lake.
    Veteran Member Three Rings S4J's Avatar
    Sep 26 2006
    Nor Cal
    Dam I love those fenders! I still wish there was a B6 RS4. Nice ride and thanks for sharing the stats.
    "Will power? I've got all kinds of will power...it's the WILL NOT power I'm lacking." saj
    || MoroBlue/Silver/6sp/Prem pkg || JHM LW Pulley & Mani Spacer || APR Snub || H-Sport F/R || Bilstein PSS9's || Neuspeed SS || GIAC || K&N || Full Milltek Res || Apikol Rear Diff Mount || Ind Fog Mod || PIAA Xtreme 4150K Fogs || E-Codes || Carbotech Bobcat Brake Pads || RS4 Pedals || V1 W/Remote-mute in Shift Boot || Vellano VSQ 19x8.5 || ECS Rotors ||
    Veteran Member Four Rings 2PUTT's Avatar
    Nov 09 2005
    UBIQUITOUS
    i think i saw your stock exhaust outside the shop....
    2009 Audi Q7 TDI
    2001 Audi S4 Avant
    CHALLENGE MW
    AWE | AWE | AWE
    Jan 29 2006
    08 RS4
    Quote Originally Posted by zachf88 View Post
    Thanks man.. oh yea I need to raise the car a bit, it settled more than I thought it would...
    Jan 29 2006
    08 RS4
    Quote Originally Posted by 2PUTT View Post
    Ah not mine. I took mine home the same day... There was actually about 4 stock rs4 exhausts there when I had mine installed. KMD is doing good ;)
    Established Member Two Rings ichibunz's Avatar
    Jun 03 2008
    Danbury,CT
    that's my next mod an RS4..NICE!
    Veteran Member Four Rings channad's Avatar
    Oct 14 2007
    2008 S4 DTM; 2017 Q7 Prestige
    Mammoth Lakes, Ca
    when I saw the pics, my jaw just dropped
    ChannaD aka Techno Dad | New DJ Mix | New YouTube Video!!
    2012 Q5 - Black | Black | Premium Plus | S-Line | Nav | B & O
    2008 - DTM | Sprint Blue Pearl | Black leather/Alcantara | Navi | CF trim | OEM 18" RS4s
    Veteran Member Four Rings Dodge2Dub's Avatar
    Feb 18 2007
    E90 M3; Ducati S2R 1000
    San Diego, CA
    I'm a bit confused. The modded S made 236 and the modded R made 326 HP at the wheels? It seems as though the wHp for the S is really low in comparison, especially when you consider that the S was tested in cooler temps.
    Cool stuff with a little growl!
