Results 1 to 23 of 23
    Active Member Four Rings bassed's Avatar
    Sep 24 2005
    always in design
    What would you say is respectable whp/tq at 18psi?....
    Just curious?
    Veteran Member Four Rings quattro16's Avatar
    Feb 05 2007
    Long Island, NY
    Re: What would you say is respectable whp/tq at 18psi?....
    300hp 290 tq. But what the fuck do I know!
    BetaAlphaTauMember #17
    20 Year Audi Master Guild Technician
    Long Island, NY. Instagram @andyaudiman
    Jul 07 2004
    630AWHP A4, Nissan Titan
    socal
    400whp 350tq.
    Veteran Member Four Rings Euro-Tuner's Avatar
    Jan 06 2007
    NH
    have any numbers?
    Jul 07 2004
    socal
    Quote Originally Posted by Euro-Tuner View Post
    have any numbers?
    Yes, just try another forum that starts with A and is on this world.
    Sep 24 2005
    always in design
    400whp 350tq.
    Once the WG is dialed I hope to nudge another 35-40 out of her at 18psi
    have any numbers?
    Jul 07 2004
    socal
    Quote Originally Posted by bassed View Post
    What do you mean "dail the wg"? Are you just making it stay closed longer so that more of the exhaust is forced thru it up to the point that you do make 18psi?
    Veteran Member Three Rings beejohn's Avatar
    Jan 24 2005
    Pennsylvania
    yeah i don't get how adjusting the wastegate would make any more peak power if you are still going to be running 18psi???
    --beejohn
    2001 A4 1.8TQMS
    Jul 07 2004
    socal
    Quote Originally Posted by beejohn View Post
    If the wg is cracking open too soon then fixing that will make more low end power, I dont think its going to make a huge diffence at the top end since the wg is still making the turbo produce just 18psi.
    BTW at 18psi it looks like the boost drops slightly after 5500 rpm. I wonder if that taper will get bigger when pushing 25psi.
    Feb 15 2007
    marimont
    You have to dial in the synapse wastegates. They operate a little different then a set tial spring works.
    Sep 24 2005
    always in design
    This is all WG dialing related. The Synapse is nothing like a Tial in anyway shape or form.
    Jul 07 2004
    socal
    But it is still just a valve that allows pressure to bypass the turbo. It doesn't add air flow for the same boost level. Basically all it is a newer design of the same part.
    Veteran Member Four Rings TQMB5's Avatar
    Jan 17 2006
    2002 S6
    Grand Rapids, MI
    thats nuts, goood numbers
    ::2002 S6
    Jan 06 2007
    NH
    Thread Jack!
    can I get a quick rundown of how my Tial 44mm WG is going to act? and will I be able to tweak it at all with a custom tune on an N75 valve as opposed to an EBC? will it produce enough vacuum to open the WG the way it is setup from the factory?
    ...I feel silly asking, but its better to find out know than after something doesnt work.
    Jul 07 2004
    socal
    Yes you can if you can get the tuner to do the tune for the spring rating that youy have on your Tial. Its just better to use a EBC since it is basically a stand alone ecu/n75 which can react quicker then the OEM setup. One big advantage the EBC has over a OEM N75 valve is the fact that you have 2 hoses going to the Tial WG, one that supplies pressure to the top and another one to the bottom. This means the WG can be fully closed till the very last second, while the N75 blocks all pressure till it needs to start opening the wg and usually does that much sooner then it should.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    What have you changed since the last dyno run? I'm pretty sure I heard a couple things have changed. Are you running W/M? going to?
    W/o W/M I'd say 362whp and 318wtq.
    Just to be different.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    running a lil rich top end, huh Ian?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by 317ssayzarc View Post
    Better rich than lean.
    It just goes to show how much headroom he has as is. IIRC he has enough fuel for a very respectable amount of power.
    Veteran Member Four Rings GetBoosted84's Avatar
    Apr 10 2007
    01 Audi A4 1.8T Quattro / 88 Mazda RX-7 GXL
    Eastern PA
    Nice numbers bassed. Did you really drive all the way to canada to get your car tuned? Man you are dedicated. My hats off to you.
    BTW, how did the rest of the install go? Were you and Aaron able to get everything mounted the way you wanted it?
    Jul 07 2004
    socal
    Still in the 11's so its not too rich.
    Sep 24 2005
    always in design
    Quote Originally Posted by djwimbo View Post
    Went with 2.5" IC piping all the way though and hooked up the w/m. I am running it it as well.
    Just right for room to make lots more power
    Quote Originally Posted by GetBoosted84 View Post
    Yup I've spent some time on the rollers up there now. I ended up trunk mounting and having a pretty clean install. Aeron wouldn't allow me to mount it where I wanted and I'm happy about that now
    Apr 10 2007
    Eastern PA
    lol, yeah I didn't think he was going to let you put it there. That's awesome that it came out good.
    Are you heading to waterfest btw?
    Veteran Member Four Rings chris164935's Avatar
    Apr 18 2007
    2016 Audi A3 2.0tQ; 2001 Audi A4 1.8tQM
    Orange Park, FL
    Sounds like too much hassle just to be able to maintain a boost level. A Tial wastegate with an EBC sounds much simpler...
    "You know you have a bad idea when Ford guys are making fun of you."
