Results 1 to 6 of 6
    Veteran Member Three Rings A4twin's Avatar
    Jun 02 2007
    2016 SQ5 2021 VW Tiguan
    Pasadena, Tx
    WTB: Tranny Mount B6 1.8T Quattro Manual
    looking for a decent used oem tranny mount for a b6 1.t quattro manual
    thanks
    PM or email at [email protected]
    can do paypal
    2016 SQ5 APR OBD11
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Re: WTB: Tranny Mount B6 1.8T Quattro Manual
    Quote Originally Posted by A4twin View Post
    thanks
    can do paypal
    you got PM
    -Sami-
    Veteran Member Three Rings nihil's Avatar
    Oct 01 2007
    Too small
    N/A
    I've got one I just pulled out a week or two ago, but I have to ask, why get a used mount? The 034 density trans mount is fairly cheap, and is better than the OEM part, and much better than a used OEM part.
    2002 A4 1.8TQMS (sold)
    1982 MB Geländewagen 300GD
    1968 Charger R/T
    1987 Porsche 944 (sold)
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
    Dec 03 2005
    2 pedals 1FG
    connecticut
    I've got an OEM bushing if you need it.
    -Doug
    Jun 02 2007
    Pasadena, Tx
    Quote Originally Posted by nihil View Post
    i have the 034 trans mount, to much vibration for my taste. yes, i've loosen all nuts ran car for a few minutes then tighten all mounts (done this three times) but still get to much of vibration for me.
    any body have any other suggestions?
    2016 SQ5 APR OBD11
    Oct 01 2007
    Too small
    N/A
    I was worried about that when I did mine, and after the first couple days it started vibrating pretty bad, but then I loosened the mounts, let it idle for a minute or so, then tightened everything back down, and it has been fine since. It might be slightly louder than stock when cold, but after it warms up it's no louder than with the old mounts. I don't know why the same process would work differently for you. Did you remove the rubber dust boot from the 034 mount? Did you use the large washer/spacer that came off the OEM mount? Did you do the engine mounts at the same time? Snub?
    You can have my OEM mount for shipping costs, but be prepared for sloppy sloppy shifting, and I don't have the center bolt that goes with it (stripped head, had to cut it).
    1968 Charger R/T
    2015 Tacoma TRD/OR
    2007 4Runner
    2022 Tenere700
    2009 TW200
