Just curious to see if everyone is as anal as myself about keeping track of their records.
-Purchased April 13, 2007 with 61,345 miles
May 5, 2007 New Tires and Alignment- 62,211
May 16, 2007- New Spark Plugs
June 2, 2007- New Spoiler Light
June 8, 2007- Oil Change
July 20, 2007- New Rear Rotors and Pads- Stock & Used Front Rotors, Pads, Calipers from B5 S4, changed brake fluid, and Tire Rotation- 68,145mi
August 10, 2007- Changed Oil and filter (installed magnetic drain plug), new cabin air filter, installed APR snub mount- 69,350 miles
October 11, 2007- Tires balanced & rotated- 73,685 miles
November 17, 2007- Changed oil & filter, new oil dipstick, changed power steering fluid, fuel injector additive in tank, changed transmission fluid (installed magnetic drain plug), changed rear gear oil, and changed fuel filter.
February 15, 2007- Installed (4) new coil packs
March 7, 2008- Installed new timing belt, accessories drive belt, water pump, tensioner assembly, tensioner roller, idler
roller, coolant, changed oil & filter- 81,202
March 21, 2008- Tires rotated
March 22, 2008- New power Steering fluid (again)- 81,900
June 18, 2008- Clear corner Mod
June 19, 2008- New Cabin Filter
June 20, 2008- Rebuilt K03 turbo, new coolant, and new oil/filter- 88,772
June 21, 2008- Valve Gaskets replaced and new spark plugs
June 22, 2008- New tail light bulbs
